Hinode
- Has thanked: 496 times
- Been thanked: 635 times
- Has thanked: 18303 times
- Been thanked: 8982 times
Re: Hinode
I found a couple of threads in the search which may be helpful
viewtopic.php?t=10321&hilit=hinode
viewtopic.php?p=310986&hilit=hinode
- Has thanked: 21147 times
- Been thanked: 10693 times
Re: Hinode
I have one, I dont really bother with it as my mount is aligned properly.
- Has thanked: 4483 times
- Been thanked: 4090 times
Re: Hinode
The Hinode is a great thing for someone who doesn't have fixed stands and a well-aligned mount. During the day, the assembly aligns poorly and Hinode solves it 100%. Anyone who wants to make animations will really appreciate it. I have one myself, but rarely use it. It doesn't have an ideal response to clouds, if the mounting is not aligned, it won't find the sun anymore.
- Has thanked: 9977 times
- Been thanked: 5938 times
Re: Hinode
Hi,pupak wrote: ↑Wed Nov 09, 2022 7:13 am The Hinode is a great thing for someone who doesn't have fixed stands and a well-aligned mount. During the day, the assembly aligns poorly and Hinode solves it 100%. Anyone who wants to make animations will really appreciate it. I have one myself, but rarely use it. It doesn't have an ideal response to clouds, if the mounting is not aligned, it won't find the sun anymore.
That is good.During the day, the assembly aligns poorly and Hinode solves it 100%.
That is bad I did built my one Solar guider and when it encountered clouds my guider just stopped guiding ...It doesn't have an ideal response to clouds, if the mounting is not aligned, it won't find the sun anymore.
ON the other hand ¿ how bad must a mount be aligned in order to loose that fast the Sun ? There are many tricks to get the mount more or less well aligned by marking the floor and not changing the altitude ...
- Petrus
- Has thanked: 1669 times
- Been thanked: 827 times
Re: Hinode
I have one and I love it! For solar animations, it gives a sort of free hand as I do like to use many telescopes and mounts on a nice sunny day. In my mind hand controller is totally useless, I use it with a computer and it works nicely. Hinode has terrible sound effects, but these can be turned off. Reminds me of some old 90's PC games!
Many tricks recommended by Rainer are worth checking up on before spending money on Hinode. I tested marking the ground myself and it offered quite good results. I have to carry my EQ mount every time outside. For me, Hinode allows more carefree and quick imaging without hassle.
~ Petrus ~
Flickr
Flickr
Re: Hinode
Hi,rsfoto wrote: ↑Wed Nov 09, 2022 7:05 pmHi,pupak wrote: ↑Wed Nov 09, 2022 7:13 am The Hinode is a great thing for someone who doesn't have fixed stands and a well-aligned mount. During the day, the assembly aligns poorly and Hinode solves it 100%. Anyone who wants to make animations will really appreciate it. I have one myself, but rarely use it. It doesn't have an ideal response to clouds, if the mounting is not aligned, it won't find the sun anymore.
Here I present the RS-ol_guider. I developed that one in 2017. It worked quite good with an error of about 30" arc seconds if I remember well.
On the left side is the Sensor and on the right side the Arduino inside a box and the silver phone cable goes to the ST4 plug for my equatorial mounts.
and below 2 videos of the efectivity of this guider. This are time lapse videos and the guided time was around 75 minutes
- nicspenceryork
- Has thanked: 6286 times
- Been thanked: 1407 times
Re: Hinode
I have the Hinode Solar Guider and have found it useful. It is easy to use, accurate and makes animations easier to do. I choose to use it without a laptop.
Yes it's expensive but, if you can afford it, it reduces at least one of the potential frustrations of imaging!
If you've already tried solar tracking with your mount accurately aligned and think the guider might further improve the accuracy then it could be worth the investment. I'm not experienced enough with equipment to know whether the people who don't need to use the guider have a very high quality mount which is so accurate an additional guider wouldn't be needed. Mine is a Celestron AVX which 'tracks very well for quite a while' but I'm guessing wouldn't track as well as a mount which cost many thousands and therefore this guider, in my situation, helps.
Nic
Nic
Re: Hinode
More or less yes, but do not forget the Sun continhously drifts in declination.alessbonsai wrote: ↑Thu Nov 10, 2022 7:41 pm So if I can do a good polar sighting, I could do without the guide
For example today it drifted in 1 hour ~ 41" arcseconds ...
From Sunrise to Sunset in my place it was in 11 hours around ~ 7' 31"
This movement is not constant as getting nearer to the Winter equinox on 21st of December it is only ~ 11"
