Does F10 Matter in CaK?
Re: Does F10 Matter in CaK?
There the same amount of energy it's just spread out farther. That is one of the problems I see using a fast system. A lot of heat on the bandpass.
I don't know about your filters but the commercial CaK units from Lunt and Coronado both feature a "hot mirror" (dichroic interference filter) at the front of the device which reflects very nearly all the visible & infra red straight back up the tube, so it doesn't warm the filter to any significant amount. The way I understand the 4" aperture safe limit on the Lunt unit, it's because of differential heating between the "hot mirror" and its mount when the defocused solar image is hitting both which might possibly cause damage. The focal ratio doesn't actually come into the equation except for the fact that the defocused solar image will be smaller / more intense in proportion to the focal ratio i.e. there is more energy per unit area in the 3" inside focus beam of a 4" f/15 scope than there is 3" inside focus in a 4" f/5.
- sullij1
I understand it as brianb, that is where the confusion creeps in for "everybody". Which is it????????
That is why I am asking all the questions!!!!!!!!!
Look Up!
I find it strange that I had an easier time focusing at F10 rather than F7. I guess the slower the better. .
Pat, the critical focus zone on telescopes is wider at larger F/ratios, so an f/10 scope is easier to focus than an f/7. For example, for a 4" scope at f/7, the critical focus zone in microns is approximate 108, and for a 4" at f/10, it is 220.
- Has thanked: 20442 times
- Been thanked: 10246 times
A very interesting thread Joe! Thanks for creating it
I think, the biggest variable here is the scope being used; people appear to get good and bad results in CaK with a variety of scopes at a variety of f-ratios. My unbranded 70mm f6 achromat performs very well at f6, my Tal100R @ f10 gives really nice contrasty images, however my Meade 127mm AR5 @ f9.7 gives the worst results of the 3 scopes. I think it's down to the objective lenses themselves...
Just my 2c... :whistle:
- sullij1
Thanks for poping in. Is your AR5 the newer ED/APO version or the Achro version? (again the objective question)
Never mind - I see you did say Achro,
Look Up!
- sullij1
[quote] The focal ratio doesn't actually come into the equation except for the fact that the defocused solar image will be smaller / more intense in proportion to the focal ratio i.e. there is more energy per unit area in the 3" inside focus beam of a 4" f/15 scope than there is 3" inside focus in a 4" f/5.
Not that this may matter for image as much as thermal cycle on the filters but I still dont get the idea.
For example Merlin66 has pointed out in the past the the solar disk in mm is roughly 1/100 of the focal length. So- 1/100 of 1000mm gets you "approximately 10mm concentration of the disk/heat" on the primary bandpass filter. (actually 10mm at the focal point/sensor.)
Granted as we discussed for the Lunt's the hot mirror and dichroic coated (blue filter?) prior to the bandpass filter cut much of the heat. Still it is fair to assume a "very small" percentage of heat is still being past to the primary band pass filter.
If you reduce the focal length to 500mm this makes the solar disk approximately 5mm in size. My mind wants to think this smaller disk size is carrying more energy in the form of more heat in the smaller size. (burning ants) Again it is reduced by the Hot mirror and (Blue filter? we still don't know. ) but is still carrying more energy/heat in a smaller area.
So as much as I want to align myself with brianb what Markthis "seems to be saying" still makes sense. The heat load delivered by the shorter focal LENGTH is higher.
Where is my admittedly layman thinking flawed?
This is all regarding filter life more than image. (and the question that confuses me most)
By and large I am convinced the longer f ratio for the Cak is better image wise.
So now we are getting a good image, the next question is what f ratio is easiest on the filter thus prolonging its working life? Lets face it these suckers are expensive!
Look Up!
- sullij1
Don't ya always hate the guy in the back of the class who is always raising their hand asking questions?
Look Up!
[quote][quote]
...If you reduce the focal ratio to 500mm ...quote]
I know you probably realize it, but you are referring to focal length here, not focal ratio. For purposes of some of the things discussed in this thread, the difference matters.
Please note that I have personally confirmed the Starlight Instruments A20-292 adapter is a perfect fit for the Celestron NexStar 102 GT OTA when used with the Starlight Instruments Feather Touch FTF2025BCR focuser.
