Solar Ha imaging and post-processing tutorial
these are all of the great references that our users have shared with others.
Moderator: marktownley
MoonPrince
Has thanked: 7 times
Been thanked: 228 times
Post by MoonPrince »
Recently, I has been studying the technology of solar imaging. The most stunning solar photography is the hairy flame of the chromosphere and the huge prominences of the sun soaring into the sky. The chromosphere actually photographed the Ha channel (hydrogen-alpha emission line) at a wavelength of 6562.8 angstroms. The sun will behave differently in this band than it does in the entire visible spectrum.
Solar Ha photography, need to use a solar prominence mirror or a solar prominence filter to complete, these equipment can also be bought in China, the price of a solar prominence mirror with the caliber of exponential growth, the general 80mm caliber of the solar prominence mirror is about 20,000, is really a very expensive equipment. More cost-effective is a rear prominence filter called QUARK, which can be used with ordinary telescopes and is acceptable within ten thousand yuan. Other than that you need a very high quality black and white camera. The equipment I used for the demonstration is as follows:
Main telescope: Explore Scientific 127CF APO F7.5 Refractor Telescope
Solar prominence Filter: Daystar’s QUARK Solar Prominence Filter (built-in 4.2x Chromosphere version)
ERF Filter: R filter (used to act as ERF filter)
Main camera: Apollo-M MAX (IMX432) monochrome camera
ES127+QUARK+Apollo camera.jpg (359.29 KiB) Viewed 5063 times
The combination of Apollo-M MAX and QUARK can achieve the best focal ratio and the most appropriate sampling rate close to F30, which can be said to be a perfect solution to the problem of excessive sampling rate left over for many years.
Below, I will share all my practical experience from shooting to post processing.
Ha Solar photography tips
Everyone’s equipment is not the same, in the shooting, parameters need to adjust, but the general principle is similar.
1. Exposure, Gain, Format and Histogram
Ha images are far less bright than white light, so we must turn up the gain, ES127+QUARK+Apollo-M MAX combination, Apollo-M MAX set to 150 gain is basically appropriate (HCG open at gain=146), exposure 7-10ms.
At this point, the histogram’s maximum brightness is about 70%. 70% histogram brightness, whether positive or negative color photo effect is good.
In addition, recording RAW16 is better than RAW8, which can give full play to the advantages of the camera’s high full well (full well of 150 gain is 18700e), especially when the sun’s edge and solar prominence are photographed together, and sharp solar surface features and solar prominence details can be obtained at the same time.
2. Eliminate Newton rings
Any camera with a Solar Ha filter will have an interference stripe. This stripe can be eliminated by tilting the camera’s tilt plate. Apollo-m MAX has a big format of 1.1 inches, so Newton rings will appear to have many circles.
First, when we point at the sun, we can see Newton rings clearly out of focus.
Next, use a wrench to adjust the tilt plate at the front of the camera. (Remember to adjust a set of tilt screws, the other two screws should be properly loosened, otherwise the plate will be overstressed and deformed.)
By adding a tilt of 2-3mm in one direction, Newton rings can be completely eliminated. Remember: Newton rings must be eliminated by tilt adjustment, not by flat frame. I’ve tried it myself a few times, and it doesn’t work.
Once Newton rings are gone, we can begin to imaging the Sun
3. Focusing skills
When focusing, it is recommended to select the active region with the most prominent features on the sun. Such an area has more details and features, and it is easy to judge the accuracy of focusing.
Generally, when focusing is fine, and changing areas does not require refocusing. Unless more than 15 minutes, telescopes exposed to sun light may exhibit significant thermal expansion and contraction resulting in changes in focus.
Now, there are some more practical tips:
1) Preview and stretch the image to improve the contrast of the image, which is conducive to judging the focus.
2) Zoom in 150%-200%, so that the details are larger and it is also good for observing the changes in clarity of small details.
3) Create an artificial darkroom by covering the screen with a large black curtain, so that the screen won't has reflection.
