There was a glimmer of unobstructed Sun through my upstairs window between 13:40 and 13:50 today. I took a small number of videos, from which I decided to stack three frames. This was the first time that I tried my 90mm aperture 910mm focal length Sky-Watcher refractor (with foam board SHG) for a wavelength other than H-alpha. Since the telescope is already around f10, I decided not to mask the aperture any further. It seems to have produced quite good resolution, despite not perfect conditions. It's not as good as what I've achieved previously with my more permanent setup using a 72mm aperture mask (and 720mm focal length), but that was shooting outdoors in the summer (and with more time to acquire data).
The tree-shaped protuberance on the left side is quite impressive. See some nice full disks from Pedro taken on the same day using traditional methods: viewtopic.php?t=38879
Ca-H SHG full disk image with 90mm refractor -- Nov 25
- Has thanked: 48 times
- Been thanked: 1543 times
Re: Ca-H SHG full disk image with 90mm refractor -- Nov 25
Looking back at my Ca-H images from the summer, the image below is probably my best result, taken on a day with very good seeing:
Ca-H SHG image. 720mm focal length, 72mm aperture. 2400 l/mm grating. 13x sidereal scan rate. Stack of 9 frames (out of 24).
The image comes from this post: viewtopic.php?t=37438.
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Nice detail in the disk and in the prominences,you have given me the incentive to try my 90mm 900 focal length achromat with the Sol'Ex next clear sky I get.
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
The 90mm f10 works pretty well. I'm using it now because it's actually quite light so easy to move around indoors (!).
- Has thanked: 21000 times
- Been thanked: 10625 times
This is an excellent set Douglas!
- Has thanked: 18146 times
- Been thanked: 8947 times
Incredible images Douglas, not only filaments but now prominences as well
I bought my first beginner hand held spectrometer last week. I have been looking at every light bulb with it and this weekend at the cloudy sky. I could see clearly the sodium doublet, hydrogen beta and iron. I was struggling to see the Halpha line but I did see it for a moment when the Sun came out a little, the sky does seem to need to be brighter to see this one. It is absolutely fascinating little toy, an early Christmas present.
The handheld spectrometers are great. As I recall, you can point directly at the Sun and the lines really jump out. If you have one of the fisheye lenses that come with the ZWO cameras, I think you can put this lens right up to the eyepiece of the spectrometer and record the spectrum with the camera (monochrome is easier).Montana wrote: ↑Sun Nov 27, 2022 7:50 pm I bought my first beginner hand held spectrometer last week. I have been looking at every light bulb with it and this weekend at the cloudy sky. I could see clearly the sodium doublet, hydrogen beta and iron. I was struggling to see the H-alpha line but I did see it for a moment when the Sun came out a little, the sky does seem to need to be brighter to see this one.
Another cute spectrometer experiment is to drop some salt (sodium chloride) onto a candle or the gas hob and the sodium doublet is super bright. Kitchen science!
Thanks for that tip, I didn't realise you could shine it at the Sun (don't want to blind myself). I'll definitely try the salt on the gas hob tonight, the Hubby already thinks I am weird so it won't come as a surprise
I had great fun this evening while the Hubby was cooking tea, it was fabulous, the sodium line is amazing!! I really enjoyed myself until I got told off by the Hubby for making a mess. Tea was lovely so I can't complain
I tried the spectrometer on our candles the other night, we noticed that the advent candle had a really strong sodium line in it but the other candles were all an even spectrum. Intrigued a looked up on google 'salt in candles' and found that adding salt to candles makes them non drip. Interestingly, we had already noticed that the advent candle doesn't drip like the other candles. It is so educational, I feel I have made quite a discovery I wouldn't have recognised the sodium line if I hadn't done the messy salt on the hob experiment Thank you!