- sullij1
Mark,
Thank you, yes, you are so right! I DO mean FOCAL LENGTH! Post edited.
(We applaud you for beating on the guy in the back ) 1 karma point delivered!
Sorry all.
Sorry all.
Look Up!
- sullij1
Mark,
Thanks for saying. I was considering an AR5 for this and other purposes. You just saved me and perhaps others some money.
Mark,
Look Up!
- Oh, I get it now!
Thanks for that. I will have to REALLY, REALLY like the scope to invest that kind of money. What did you think of the stock focuser? BTW, my scope did not come in yet, it's stuck in UPS pergatory (also known as Earth City, Missouri).
- sullij1
Personally I like the stock focuser. I have yet to have a problem hitting focus with it. I was actually going to buy one of the focusers that come on the Celestron unit for a PST mod. You don’t have the 10:1 control but it has yet to matter. I admit that I am a cheapskate, not by choice but by necessity.
Look Up!
- Oh, I get it now!
Hey Joe. That makes me feel better knowing you have bad seeing as well and the standard course focuser works for you. I will try the standard focuser and report back when I get it in and have a chance to use it.
- sullij1
Thanks pat, based on our other conversations at the sissy site (:)as Stephen says)I am now sure the reflections we saw in my images are the reflections in the diagnol B1800 I was using. You don't see them cuz you are using the straight through Cak Module. So the straight through is a better decision for imagers.
Look Up!
I've noticed that the reflection from the hot mirror on the front end of the CaK filter out the front of the objective is an extremely bright beam of light. There must be a corresponding bright reflection from the rear of the objective back to the CaK filter and that's what we see in images. How annoying.
- sullij1
A bit annoying for sure but as you saw it can be dealt with on surface features fairly well. It is on the limb trying to image proms that it becomes a bugger. To be more clear: I am cerian the reflection is from the mirror in the diagnol. With a straight through the mirror is ommited from the image train so no reflection (as in Pat's shots). Although the straight through is a better choice for imagers, both products are superior to any at the price point.
I would highly recommend either with the reflection caveat to the imager.
Look Up!
- sullij1
Dan, thanks again for allowing the comparison and the use of the filter. It was a pleasure.
Look Up!
If you're up for it, next up we can compare straight through to diagonal. I'll place the order.
Okay, one order placed for an LS18CaKMDs2. Rikki says three months. Not holding my breath on that time frame though.
EDIT: It ended up taking five months from initial order to final shipping.
HI Sullij,
OK
You had asked if I build K-line filters. I have make filters from K-line to CA2 at 8542Ang.
Before I go into the different designs, there are a few things about viewing K-line (or H-line) that should be pointed out.
1) The color of the sky makes a difference. The bluer the better. Take the same filter at sea level then take it to 8000 ft., the higher elevation will show much more contrast. Where I live you get a lot of haze or the sky looks white. If you can block the sun with your hand and the sky around the sun is not blue then the view will not be as good as it could be.
2) AR’s, if the scope has a broad band AR (BBAR) or the eyepieces do, this could drop the contrast. In the BBAR design, they are designed to keep the reflection down from about 400nm to 700nm. The problem is that the TIO2 that is commonly used as the high index layers absorbs really well below 410nm. The more surfaces the less contrast. A simple ¼ wave MGF2 will do better (unless the AR is designed for the shorter wavelengths).
3) The type of scope. The most common scopes today are the F/7-8. If you are doing a ray trace for their designs you will find that they are probably not ¼ wave at K-line or even close. With these scopes you will want to keep the magnification low to keep the image sharp. To improve your image the best thing would be to stop them down in half. There was a reason that the old scopes where F/15. They have higher contrast and can be corrected easier. It’s true the point where the blue light and the red light come to focus is not the same place but the image of both wavelengths will be better.
4) The simpler the better. Air spaced doublets are your best for K-line (unless you can afford an Aspherical objective). Also keep away from cemented objective lens they will fail over time when used as solar scopes.
5) Resolution is a function of wavelength. So a 50mm K-line scope will have the same resolution as an 85mm scope at Ha.
6) The difference in design of the two. The Daystar has two different K-line housing. The standard tiltable K-line is nothing more than two 10Ang blockers and an ITF. So it went AR, 10ang, BG25, ITF, 10ang, BG25, AR. Del would call this a 5ang filter but it was really not. But it does work, the plage was there and you could see prominence sometimes.