4. Photograph each feature area
Not every region of the chromosphere is worth photographing, unless you want to make a full disk Mosaic. Normally, we would operate a telescope and look at the entire surface of the sun, remembering where there are flares, where there are sunspots, where there are prominences. Then record each feature area one by one.
The brightness of the central and edge regions of the sun will be much different, so if you are in pursuit of perfection, you can adjust the exposure time appropriately (it is recommended not to move the gain), keep the maximum value of the histogram is about 70%. Or we trying to save time, we can shoot all areas with one exposure and then lighten or darken them later.
The active areas of the chromosphere change so quickly that even half an hour can make the same area look markedly different. That’s why a lot of masters like to do time-lapse videos, to record the eruption of a solar prominence, and the movement of prominence it’s very impressive. Today we are not going to talk about the complicated gameplay, we only need to understand the core of imaging and processing.
5. Flat frame shooting techniques
I have also experienced many failures in flat frame shooting. If the flat frame is not good, the solar videos that I worked so hard to shoot on that day is basically in vain, and it is impossible to produce a good image. Deeply aware of the importance of flat frame for Ha imaging. There are a few things to note here, if you can get the flat frame right, then the post processing will be very comfortable.
1) After aiming at the sun, defocus more and shoot flat frame video
This is the most natural and effective flat frame shooting method, because QUARK has a high magnification, for my 127APO, I only shot part of the sun, so use the sun as a huge flat field light source.
take flat.jpg (310.47 KiB) Viewed 5063 times
2) Gain is consistent with light frame
The consistency of gain is very important. Subtracting photos with different gain will increase noise, so I have consistently emphasized that only adjust exposure, the gain does not change. Just for when you take flat frame, you can shoot with the same gain. Flat frame brightness can be consistent with bright field, 70% histogram brightness is good . If you want to get 50% brightness like deep sky imaing, that’s fine.
take flat3.jpg (44.71 KiB) Viewed 5063 times
3) Keep the format consistent with the light frame
If RAW16 is used for light frame, RAW16 is used for flat frame. When using apollo-M MAX, use RAW16 for light and flat frame shots to maximize the camera’s tolerance.
4) Shoot 500 frames to make master flat
Don’t use single flat frame as master flat, be sure to take 500 frames stack the master flat, this can better smooth out the random noise of the flat. Flat video at 500 frames is very fast, only need a few seconds.
5) Shoot flat in multiple areas
You can shoot flat in the center of the sun and slightly off. The reason is that when the imaging train aligns with different areas, the distribution of flat frame light intensity will vary due to internal reflection of the optical system, and sometimes the flat field shot by the central area cannot perfectly smooth out some areas. Therefore, more areas will reduce the risk of calibration failure.
6) It is recommended to shoot two sets of flat
One before the shoot starts, one before the shoot ends. This is a better way to avoid the risk of some calibration failures. Because I once moved the Angle of the camera between shots, the result was that the video with the changed Angle could not be calibrated with the master flat.
Interesting question 1: Can the flat field of one telescope be used by another?
Surely not, you might say! But I found that under certain conditions it can.
For example, the flat field of the sun taken by ES127+QUARK+Apollo-M MAX, if QUARK and Apollo-M MAX are removed together, and put them on 80APO F5 refractor, the master flat of 127APO can be used to calibrate videos from 80APO.
80APO without flat.jpg (241.12 KiB) Viewed 5063 times
80APO+QUARK+Apollo-M MAX without flat
80APO with 127APO flat.jpg (236.25 KiB) Viewed 5063 times
80APO+QUARK+Apollo-M MAX with flat of 127APO
Why do I use it that way? Because the field of view of the 80F5 is too large, the defocused sun cannot cover the entire screen.
80 flat.jpg (96.72 KiB) Viewed 5063 times
80APO flat
I can’t use a flat like that, and that’s what it would look like.
80APO with original flat.jpg (237.79 KiB) Viewed 5063 times
80APO with origianal flat
So I have no choice but to find another way make flat. Someone say bubble wrap is good for make flat frame, but I haven’t tried it yet.
