Vixen A80 screw on ERF cell
occamfan
Post by occamfan »
I never like the idea of bits falling off the telescope while viewing the sun,so I thought you may be interested in seeing this Vixen A80 cell.I started off with a Daystar 80mm ERF whose original cell was too large;so I cut down the Vixen dewshield and using bits of aluminium,managed to make this.
It screws on using the original Vixen fitting,and keeps the ERF secure.
Has thanked: 20732 times
Been thanked: 10427 times
Re: Vixen A80 screw on ERF cell
Very impressive peice of kit! Screw on is definitely the way forward, these little nylon screws that some cells have to hold expensive bits of glass on always make me feel uneasy...
Has thanked: 174 times
Been thanked: 618 times
Excellent job, well done!
Pity you can't use it with your next "upgrade" -to the 150mm scope ;-)
(The filter looks very "orange" - Not sure what glass the Daystar crowd use - a red Schott?)
occamfan
Post by occamfan »
The Daystar ERF filters changed colour from red to yellow when they changed their manufacturing process from poured, to drawn glass,as they had quality control issues previously.At the same time they also altered the bandpass characteristics of the glass.
Thanks for that.
It certainly doesn't say much (technical stuff) on their website...
http://www.daystarfilters.com/energy.shtml#
occamfan
Post by occamfan »
Ahhh
Missed that!
Thanks for pointing it out...I understand what they are saying, but IMHO the more of the "Non-Ha" spectrum you block with an ERF the better.
peter drew
Post by peter drew »
Very nice looking job. At least with Ha, if the filter does fall off, the instant damage is to the filter not the eye, as might be the case with a white light filter. A liitle more expensive though!
andreahaku
Post by andreahaku »
Great solution. Very clean and safe ;)
Good job!
florencior
Post by florencior »
Good job, the mounting inside the dewshield is a great idea
Florencio
http://florencior.fotoastronomia.net
Post by swisswalter »
Hi Charles
a very fine job. That is the way to do it :bow:
