AR3615 - X-flare on 23Apr & M-flare on 24 Apr (Singapore) [New Images Added]
- yltansg
- Has thanked: 1460 times
- Been thanked: 1447 times
My CAK setup:
23Apr24 - AR3615 sent an X-flare but I can't see it in this image at 9:38am local time -
Taken single Alluxa filter (tilted in 3D Skybender) - image lacks the usual details - I am still figuring what went wrong
24 Apr - AR3615 emitted a M-flare flare. This image was taken with double-stacked Alluxa CAK filter (without tilting):
From GOES X-RAY FLUX
While I have obtained some good single filter (tilted in 3 D Skybender), I wasn't not able to repeat the same performance on several subsequent tries. I am getting uneven illumination and bright cones of lights in the image. Needs to learn more about it.
Enjoy and do give me your comments. Thanks
Alfred
Alfred
- Has thanked: 17996 times
- Been thanked: 17152 times
Re: AR3615 - X-flare on 23Apr and M-flare on 24 Apr (Singapore)
Very nice CaK resolution and contrast. Professional class work Alfred!
- Has thanked: 21003 times
- Been thanked: 10626 times
The second cak image has turned out well Alfred. The first one looks like the tilt is completely wrong to me, excessive tilt infact, uneven illumination is the same as when a ha etalon is tilted too much. The cones of light also imply excessive tilt. I have found there is not really much need to mess around with the tuning too much once you have found the onband position, just a subtle tweak between observing sessions.
- yltansg
Dear Mark,marktownley wrote: ↑Sun Mar 24, 2024 5:02 am The second cak image has turned out well Alfred. The first one looks like the tilt is completely wrong to me, excessive tilt infact, uneven illumination is the same as when a ha etalon is tilted too much. The cones of light also imply excessive tilt. I have found there is not really much need to mess around with the tuning too much once you have found the onband position, just a subtle tweak between observing sessions.
Thank you for your comments. I am very glad I had a good first light. I would need more time to play with the tilting
Alfred
- OlegLviv
- Has thanked: 933 times
- Been thanked: 953 times
Nice but why do you not write your equipment?
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Mounh: 2xSky Watcher AZEQ6
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
- Has thanked: 9404 times
- Been thanked: 6219 times
Great image of AR3615, Alfred. You have put a lot of work in tuning your setup and the results show it.
- Has thanked: 6389 times
- Been thanked: 7449 times
- Has thanked: 306 times
- Been thanked: 300 times
Great
Celestron C8 telescope Celestron C6 telescope Altair 80mm APO refractor Altair 60mm APO refractor Celestron Nexstar 4se Lunt 40THa/B600 H-Alpha Solar Telescope Sony Nex5 ZWO 130MM ZWO 290MM Altair Hypercam 183C Pro QHY5-III 178 Mono Celestron AVX mount Skywatches AZ-Gti mount Celestron StarSense ZWO SeeStar S50 smart telescope
- Been thanked: 5019 times
Alfred:
Beautiful images.
Thanks.
Beautiful images.
Thanks.
- Has thanked: 3115 times
- Been thanked: 2221 times
Excellent results Alfred. Just a matter of time with the perfect tuning.
Triband C9.25
H-a: 1-2 Lunt40 rear mounted
Cameras: imx432 + imx462
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 1923 times
- Been thanked: 1365 times
Very well done
Rich
Lunt 60mm SS, Daystar Quark Chromosphere,
Antlia wedge,Lunt wedge
- yltansg
Dear OlegLviv,
Thank you for asking. The equipment used in that session:
A 15 year-old 6CR achromat refractor (bought used) with re-spaced objective lens optimised for CAK imaging. It is fitted with a Calcium Solar filter system comprising 2 Alluxa 0.14nm Ca K filters. Camera - IMX290 Mars-M USB3.0 Mono Camera.
Alfred
- yltansg
Thanks, Franco. I am still learning, through trial-and-error and advice offered by friends how to optimise the performance by the tilting of the filters.
Alfred
- yltansg
Dear Kevin,
Thanks for your kind comments. At this image scale, I can replicate great results without tilting.
Alfred
- yltansg
Hi Dennis,
I wish there is a inexpensive way to measuring on-band tilt instead of tilting by trial-and-error
Alfred
There is Alfred and you can do it already...
When the image is on band it has the highest contrast, ie the 'bright features' are at their brightest and the 'dark features' (reverse granulation) are at their 'darkest' - the image has the highest dynamic range. You can see this visually on the first 2 images, but you can also measure this using capture software (firecapture for example) - just look for where this histogram is at it's widest. After a while you will be able to do this visually without the histogram when you know what you are looking for.
It should only be the primary filter (the one closest to the etalon) that you do this with. The secondary filter (closest to the camera) should be tilted enough so that the reflected ghost image is a couple of degrees out of the field of view. The latter is easy to do by increasing the exposure time until the 'ghost' image is revealed.
- Has thanked: 18146 times
- Been thanked: 8947 times
- pedro
- Has thanked: 14 times
- Been thanked: 6766 times
Great HR CaK image Alfred
Pedro Re'
- rigel123
- Has thanked: 8705 times
- Been thanked: 8961 times
That 2nd image is simply crackling with action!