Interesting question 2: Can the master flat shot a few days ago be used for the video shot later?
That’s also possible. There are more conditions. For example, the gain should be the same, the camera Angle hasn’t changed significantly, and so on. If the calibration effect of the flat field taken today is not ideal, you can try to use the master flat taken a few days ago to see the effect. If the effect is OK, it can be used.
Ha solar video pre-processing
1. Stacking flat fields
Drag flat field video into AS! 3, select Create Master Frame from the menu and you can quickly stacked the flat field video into a single master flat (it only takes a few seconds).
create master flat.jpg (116.14 KiB) Viewed 5063 times
Export files to 16-bit TIF format.
2. Stack solar videos
1) Import videos
After the import, you can see that the light and shade of the image are not even because we haven’t loaded the master flat yet.
WITHOUT FLAT.jpg (242.95 KiB) Viewed 5063 times
2) Import the master flat
load master flat.jpg (117.41 KiB) Viewed 5063 times
After importing the master flat, check that the image is sufficiently uniform. If there is no problem, we can proceed to the next step. But sometimes it’s not clear what went wrong in the master flat and the calibration is even worse. At this point, the a lot of flats that were taken before will come in handy. You can try several different master flat to find the best one to use.
WITH FLAT.jpg (240.32 KiB) Viewed 5063 times
3) Stacking according to the normal process
The first step is to select Surface mode, Expend mode, noise robust set to 2, and press the Analyse button.
Wait for analyse finished.
To add the APs reference frame, I usually set the size to 104 and the Min bright to 10. If the prominence is not completely covered, manually add several APs.
On the main interface on the right, the output file format is TIF, and the overlay ratio is set to 30%.
Once you’re done stacking, AS!3 will create a folder with the stacked files in it.
Post processing of Ha solar image
Stacked image, there are many kinds of processing software can do post-processing, finally found that IMPPG is best to make invert image . However, the parameters in IMPPG are very difficult to adjust, and it took me many attempts to find the suitable parameters.
Open image in Imppg
1. Sharpening and deconvolution parameters of IMPPG
1) For images taken by Apollo-M MAX, the parameter of deconvolution is generally suggested to use 1. Iterations set 50.
2) Sharpening parameters are based on the seeing. If the seeing is good, set Sigma to 0.5 and turn up Amount to 2-10, it will be very delicate and clear. If seeing is poor, set Sigma to 1 and turn up Amount to 2-20 as needed to have enough detail.
2. Imppg invert color tricks
1) Open the built-in Tone Curve tool
2) Make a simple invert curve
3) After adding two fixed points left and right, drag the middle slider to find the brightness position of the sun’s edge.
4) Increase more sliders, tune the curves of dark and light parts and increase the contrast.
5) The image is saved in 16-bit TIF format.
The most important thing about sharpening: don’t be too violent. Chromosphere is plasma gas, there is no sharp edge, so how to grasp the degree of softness and sharpness, is the embodiment of post-processing skills. At the beginning often will be more pursuit of details, but after some time, we will know how to balance softness and sharpness.
3. Post-color palette in Photoshop
In photoshop, we needs to do is add color and contrast of the image to enhance the aesthetic of the image. The first thing to do is change the mode of the image from grayscale to RGB so that color can be added.
After that, we can start to mix the colors. There are two ways to adjust the sun’s color, one is the Level tool, one is the Curve tool.
Level toning method
The tone of level is very simple and fast, we only need to set the median value the RGB channels.
R=1.6, G=0.8, and B=0.2.
Settings of Red channel
Settings of Green channel
Settings of Blue channel
So we get the color, it’s really fast, and it works really well. Very suitable for beginners, because all values are fixed, no risk of failure. Of course, if you like make image more colorful, you can learn the following Curve method.
Curve toning method
The adjustment method of curve is more test skill, it does not have fixed numerical value, only three points.
First ,we need to add a curve layer. Then select the Red channel on the layer.
