Different Ca-K options, differences?
- Has thanked: 1171 times
- Been thanked: 1360 times
Hey all,
I have HA covered for now. And white light covered for now.
I'm interested in adding Ca-K to my line up.
I'm curious though, what are the differences between these options, or is there really any difference:
Quark Ca-H-line - $1k
Lunt Ca-K module - $700~2k
Baader Ca-K II filter (requires white light filter in addition) - $350
What are the Quark/Lunt systems doing with Ca-K wavelength that a white light setup and baader Ca-K filter are not doing?
I have:
Quark Chromosphere (HA)
Baader Astro Solar Film (White Light) filter
Baader Solar Continuum filter
ASI174MM
Looking for an option to bring Ca-k into the fold.
I have:
ASI174MM
- Has thanked: 17667 times
- Been thanked: 8789 times
Re: Different Ca-K options, differences?
A Baader CaK filter is no good, it is barely faculae on white light. I think it is 80A wide from what I remember. You need 2A wide for decent CaK imaging. A Lunt CaK wedge is the way to go unless you can find a used Coronado CaK PST. I have had a bad experience with Daystar so I can't say anything about that.
I figured there was something that was truly different. So the filter is basically pointless and costly.
Looks like I'll have to pinch pennies to get a good Ca-K filter. Will hold off for now then.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
If you look at my Google+ page linked below you can see some images I made with my Baader K filter and compare it to images taken through a more expensive Ca-K module. The filter is not bad, but as Alexandra points out it has a 80 A wide band so it delivers less contrast and less detail compared to the Lunt module.
If you can then go with the Lunt, but if money matters you may also consider the filter in spite of its limits.
Best.
Best.
Hrm,
Seems the Baader filter really isn't worth while. Just looks like white light with a bit more contrast around the faculae. Not good enough for $350.
I'm curious about the Lunt CaK module. I'm curious how it has a narrow band pass, blocking filter, etc, in that diagonal blocking filter, without an etalon, no power source, no tuning, etc. Compared to something like the Quark CaH which has tuning and all that. I guess I'm curious because CaK is the chromosphere and also ultra narrowband, so why is it different than Halpha for example in terms of only needing a blocking filter wedge and not requiring an etalon and blocking filter and all that.
I'm no expert but both the Lunt and Coronado filters are just filters (with coatings) to achieve the narrow band pass. Nothing special is needed, 2.4A (Lunt) and 2.2A (Coronado) is still very wide when it comes to band pass. Remember the special hydrogen alpha filter is made as such to achieve 0.3-0.7A wide (that is narrow). The Quark CaH filter just works in a completely different way, I think in a similar way to their Halpha filter, but I am sure I read somewhere that it is 5A wide, but then the Calcium H band is very wide (relatively) compared to the others. If you read Christian V's most recent post I asked where his filter was from and it was from filter company I have not heard off but it seems to have done a brilliant job viewtopic.php?f=4&t=22556 . You can also buy Calcium K filters from Omega Bob of Ebay but you really do need 2 to double stack them. My CaH filter from him is 5A wide and not really very good.
You will not be disappointed with the Lunt wedge, it is just point and shoot, no tuning required for this wavelength.
Thanks for the links,
There seems to be so much vague information and very little concrete with photos in the same place. In one spot you can get a great photo and vague information about the equipment. In another, there's charts and read outs on the equipment, but no photos. I get that CaK is more of an imaging wavelength, and I'm not interested in visual anyways as I'm always looking through a camera to do it regardless.
I would just think there's other options other than $1k modules like the Lunt/Quark out there. The PST CaK is discontinued and not available. There are scopes dedicated to CaK from the major manufacturers, but I'd definitely rather have a module design to move between scopes over time.
- DSobserver
- Been thanked: 19 times
Visually à lunt cak filter is impressive!
You can't use high magnification otherwise it becomes too dark but you can easily see the famous structures.
Only bright prom are visually detectable
I use it with a 90mm scope
I remember in the past that visually it was impossible to see something with Coronado one
There is nothing vague. What do you want to know?
- Has thanked: 1 time
- Been thanked: 2713 times
Just a quick input there : the Baader K line filter is not a Ca K filter nor a Ca H filter. As explained by Alexandra, its bandpass is so large that it includes both Ca K and Ca H lines.