- Has thanked: 65 times
- Been thanked: 4470 times
Really sharp images Alfred and the second shows so much detail
It will be good to see how the setup works with more tuning adjustments!
- Has thanked: 409 times
- Been thanked: 285 times
Love the contrast and detail of the second image.
Like your viewing location, very little concern about tree-tops :-)
Thanks for sharing!
Wayne
Thanks for sharing!
Wayne
Lunt LS50THa, B600, single stack
William Optics Z61, Baader solar film filter
DayStar Quark Chromosphere, w/1.25" ZWO UV/IR filter
William Optics Z81
ZWO ASI178MM
William Optics Z81
ZWO ASI178MM
- KMH
- Has thanked: 665 times
- Been thanked: 788 times
Alfred,yltansg wrote: ↑Sun Mar 24, 2024 10:35 pmDear OlegLviv,
Alfred
Is there any filtration other than the two Alluxa filters (like a front-mounted ERF, or something analogous to a wider bandpass blocking filter)?
Thanks,
Kevin
- Has thanked: 2504 times
- Been thanked: 4929 times
- yltansg
Dear Mark,marktownley wrote: ↑Mon Mar 25, 2024 5:31 amThere is Alfred and you can do it already...
Thank you very much for a detailed and yet easy-to-follow instructions. I hope to post good results from a properly tilted DS filter system.
Alfred
- yltansg
Dear Kevin,KMH wrote: ↑Mon Mar 25, 2024 7:19 pmAlfred,yltansg wrote: ↑Sun Mar 24, 2024 10:35 pmDear OlegLviv,
Alfred
Thanks,
Kevin
I have a blue filter installed at the front of the 6CR. It is from a friend. Unfortunately I don't have the specifications of this glass.
Alfred
- yltansg
Thank you, James, Mark, OlegLviv, Franco, Arnedanielsen, Xinghai, Eric, Dennis, Kevin, Cybermayberry, Alexandra, Pedro, Warren, Brian, Wayne, Maurits for your kind comments.
I have many fair images from the same session. I have added 2 more images for your viewing pleasure.
AR3614:
Is that a thin light bridge tunneling through the sunspot? I am always amazed by formation of straight lines on the Sun.
AR3619:
For you to have a sense of where these images are, here is the solar disk from Spaceweather.com. Credit: SDO/HMI
Pleas do a right click to enjoy the images in full resolution.
Alfred
AR3614:
AR3619:
Alfred
Re: AR3615 - X-flare on 23Apr & M-flare on 24 Apr (Singapore) [New Images Added]
Excellent addition Alfred
I see white dots in the penumbra of the first additional picture. I wonder what they are?
- rigel123
Great additions Alfred!
- yltansg
Hi James,DeepSolar64 wrote: ↑Tue Mar 26, 2024 1:57 pm I see white dots in the penumbra of the first additional picture. I wonder what they are?
Besides imaging AR3615 I was also observing AR3614 from 8:08 to 8:37. The "white dots" starting forming before 8:14 am and became more pronounced at 8:18am and there went away at 8:37am. I have shown the images taken from 8:08 to 8:37am.
There was no white dots on the penumbra at 8:08am
The image below shows the penumbra at 8:14am (left one) and 8:18am (right image). At 8:14am white dots were seen left image. More white dots were seen on the penumbra at 8:18am. You would need to do a right click to see the full image.
And white dots totally gone at 8:37am
I don't really know what they are. I thought it may be a light bridge. Anyone know what they are?
Alfred
Maybe Alexandra or Christian may have an answer for us.
Nice additions Alfred, I believe the bright points you are talking about are called penumbral grains, and represent material welling from deeper within the sun aligned with the magnetic field lines. There's bits and pieces about them online but not much.
- yltansg
Dear James,DeepSolar64 wrote: ↑Tue Mar 26, 2024 6:26 pm Maybe Alexandra or Christian may have an answer for us.
It would be great to know more about these bright spots/lines in the fibrils getting into the penumbra. That would enhance our understanding of our observations.
I am grateful for the resolution improvement resulting from the 6CR refractor objective lens respacing. It has provided me details never seen before for Calcium-K imaging. As friends in this forum has suggested and guided me to do this improvement, I would also like to suggest forum participants to do the objective lens respacing if they are using a achromat refractor for CAK imaging.
Alfred
- Peterm
- Has thanked: 1825 times
- Been thanked: 1583 times
These are very impressive. Nice to see your set up with the Solar protective shield.
BOSS team: https://www.scienceinpublic.com.au/medi ... ia-release
- yltansg
Hi Peter,
Thank you for your kind comments. The shield is supposed to prevent the 6CR tube from heating up. Recently I received a comment that it may cause the heat build-up within the tube to be trapped in it instead. It is too troublesome for me to remove the aluminum cladding so I am going to keep it since the images are turning out ok
Alfred
- yltansg
Hi James,DeepSolar64 wrote: ↑Tue Mar 26, 2024 6:26 pm Maybe Alexandra or Christian may have an answer for us.
A friend of mine suggested that it may be an Incendiary penumbral filament like the one shown below.
Alfred