The etalon based filter was the other design. At K-line it takes much more temperature to move the bandpass. So unlike Ha the temperature control is less critical. The other advantage is the bandpass are broader so tilting can be use easier. I did put some etalon filters in the tiltable housing but added a strip heater and temperature controller to have more control of the bandpass.
Ok, the design for the etalon based filter would be AR, 10ang,(sometime BG25 and UV Polaroid )etalon, ITF, BG25,AR. You would need to use the UV Polaroid when the thickness of the mica was not a ½ wave plate or the next peak was not outside the blocker. This is because the mica is birefringent and will have two peaks. One for the different indexes on the different axis.
It should be noted that the UV Polaroid material we used is no longer made. So the ones I make need to be ½ wave plates to keep the HW as narrow as possible.
7) The F ratio, the main problem is the concentration of heat. The standard Daystar oven uses a Delrin plate on both ends against o-rings to hold the optics under pressure. I have seen where a 100mm F/15 melt the Delrin in the front of the filter. Whereas F/20 did not hurt the Delrin. This was the limiting focal ratio that we would use.
8) The Lunt design looked like it uses a single cavity bandpass. But you could use an etalon also. The specs wouldn’t have to be very tight to make a 2.5Ang peak. Since I have not taken one apart I will go with what has been posted. So you have your bandpass , the blue glass will block anything to the short side. Now the long side, a bandpass at 393.4nm is going to have another bandpass somewhere in the green. If there is no ITF then you would need to block this next peak. It was posted that it looked like there is some KG glass. KG glass is good for absorbing the IR. One problem is that it is soda glass. This type of glass absorbs water. So over time it would fog out this may or may not be a problem. So they are blocking till the KG glass can take over. The yellow glass is there to make the filter dimmer and help with what the blue has blocked. It does not look like this filter design is blocked as well as the Blocker/ITF design but is probably good enough. I could be wrong, they may have an ITF, am sure someone will point it out if I am.
9) LIABILITY: With my company and the old Daystar we ever said that K-line was a visual filter. To be safe it was always a filter for a camera. And that is how they were marketed. We used them at F/20-F/30 which keeps them dim. I’m not saying that it will hurt your eyes at F/6 you just need to keep the transmission low just to be safe. Unlike Ha where it can be brighter I think you would want to keep the blue end of the spectrum dimmer just to be safe.
OK,
Going through your questions, some may have been answered already.
I would disagree with Daystar about using F/15 unless I was using a Baader K-line filter as a per-filter.
With K-line you want to keep the heat down.We would not use any ERF and only use an 80mm CA.max. You would be hard pressed to find a blue glass that would work as an ERF larger than this. By using Baaders K-line filter as an ERF just in front of the filter is not a bad idea. Your main problem would be the heat building up inside the scope as your lost of resolution of the image.
Lunt uses smaller blockers then Daystar style. It is much cheaper to use a 15mm blocker over a 38mm one. But if you need to replace the Lunt filter changing blocker in the Daystar style will cost less. Now with this design, you are fitting the suns image through the smaller blocker to save on cost. But like a have said before if you have 100mm of light and you compress it to .2” compared to 1.08” which do you think is going to be more intense. It’s the same amount of energy just spread out farther at the longer F/#. See how long you could hold your hand in the 100mm F/6 beam; this is what the Lunt filter is working with. A standard blocker is speced at 50C, I have seen them run at 70C and last year’s when being used a couple times a month.
So the Lunt design is to run them hard and expect the filter to be used once an awhile.
The IR blocking in front of the filter is not that important. There is far more energy in the blue end of the spectrum then the IR when it comes to heating the filter. So I’m not to sure why Daystar says to have an IR blocker or solar film in front of the filter. (This goes back to blue filters move less with temperature)
The next question was what type of scope is best. If you where making a custom scope, you would make it a doublet with both elements made of BK-7 and air spaced and design it for K-line.
Since most of us don’t have this, keep to F/10 and up and keep it air spaced. Most scopes are corrected for somewhere near Na. and try to cut out anything shorter then 400nm.
You had a question about exposure. You can always make the filter dimmer by adding light yellow glass before the camera.