The R curve pulls up, not to much.
Make the G curve an “S”, and don’t bend too much.
B curve pull down, a little bit more.
Once the 3 curves are created, the color will come out. At this time, is to fine-tune the curve of the three channel, find the most comfortable color effect can be.
You can then add a new curve layer to optimize the contrast of the image. This depends on the individual’s perception of the image, adjust the curve until you feel perfect.
Color mixing is mostly about personal aesthetics, as long as you feel comfortable and good-looking. I personally prefer to use curves because the color changes are more vividly and the image looks more advanced.
Add photo Information
When we done post-processing, make sure you describes the parameters, equipment, when and where the photo was taken, and the person who signed it. This is tradition, in order to facilitate the people looking at the photo can immediately know the information to judge the quality of the photo, give a like or give some suggestion.
ART-Chromosphere 20211115-1.jpg (417 KiB) Viewed 5063 times
Final image
The final result was amazing when I saw it for the first time. I didn’t expect apollo-M MAX camera with QUARK to achieve such a effect, it seems that this new camera has great potential in solar imaging.
This is my summary of the Sun Ha shooting and post processing of all the skills, welcome to leave a message in the comments section, if you don’t understand some parts. If there is something wrong, please let me know and I will correct it. Some friends say that they want to learn sun Mosaic and some higher level of imaging, I must to make more research and try more times to get enough experience for writing a higher level of the tutorial.
Telescope: ES127CF APO F7.5, LXY80APO F6
Mount: SW AZEQ6, iOption GEM45.
Camera: Player One Apollo-M MAX(IMX432), Apollo-M(IMX174), Apollo-M MINI(IMX429)
Accessories: Daystar Quark Chromosphere, Herschel prism, TV5X, TV2.5X
Has thanked: 18301 times
Been thanked: 17457 times
Re: Solar Ha imaging and post-processing tutorial
Post by DeepSolar64 »
WoW, thanks for the nice Tutorial!
I use GIMP. It's similar to P.S. but different a bit in layout. PhotoShop is almost certainly the better of the two.
MoonPrince
DeepSolar64 wrote: Thu Dec 16, 2021 8:27 am WoW, thanks for the nice Tutorial!
Thank you, James. I didn't try GIMP, I will take a look of it later.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Don't forget that PaintShopPro does as well as those mentioned here and is far-cheaper than PS.
Perhaps this intuitive post could be retained in the "Solar Reference Library" ??
MoonPrince
EGRAY_OBSERVATORY wrote: Thu Dec 16, 2021 12:17 pm Don't forget that PaintShopPro does as well as those mentioned here and is far-cheaper than PS.
Yes, I'm sure many softwares can do same processing :D. I familiar with Photoshop.
Has thanked: 21496 times
Been thanked: 10913 times
Very good indeed! Thank you. I'll leave here for a couple of days for exposure and then move to the solar reference library.
Has thanked: 18489 times
Been thanked: 9066 times
What a wonderful comprehensive guide to imaging :bow2 :bow2
torsinadoc
Has thanked: 1640 times
Been thanked: 878 times
Post by torsinadoc »
Excellent. Thanks for sharing
MAURITS
Has thanked: 2570 times
Been thanked: 5079 times
Post by MAURITS »
Thanks for sharing this detailed tutorial.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
MoonPrince
marktownley wrote: Fri Dec 17, 2021 6:25 am Very good indeed! Thank you. I'll leave here for a couple of days for exposure and then move to the solar reference library.
Thanks a lot, marktownley. I will keep working on solar imaging.
MoonPrince
Montana wrote: Fri Dec 17, 2021 8:58 am What a wonderful comprehensive guide to imaging :bow2 :bow2
It's my first time to write solar imaging tutorial, thanks a lot, Alexandra.
MoonPrince
MAURITS wrote: Fri Dec 17, 2021 2:19 pm Thanks for sharing this detailed tutorial.
Thank you, Maurits. The layout is difficult to do better in forum, I think it might be a little difficult to read.
