Sun FD in H-Alpha 24th of March 2021
- arnedanielsen
- Has thanked: 6305 times
- Been thanked: 7321 times
Yesterday was mostly scattered clouds, but in the afternoon it cleared enough for a quick imaging session - still through some high cirrus-clouds though.
Full size version
Equipment used for this image was a Takahashi Sky-90 II with SolarMax 90 and BF15 filter, Baader 35nm H-Alpha filter, 2x Cemax Barlow and ASI ZWO 1600MM PRO camera. Everything mounted on a Paramount ME mount.
Stack of the best 60% (400of 673) images captured with an exposure time of 2.3ms, gain 0, HighSpeed=On and 22fps. Stacking done in Autostakkert 3, sharpening in AstraImage and contrast stretching in Adobe PhotoShop.
Arne
Full size version
Arne
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4880 times
- Been thanked: 4980 times
- Has thanked: 17849 times
- Been thanked: 16991 times
Re: Sun FD in H-Alpha 24th of March 2021
Very nice Arne. Clouds have had me missing it.
- Been thanked: 8906 times
Superb full disc the disc looks very similar to yesterday when I had a peep, so not much changed overnight.
- Has thanked: 9318 times
- Been thanked: 6154 times
- rsfoto
- Has thanked: 9723 times
- Been thanked: 5771 times
Hi Arne,
Well done
Well done
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely capture Arne, well done through the clouds.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4426 times
Well done Arne
- arnedanielsen
Thank you all for your kind comments!
The resulting image turned out better than I expected considering the amount of cirrus.
Arne
Arne
- Has thanked: 20811 times
- Been thanked: 10480 times
Great disk through the cirrus Arne!
