Sunday Sunshine 21st March
- Has thanked: 20424 times
- Been thanked: 10243 times
I nearly didn't get to image at all yesterday; I seemed to be trapped under cloud all day, and by early afternoon decided the day was a write off and resorted to a few cold ones and listening to some music. Next thing I know the sun is out and the stubborn cloud had burned off, it was a close call, i'd had a few cold uns' at this point and i'm never happy playing with expensive telescopes when ones mind is slightly distracted. Slowly and carefully I set up. First off the full disk with the DS50 setup:
Ha-FD-bw by Mark Townley, on Flickr
Ha-FD-colour by Mark Townley, on Flickr
I need to have a good clear run with the DS50 to get the tuning flatter and more even. I was fighting the seeing even with the 50mm, and slower frame rate of the camera, and only 1000 sub frames per file meant it is more susceptible to a poorer signal to noise. Compare this to the DS90 at f25 I used for the closeups, and the considerably faster frame rate of the IMX174 camera and 4000 sub frames per file meant I had better data to stack a final image from.
ARs-Ha-bw by Mark Townley, on Flickr
ARs-Ha-colour by Mark Townley, on Flickr
filaments-bw by Mark Townley, on Flickr
filaments-colour by Mark Townley, on Flickr
Given I was expecting nothing from yesterday, to get these I was pleased with the results.
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4786 times
- Been thanked: 4900 times
Re: Sunday Sunshine 21st March
Considering the stubborn-conditions Mark, a well nice set of images.
Cheers
terry
Cheers
terry
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Thanks guys!
- Been thanked: 4904 times
Mark:
In spite of weather, you got a very nice set of images.
Best wishes.
Best wishes.
- Has thanked: 17572 times
- Been thanked: 16691 times
Mark,
I am glad you pulled off a good imaging session and didn't fall over your scope! It looks like you do dern good work buzzed!
Thanks everyone!
- Has thanked: 8415 times
- Been thanked: 8161 times
A really nice set of images, Mark. It’s so satisfying when the weather goes your way....if not entirely.
- Has thanked: 17666 times
- Been thanked: 8787 times
Well done Mark there looks to be quite a few smaller hot spots around too
I know what you mean about the drink, I always like to get set up before the drink comes, not after. The sky cleared for me too around 3pm but that is a no go for me as the Sun goes behind a neighbour's house. It has to be late May to mid July for me to do late imaging.
- Has thanked: 9144 times
- Been thanked: 6025 times
Beautiful images, Mark: thank you for the peek at your capture techniques.
Thanks everyone! I'm hoping Saturday mornings forecast delivers for me...
- Been thanked: 4340 times
Superb images Mark...glad to see great results for the break in the weather
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
A couple of cold once doesn't seem to affect your skills at solar-photography or focusing! Great images Mark!
Arne
Arne
