Uv/ir cut
- Has thanked: 496 times
- Been thanked: 635 times
Uv/ir cut
in WL with astrosolar, in front of the 540nm filter do I have to use a uv/ir filter? is the Baader filter suitable or do I have to use one in particular
- Has thanked: 3180 times
- Been thanked: 2289 times
Re: Uv/ir cut
It might give better results. Baader recommends a uv/ir cut filter for visual use with the 540nm filter and the shown bandpass ranges from 400nm-700nm. So i would try it out and see if a difference is there.
Triband C9.25
H-a: 1-2 Lunt40 rear mounted
Ca-K: homebrew (includes 2x 1.5A filters, thanks Apollo), corrective lenses (thanks again Apollo)
Cameras: imx432 + imx462
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 18303 times
- Been thanked: 8982 times
Re: Uv/ir cut
I usually do, the older versions of the Baader Continuum didn't block very far IR so tended to make imaging blurry. If you have one, use it anyway, it won't change anything if you don't need it but will make a huge improvement if you do need it
Re: Uv/ir cut
i have the new version of the uv/ircut filter. I can mount the 1.25 filter directly on the nose of the camera … camera-filter540-barlowtv2x-uv/ir-herschel filter…
- Has thanked: 21147 times
- Been thanked: 10693 times
Re: Uv/ir cut
I would mount that uv/ir cut much higher up the optical train if you can
Re: Uv/ir cut
I always get confused… at the top you mean near the sensor or the telescope? My doubt is, can a filter immediately after the sensor worsen the performance of the powermate or telecentric in general?
- Has thanked: 162 times
- Been thanked: 320 times
Re: Uv/ir cut
Generally, when we talk about before or after in an optical train we are referencing the path of light in time. So with a refractor, first is the objective lens, last is the detector.
It seems to be good practice to put the UV/IR filter closer to the refractor objective. The earlier you can reject heat causing energy, the better. This lessons the potential to build up heat in the system. When Mark says higher up, he means earlier in the incoming light path or closer to the refractor objective.