Internal reflections, The Lunt design uses tilting to try to keep the reflections down. This does not always work.There should not be any double images visibly. If you are imaging and get the exposure longer for a prominence then you may start to get problems. The other place they can come from is if an element does not have an AR on it. I am not a big fan of tilting elements. Working with the blue end of the spectrum does have the advantage in which you can cut down the internal reflections with dark blue glass. (BG25). This does not work at Ha, putting a red glass between two mirrors does not do much for the internal reflections.
Your other question was about using a filter at F/25, 12 times a year 2 hours.
This is not going to do any damage to the filter. First, K-line blockers tend to last longer than Ha blockers. I think it is because the layers are thinner. I have seen K-line filters last 10 years but none shorter than 5 years.
What is the best K-line filter? Well a hard coated 1 ang bandpass would be everything an amateur would need. The problem is the cost would be high.
Well, the Mica etalon is limited to around .8Ang -1 ang. but 2 ang is a nice bandwidth to work for. This is cause by the coating material. At 410nm you can get down to .25Ang but below this the high index absorbs too much. So to keep the transmission up you need to drop the reflection on the mirrors.
The Lunt design, I would keep to about 50mm and use the longest focal length that still fits the full disk through the filter. If you plan to use a 100mm F/6 expect the filter to be replaced in a couple years. If they have a 5 year warranty make sure you send them back for repair.
Sorry if this was a too long but I’m sure there will be comments.
OK
OK,
- sullij1
Mark,
WOW, oo00oo, WOW! I am near speechless, I know I have probably not been your favorite poster in the past and I am truly grateful and humbled by you taking the time and going to such great effort to take the lot of us to SKOOL!
I know I feel schooled in a good way.
Your experience and knowledge in this area and you willingness to share is appreciated by many at this point, I am certain! It is by me I assure you! I have saved your comments to my knowledge base folder as truly I feel I will not find a better answer to my questions in the future. I am certain I will refer to your comments often.
You were not long winded, what you were is very precise in you answer and I am certain it is going to help me and many others in this community as we work to better our CaK instruments and help us get the most life/use out of our equipment.
I for one am in your debt! Thank you Mark!
Kindest regards,
Joe
Kindest regards,
Joe
Look Up!
- sullij1
Finally, the engineer guy who could really shine some light (no puns intended) appeared.
1 karma point awarded. I would give you 5 if I could.
Look Up!
- sullij1
I would be a fool to say no! I am at your service! U-R-DA MAN!
Look Up!
Hi Mark
thank you so much for that wealth of information
Some fantastic info there Mark, many thanks 8) Alot for me to think about and play around with
Yep, agreed Mark, a very valuable post. I read it, and read it again.
Thank you for al this information.
Gay
Gay
- sullij1
I hope somebody refers Pedro to Marks post, I know he has had serious issues with his Cak Modules corroding. it MaaaaY help him.
Look Up!
The 5" Meade AR5 i'm talking about is not really bad for Cak, just the worst performer of the 3 refractors that I own...
http://brierleyhillsolar.blogspot.co.uk ... ngths.html
- solarchat
- Site Admin
- Has thanked: 83 times
- Been thanked: 1317 times
the bigger the aperture the worse the CaK image? Id have to disagree on that one....
or did you mean the worse the Chromatic Abberation? Oh, sorry. nevermind. acronym confusion on my part...
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Atlanta, GA USA
Thank you for your comments.
From the bandwidth view F/10 doesn't matter. The bandwidth doesn't change that much from F/10-F/25 with broad filters.
From a deep of field view, then the longer the focal length the more room you have to be in focus.
Larger scopes,
The real disadvantage with larger apertures is that you are heating two different types of glass with different index of expansion. It may take a while to come back to 1/4 wave.
I had this question from a guy that has a 12" F/12 refactor.He wanted a telecentric so he could use it full aperture. I was concerned with what he wanted to do. I call an optical shop that I knew and asked them. They told me the problem with the different expansion rates and really doubted that it would ever stabilize. They suggested to stop the scope down and not take the change of damaging the objective. This was for Ha. But most of us don't have 12" refractors.
I can't see any problems with 6" scopes. We have used them for years but for K-line just to keep the heat down, I would add some BG25 or a Baader K-line filter or a bandpass per-filter before your K-line filter.
I wanted to add what I forgot on my other post.