Here is a comparision between a K line filter :
and a Ca K filter :
I've got another one here :
http://www.astrosurf.com/viladrich/astr ... -Kline.jpg
http://www.astrosurf.com/viladrich/astr ... 63-Cak.jpg
This being said the K line filter is still useful (compared to green or red filters) for the three reasons :
1) the contrast of the granulation (and of sunspots) increases when the wavelength decreases. In other words, we have more contrast in blue light than in red light,
2)the diffraction decreases (ie. resolution increases) when the wavelength decreases,
3) this is a narrow band filter (8 to 10 FWHM), so there is no more issue with atmospheric dispersion.
Compare for example this image at 540 nm (so called Baader continuum filter):
with this one at 396 nm (Baader K line):
and a Ca K filter :
- Has thanked: 8415 times
- Been thanked: 8161 times
A very informative thread. Thanks guys.
Like all things, you get what you pay for, Marty. I can recommend the Lunt CaK module.
Good comparisons and info Christian.
Thanks Christian, that helps with a lot of questions.
Great comparisons too. It looks like the K-line filter is still better than just a Continuum filter, I can see the faculae better for sure, and the contrast and resolution looks much better. Though, at $350 for that filter versus the $50 I got the continuum for, I think ultimately its better to just put that money towards a Ca-K module that is real, and not just the K-line filter.
- Astrograph
- Been thanked: 46 times
To add my two pennies worth.
The Daystar H Line is as much for visual as imaging. It needs to be used with an ERF. You can use an Astronomik UV/IR cut as this has a window for calcium or a Baader Blue filter. You can't use a Baader UV/IR as it blocks below 400nm. The Daystar works OK even at F8 but really needs a 2x Barlow. You have to be careful with your choice of eyepiece / barlow as the coatings on some block sub 400nm heavily. Some scopes also will not have enough in focus without using a tele-centric (and then you have the coating issue to contend with). The new Baader TZ-3 is known to work well with Calcium but I know the other models don't. The H Line is more blue than the purple of K and does not seem to offer the same sort of prominence visibility as K. Alexandra is right that its bandpass is 5A
The Lunt CaK module is very easy to use with any refractor. The module is a tube that fits inside the focuser. It has a rejection filter on the end of it so you need nothing else. The B1200 version seems to work with everything. You can add a barlow to it but you need to be careful for the reasons outlined above. The APM 2.7x is a good choice as it as nearly 99% transmission at 400nm and works well in the Calcium wavelengths. It is 2A bandpass. You can use it with the K Line as a sort of cheap DS but I don't think its ideal. Proms are visible when you expose just for them.
The Baader K Line filter is alright I think. Its not cheap but it does offer a big contrast boost. You can use it in a wedge (but remove the ND3) or with solar film and also as an add on for the Lunt. One thing to be careful of is getting a bad one. The filter is two filters and if they are misaligned then you get double or even triple images. If you see this, send it back.
Thanks for the info,
Overall, if I ever buy something for Calcium, I will probably go for the Lunt module. It just makes sense and I'm not going to be getting a big ERF any time soon. I'd love to just get a PST CaK but I guess those are super rare these days and discontinued. The Lunt has a massive wait time, but I'd rather get it used anyways from someone getting out of it. We will see. I have a few little filters I'm going to experiment with in the mean time and just watch the market for a while and see if a Lunt shows up.
- krakatoa1883
I agree with Astrograph. I just purchased a Quark H and I found it complements well my Baader K that I keep for imaging granulation as it provides more contrast than Baader Continuum. For me it has an advantage compared to the Lunt module: I can use it not only with my refractor but also my solar newtonian that can be safely used at full aperture. Same with the K filter.
Thanks, Very nice!
Good point about the Quark and being able to use it with non-refractors. Ultimately one day I want a 9.25" SCT. But then again, I don't think I'll ever afford the ERF's needed for such an aperture; especially two separates one for CA and one for HA. Sigh. So maybe I should keep it simple with smaller apertures of 5 inches and call it a lifetime lol. Guess we'll see what comes up for sale first, and for what price, as that always tends to dictate it for me. I don't buy new.
Well, Valery sells large aperture ERFs that have a gap at CaK, WL and Halpha so you only need one
That would be great, if I ever got a big enough scope to warrant it, but for now, I dont' think I'll be venturing over 5 inches for a while. Getting the 9.25", the D-ERF, the calcium module, and the cost to mod the 9.25" with a PST etalon (at the very least) will be like a $5k+ expense. Not quite ready for that! Maybe when I retire!
