A very welcomed hole in the clouds (the first in the last two weeks) allowed me to capture few discs in WL, CaK (with aperture reduced to 50 mm due to unfavourable seeing) and H-alpha. There was almost nothing to image in WL except granulation and two tiny spots in the northern hemisphere. While imaging in H-alpha clouds returned so the image came out hazy. All images with ASI 178MM.
Right click then enlarge to see at full size. Thanks for looking.
Full discs of February 21st - ASI 178MM
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
- 2021-02-21-1356-RB-Halpha-fulldisc.jpg (152.41 KiB) Viewed 282 times
- 2021-02-21-1318-RB-CaK-fulldisc.jpg (362.81 KiB) Viewed 282 times
- 2021-02-21-1311-RB-WL-fulldisc.jpg (483 KiB) Viewed 282 times
- Been thanked: 4900 times
Re: Full discs of February 21st - ASI 178MM
Thank you Raffaello for well-good FD's - which showed as much as could be seen today in the three-lights.
- Has thanked: 20442 times
- Been thanked: 10248 times
These are excellent disks Raf!
- Has thanked: 17581 times
- Been thanked: 16697 times
The sun was really calm today. Not much to see or image. Nice discs though!
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Good captures Raffaello, thanks for sharing. Cloudy here since the 18th February
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4340 times
Great FD images Raf...well done
- krakatoa1883
Thank you very much. Worst winter ever here but this week should be better.
- Has thanked: 17672 times
- Been thanked: 8793 times
They certainly do look good in large full size