You need first to be able to see K-line. The older you get your eye start to yellow and will filter out the blue. This will make it so you will be unable even to see K-line.
Mark W.
Larger scopes,
Mark W.
- sullij1
Most of us here are more concerned with what our cameras will see and how the camera sees from an image gathering standpoint. I would venture to say that 80 to 90 percent of us that can afford a CaK filter are past the age that visually seeing Cak is even a consideration. Just speculation on my part. Our concern is imaging.
Look Up!
Yup, almost no one uses CaK modules for viewing! However, now that you've conveniently brought the subject up, I might as well report my rough unscientific findings on that subject.
For ASAE I put a Lunt CaK module on a scope for viewing. I called it the “Calcium Challenge.” People in their age 20s and 30s reported seeing quite a bit of detail including filaments, sunspots and plage in sharp focus. None of them reported seeing any proms though. The age 40s, 50s could generally only see sunspots and plage in soft focus. The age 60s could see only a featureless disk with limb darkening. The age 70s and up could not see anything at all, not even a purple blob.
That is so true, your challenge is right on. Then you get your cataracts taken out, and you can see K-line again.
Since where more concerned with cameras. Has anyone every uses one of those Sony UV video camera they sell? I've only seen them in adds.
Mark W.
Mark W.
- sullij1
Ok class let’s review:
First let me start by saying this is not the conclusion to this experiment, you all saw Astrodanco’s generous offer and my theory on the diagonal mirror causing the weird reflection. Further we have only evaluated a few scopes and more can be done. With that in the open:
For anyone considering purchase of a CaK unit like the Lunt diagonal, Lunt straight through or Coronado mod’s like Mark Townley’s here are a few things to consider:
Markthis pointed out
2) 2) AR’s (anti reflection), if the scope has a broad band AR (BBAR) or the eyepieces do, this could drop the contrast.
3) The type of scope. Stop down faster scopes to F10 up to F15. There was a reason that the old scopes where F/15. They have higher contrast and can be corrected easier. “Keep to F/10 and up and keep it air spaced. Most scopes are corrected for somewhere near Na. and try to cut out anything shorter then 400nm.”
4) The simpler the better. Air spaced doublets are your best for K-line.
5) The F ratio, the main problem is the concentration of heat. Fast scopes create more heat on filters be they heat rejection filters or the primary. So F6 very hot. F10 or more, are much cooler. Easier on the filter components in general.
6) It was noted “KG glass is good for absorbing the IR. One problem is that it is soda glass. This type of glass absorbs water. So over time it would fog out this may or may not be a problem.” So if there is KG in the train and you start having fogging problems this could be the culprit.
7) If you go over F15 consider a prefilter prior to the primary filter like a K-line or BG25, no bigger than 80mm to prevent chromatic aberration (CA)
8) Working with the blue end of the spectrum does have the advantage in which you can cut down the internal reflections with dark blue glass. (BG25).
9) “Using a filter at F/25, 12 times a year 2 hours. This is not going to do any damage to the filter.”
10) “If you plan to use a 100mm F/6 expect the filter to be replaced in a couple years. If they have a 5 year warranty make sure you send them back for repair.”
11) Disadvantage with larger apertures is that you are heating two different types of glass with different index of expansion. It may take a while to come back to 1/4 wave.
12) Try and keep to the manufactures aperture specification but it is said “I can't see any problems with 6" scopes. We have used them for years but for K-line just to keep the heat down, I would add some BG25 or a Baader K-line filter or a bandpass per-filter before your K-line filter.” So if you don’t want to stop down that 6” F10+ use prefilters on the diagonal/filter end.
13) The scope we tested that delivered the best result was the Celestron 102GT F10 (or its clones under skywatcher and othe brands).
14) Others report that theTal100R @ f10 gives really nice contrasty images, Celestron 80 ED, Borg 76 F/10 apo.
15) The Explore 102 APO, the Meade 127 and other fast APOs work but lack contrast, place a load on the filter and require more processing.
Bottom line-F10 + will work better for you giving more contrast and increasing the life of the filter components.
This is a summary so far, If I messed something up – say so, I have pretty thick skin. Please continue to expand the image comparisons, APPLE to APPLE and report scopes that are delivering well in the K-line.