- Astrograph
The Airylab HaT and the new 235mm D-ERF will allow Ha and WL. Calcium with an SCT is pointless as they are very poor at sub 400nm wavelengths.
Mal for starters the Lunt B1200 wedge should get you good results with your 120mm scope. I have had great success with mine on both an 80 mm f11 scope and a 5" f7.5apo.Don,t worry about the Baader CaK to start off with.
Derek
Derek
Hi Rupert,Astrograph wrote: ↑Sat Jun 10, 2017 3:18 pm The Airylab HaT and the new 235mm D-ERF will allow Ha and WL. Calcium with an SCT is pointless as they are very poor at sub 400nm wavelengths.
SCTs are not so bad at Ca K and Ca H ! They at least better at Ca K than at H-a resolution wise.
With additional corrective optics (special SAFIX or special Barlow) it will be perfect even at Ca K&H.
See here: viewtopic.php?f=4&t=22680
- Astrograph
I can only comment on results with my own eyes Valery. Planetary imagers all over the world suffer with poor blue / UV band images using SCT's. Images are not terrible but they are not the quality of other wavelengths. Corrective optics may help but they are not freely available. You should change that
- Has thanked: 20435 times
- Been thanked: 10243 times
I agree!
I totally agree Rupert. What refractors do you recommend as the top performers in the deep blue (CaK) wavelengths?Astrograph wrote: ↑Tue Jun 13, 2017 10:25 am Planetary imagers all over the world suffer with poor blue / UV band images using SCT's. Images are not terrible but they are not the quality of other wavelengths.
- Astrograph
The issue with most is coatings Mark. By design they pass the visible wavelengths and normally have a severe cut lower than 400nm. Reflectors have a double wammy as the mirror coating is often limited in its reflectivity at different wavelengths. Something like an SCT then has a coating on its corrector. As you know from testing the Calcium H Quark, eyepieces etc with odd coatings make a huge difference to what you see.
I know with LZOS refractor optics that there is something like a 50% loss in transmission at the UV wavelengths but as low as 486nm they are still efficient and way above diffraction limited (0.96 actually). In theory an oilled CaF2 refractor like a TEC would be best because CaF2 is very transparent to UV wavelengths and because of the oilling the optics are uncoated internally so you get max transmission of these wavelengths. There is only coating on the front element.
So basically an oilled CaF2 Refractor that is made properly should be best. A TEC is the only current choice. The only others are older AP and Zeiss APQ's. These makes all acquired the skill to make oilled scopes reliably.
Downside is an APQ is now priced so high its for collectors only. First CaF2 TEC is the 160. Yours for £14K sir.
Mark,
For Ca K and Ca H the best refractors are TOA 130 and 150. All other refractors regardless of manufacturer are poorly corrected at these wave lengths.
If you can use a 6" F/12 achromat, you will be OK with crisp images at Ca K/H. But such a scope is not quite transportable and not easy useable.
Another, best (IMHO) solution is a Marksutov telescope.
Any coating is OK.
Any coating is OK.
- Astrograph
Valery, where is the basis for TOA scopes being so wonderful at sub 400nm? They are just pretty ordinary APO's using ordinary glass. Nothing more.
Any coating is not OK. For proof of this see this wavelength test between the Pierro Astro ADC and the cheap ZWO. The PA has fused silica prisms which pass sub 400nm light better and coatings that are designed to compliment this. The difference is quite obvious.
In any case we are getting away from how this thread started.
- PA - ZWO ADC.jpg (111.21 KiB) Viewed 10364 times
- Has thanked: 173 times
- Been thanked: 615 times
Does it really matter?
The current CCD cameras dramatically fall in sensitivity in the UV.
The shortest wavelength I've been able to record with the spectroscope is just below 3700A.
Rupert,Astrograph wrote: ↑Wed Jun 14, 2017 10:25 pm Valery, where is the basis for TOA scopes being so wonderful at sub 400nm? They are just pretty ordinary APO's using ordinary glass. Nothing more.
Please, no offence. You are not a pro, nor a specialist in the optics as far as I know. But I am.
