HA 04/02/2021
- Has thanked: 20813 times
- Been thanked: 10484 times
Re: HA 04/02/2021
That's a really nice image Jozef!
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4880 times
- Has thanked: 3317 times
- Been thanked: 1907 times
- Has thanked: 17849 times
- Been thanked: 16992 times
Re: HA 04/02/2021
There is a gap between the prom and filament. It looks like it was not a true filaprom after all. It took good resolution to see that!!
- Been thanked: 4900 times
Re: HA 04/02/2021
Indeed as James has just said, but still an excellent capture Jozef.
Thanks vm for sharing
- oreoluna
- Has thanked: 1 time
- Been thanked: 661 times
Re: HA 04/02/2021
LZOS 6" f8 Apo, Baader 160 D-ERF, TV 4x Powermate, SolarSpectrum 0,3À, ASI290mm
Jozef
- oreoluna
Re: HA 04/02/2021
DeepSolar64 wrote: ↑Sat Apr 03, 2021 2:35 pm There is a gap between the prom and filament. It looks like it was not a true filaprom after all. It took good resolution to see that!!
Yes definitely, there was a gap between filament and prominence.
Jozef
Re: HA 04/02/2021
And your image has the resolution to show that! Congratulations. That's awesome!!
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: HA 04/02/2021
Lovely Jozef, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4427 times
Re: HA 04/02/2021
Excellent capture and processing Jozef...well done
