sol ex with 3600lpmm and apo66
- Has thanked: 57 times
- Been thanked: 1231 times
due to high dispersion angle limited range from neutral calcium thru deep UV
but boy real narrow bandpass
H-beta
for me some of my best
H-beta
Re: sol ex with 3600lpmm and apo66
neutral calcium
caH
got some filaments
got some filaments
- Has thanked: 20998 times
- Been thanked: 10624 times
Re: sol ex with 3200lpmm and apo66
That new grating works well!
- Has thanked: 18146 times
- Been thanked: 8947 times
- Has thanked: 17 times
- Been thanked: 80 times
These are very detailed. What effect does the 3600l/mm grating have on light throughput? I would imagine you need to use higher gain or exposure settings?
yes
but remember solar intensity chart
486 nm still lots of light to play with
bigger problem with caH and K
- Has thanked: 9404 times
- Been thanked: 6218 times
Fantastic session with great results and well deserved SPOD , John.
- Has thanked: 48 times
- Been thanked: 1543 times
If you are using our SHG v4.3 software and a 3600 l/mm grating, you should take note of the new feature called "Ellipse fit shift". The default for this is 10 pixels, but that was chosen based on the assumption of using a 2400 l/mm grating. With the higher dispersion of a 3600 l/mm grating, you need to double this to 20 pixels or the ellipse fit routine may have a problem, particularly with Ca-K/H. I assume if you use a 1200 l/mm grating, you might want to reduce this to maybe 5 pixels.
was at 3.7
just re-did with 4.3 with 20 pixels
to all - would not have been able to get this spod without smiths SW.
tried 4.3 20 pix on caH image
maybe a bit better than 3.7
Note to: D Smith - I tried stubborn transversum button on this image to see what happens - came up with divide by zero and incomplete final image.
I had thought maybe the slightly non-circular shape of the H-beta might have been due to an ellipse fit issue as a result of the high dispersion grating. But I suspect it is actually that your mount scan was slightly irregular.
"Stubborn transversalium" is something to use if the problem is obviously transversalium (due to a stubborn bit of dust on the slit). Your slit looks quite clean. There is noise in the Ca-H image, but this is likely because you needed to use a longer exposure and slower scan (I assume).
Between v3.7 and v4.3 there were a lot of little improvements. I don't expect there will be any further updates until the spring due to work and university commitments. I would strongly recommend using the most recent version (v4.3). The file handling is much improved and it also now runs multithreaded so it is quite a bit faster if processing multiple files.
Would be interesting to see the results you get in CaK stopping the 66 down to 40mm John, I suspect it will be quite an improvement.
- Bastelhannes
- Has thanked: 83 times
- Been thanked: 138 times
Highfnum,
very nice images.
Where did you get the grating from?
very nice images.
My greatest fear is being married alive.