The basis for TOA scopes being so perfectly corrected is in the design of these objectives. TOA states for Triplet Ortho Apochromat = triplet with equal (close to this) apochromatic correction across spectrum. They are not only corrected for secondary spectrum (common focus for wide spectral range) but they also corrected for spherical aberration for almost entire spectral range they are purposed for. In the ordinary apochromats spherical aberration is corrected only for a single wave length. Usually this is 540nm and near it. In the TOA objectives spherical aberration corrected for ALL wave lengths. Therefore images at 400nm is same crisp as at, say, 540nm and even crisper because of lower diffraction influence.
Similar designs (with widely spaced lenses) are well known for optical designers for a loooong time. The only disadvantage is a poor temperature equilibration with enviromental air. This is a key factor and most designers prefer lower corrected objectives, but with much faster thermal equlibration. Somewhen in a past we have discussed these questions with Roland and Yuri. They too are not fans of orthoapochromatic objectives because of this mentioned above disadvantage. But for a Ca K imaging they are almost a perfect choice in such a size.
Again, for 400nm +/- several tens of nanometers, all coatings are about similar performance +/- a few % in transmission. Of course if an objective consists many lenses with lower transmission in UV, then a final transmission will be about 20% lower - absolutely not critical for imaging there.
Valery.
- Astrograph
Valery. I take a pride in helping people to try and understand the reality of what is out there rather than back up marketing BS. Many things look great on paper. In the real world what is delivered is often nowhere near. That applies to Tak as much as any other. TOA's, regardless of their design strategy set no new heights for performance. Being replaced by customers for something better is not uncommon. I don't dispute that in theory it might be better but there are many designs out there that promise much and deliver little new, if anything. Design is one thing, implementing it is another and doing it consistently is another still. I see this all the time. It is constantly frustrating that something that seems so simple as some shaped and polished glass put together can vary so widely in performance on a case by case basis with the same telescope. I see this because I inspect all I sell. What becomes clear is that who makes it is much more important than how or what it is made from.
I am well aware of your own experience and qualifications with optics. I feel no need to question that. You know nothing about me so please don't insult me. I run a professional astronomy business.
Good discussion chaps.
I've certainly tried all of the CaK options above, and my preferred one is a double stacked CaK PST filter of my own design. If I had to pick from an 'off the shelf' unit I would go for a CaH quark, if cost was no objective I would go with the Lunt B3400 or maybe a custom job from Solar Spectrum.
In terms of scopes i've only ever used 'budget' cheap refractors with CaK and there is significant variance in light throughput (different scopes, same focal ratios, same camera, same day), this can only be glass types or coatings causing the variance. When I reviewed the CaH Quark there was significant variance in brightness visually using different eyepieces. These are just my observations.
As i've become more experienced with my solar imaging i've learned to see the results of spherical aberration when imaging at CaK wavelengths, and, as above there is significant variation between scopes.
I certainly don't have the experience of using the higher end scopes that both Valery and Rupert have, but, being a nerd I do enjoy reading test reports and so I take something from these (and I do appreciate a test report isn't everything!).
For me, in the less than ideal seeing I have a lot of the time, a dream scope for me would be a 5-7" frac and a tri-band (full aperture) ERF, but it would have to cut the mustard at 393nm. To get to that point though I do need to win the lottery!
Hi all,
Just a little update.
I'm tinkering with a Skybender with a 380~395nm pre-filter inside, IR rejection filter on the nose, and two 393nm filters stacked on the camera nose. I used a focal reducer to do the full disc. And I used a 3x barlow for the details. I did some white light too just to compare (white light was done with a baadar solar film & solar continuum filter).
What do you guys think? Close? Or is it mainly just white light that looks like it, but not really calcium?
The skybender itself and the filters:
Hi Marty. One of those 393 filters needs to be mounted internally in the skybender - at the moment all it is doing is acting as an extension tube. Apollo has had some success with these setups in CaK.
The filter inside the tube is a 380~395nm pre-filter. Then the two 393nm filters. Do you think the pre-filter should be exchanged to one of the 393 filters and then just one 393 on the nose of the camera?
I can see through the 393 filters, but I cannot see through the 380~395, it looks like a mirror on both sides when I take it out and look at it.
I would try a 393 on the 380~395 filter, but, if apollo recommends the configuration it is in go with it.