Hope this thread helps those in the solar community considering a K-line filter figure out where to put their money.
Look Up!
Thank you Joe
for that sum up
for that sum up
So for many reasons some scopes work better than others, just trying out a Cak filter for the first time so I figured I'd add these pics to the thread..
AR102 f/6.5 Air-Spaced Doublet does not seem good for cak,
Celestron 102GT F9.8 with a .5x reducer a lot better image, for the price this scope is awesome.
Celestron hd150 stopped down to 110mm so F10.9 with .5x reducer
Couple days later
Celestron hd150 F8 with .5x reducer
Lunt 152 F6 with .5x reducer
Couple days later..
Lunt 70ED
Couple days later
Couple days later..
Lunt 70ED
Hmm, the LS152 looks best to me.
It's funny though how good that C102GT is when you consider that the whole thing, computerized mount and all is (or was) less than $200 at Costco. Such an amazing deal.
- sullij1
Looks to me like the Celestron 150 stopped down and the Lunt 152 are equals. The C102 still shines. What CaK filter was used?
Look Up!
- Been thanked: 4340 times
I agree the C150 with the aperture mask looks pretty good.
I have used my old Celestron C102 f9.8 scope for WL, CaK, and Ha and have found it to be a good performer. I picked up a used CR-150 in the fall, and have not had time ot use it much, but I just picked up the focuser assembly for my machinist today (had to modity the focuser to allow more in-travel...just a bit short of focus with the B1200CaK and Lunt soalr wedge) and hope to try it on WL and CaK the next clear day. I may even try it with the PST mod.
Thanks for posting...looks promising
I was using the B1200CaK also.
Honestly what I got was not the best to compare since it was various days, but I kinda agree the stopped down hd150 got the best image but can't tell if stopping it down really changed anything since it was a different day, the lunt152 got similar results, with the 102GT vary close to them. The ar102 and lunt70ed were disappointing..especially the 70ed as I wanted to use it for cak so I'm going to try it again to make sure..
I'd be interested seeing if any of your results compare.
Hi Eric
interesting comparison. At my place I found it almost impossible to make a fair shoot out if I made it on different days because of the seeing conditions beeing so different
I found this transmission curve and thought it relavent to what Mark is talking about:
I bought second hand recently two iris that can make things easy as far as aperture reduction is concerned.
The Baader solar iris (10 to 113mm) is ideal for reducing the aperture when observing conditions are worse (I will install it on the TV101):
http://www.365astronomy.com/solar-diaph ... p-710.html
The other bigger iris will be installed on the LUNT152 for WL and H-alpha imaging (60 to 150mm).
Baader iris
Hi Derek:
I have not yet received the two iris. Maybe next week. I bought these second hand (cheap price).
I now always image the CaK sun at F/10 with the TV101. I use a 54mm aperture reduction with excellent results.
best regards
I have written an article on my website regarding Nyquists Sampling Theorem, undersampling, oversampling and the implications on solar astronomy. I believe the content is very pertinent here and moay well go some considerable way in explaining why people have been getting the results they have at CaK wavelengths.
http://brierleyhillsolar.blogspot.co.uk ... pling.html
I would welcome peoples thoughts on this.
Thanks, Mark.
Thanks, Mark.
- sullij1
Just to complete this thread, AstroDan did acquire and let me use his B1800 straight through. Imagery was the same except for not having the image reversal from the diagonal. Unfortunately so was the reflection that I noted earlier. As AstroDan noted. It is the reflection coming from the module ERF bouncing off the front objective. No Big still, it can be controlled in post processing.
Look Up!
You can remove that real easy. Look on the barrel on the CaK module, on the side there are allen bolts recessed in, these are the retaining screws for the ERFs (there's 2 of them in series), if you loosen the one nearest the objective end of the module you can alter the tilt of it, and in turn throw the reflection out of the fov when imaging. Seriously, this is real easy to do...
- sullij1
Mark, thanks, perhaps a person may be able to achieve a minimal amount of tilt using that method but the set screws are for spacing and retaining the filter in the barrel. If you remember C Schure and Stephen R both disassembled their filters so we could peek.
If a person were inexperienced, I would not recommend this as the filter could slip and drop against the bottom filter and break.
I may attempt it with my filter when it arrives, if the same problem exists.
Look Up!