Yea, I'm only setup this way because that's how he suggested it be used. I didn't notice much difference tilting though. I'm curious if putting the 380~395 on the nose with the IR rejection and then putting a 393 in the tilter and a 393 on the camera would be more appropriate?
I'm trying it out as I didn't buy it, just seeing if there are alternatives to the $1k options (Lunt, Quark) since there really isn't a lot of Ca options out there really, compared to HA. Really bummed the PST CaK is no longer made, as that would have been ideal for me I think for cost.
Long term, I can't decide if a Quark CaH or a Lunt CaK BF would be ideal. I think ultimately I will stay within refractors of 6 inches or less for this, simply due to cost of moving into a big aperture SCT and the ERF required, etc. It's just too costly. I can however manage 6 inch refractors. I'm just not sure if the Lunt BF1200 would be best, if I put a 3x or 5x barlow on the 150mm refractor (one day at least), or if a Quark CaH unit would be more appropriate for something like that. I would like to be able to do full disc and high mag with the device. The Quark CaH still seems to need long focal ratios but at least lacks the barlow so I could do full disc with that. But the Lunt is attractive as well. Just not sure what would really be ideal for imaging (I do 1% visual, with a PST, just to look for morning proms basically).
Wow! I think these images are fantastic! lovely and crisp and lots of plage seen around the spots in the centre of the disc. That is impressive! what aperture is the scope and what are the 393 filters?
- Astrograph
Personally I think you would be better off with the Lunt CaK module is you can just use it with no extra costs and it will work. The Daystar CaH will require an ERF of some kind. Although I have used it on an F6.5 scope visually and it looked 'ok' it really needs to be at least double that. An important consideration with the Daystar is back focus. If you add a telecentric then things can be made to work because the focal point gets moved further back. If you want to use it on its own then your scope must have enough back focus to accommodate the Quark and still allow focus. On many Chinese scopes there is not enough back focus (and hence inward movement on the focuser) to reach focus. This is not an issue with the Lunt as it is fitted internally.
Thanks!
Scope is 120mm refractor (Celestron Omni XLT 120; F8.3). The 393nm filters are just 1.25" filters that I received with the Skybender. I'm not sure about their make/origin. Maybe Semrock?
I have no issue with backfocus; I use straight-through, no diagonals, and my focuser is linear bearing and I use assortments of extensions to get focus with my current telecentric barlow in my Quark no problem.Astrograph wrote: ↑Mon Jun 19, 2017 9:21 am Personally I think you would be better off with the Lunt CaK module is you can just use it with no extra costs and it will work. The Daystar CaH will require an ERF of some kind. Although I have used it on an F6.5 scope visually and it looked 'ok' it really needs to be at least double that. An important consideration with the Daystar is back focus. If you add a telecentric then things can be made to work because the focal point gets moved further back. If you want to use it on its own then your scope must have enough back focus to accommodate the Quark and still allow focus. On many Chinese scopes there is not enough back focus (and hence inward movement on the focuser) to reach focus. This is not an issue with the Lunt as it is fitted internally.
Interesting, didn't realize the Quark CaH would need an ERF. I read it just needed the standard UV/IR cutter just like the other Quarks for heat rejection, but beyond that, just had to be at F7 or greater and it was good to go. Unless my understanding is incorrect?
Ultimately I too think the Lunt is the way to go in the long run for CaK for me, if I get to that point. I will keep using this Skybender setup for a little while and see what I can get out of it before moving to something else. I'd love to have both just to compare and see if one really is superior with my setup or not. I like my Quark Chromosphere, but I definitely appreciate the idea of not needing another powered device to manage.
Do you think the B1200 would be a limitation with a 3x or 5x barlow on a 1,000mm scope (120mm aperture, F8.3) using an ASI174MM?
- Astrograph
To clarify the back focus comment. A telecentric adds backfocus. You need a telecentric (not a barlow) to allow an etalon to operate correctly and onband. The Quark Calcium does not have a telecentric as its bandpass is wide and scopes from F8 should be OK. The problem is that inserting the Quark Calcium into the light path uses up what back focus you have. With some scopes you will not get focus. You don't need extensions, you need a scope whose focuser retracts further inwards. This is not a factor with the Lunt as it has a collimating lens inside.
The Quark Calcium has a block in it nose which allows no ERF below about 60mm. Above that you can use an UV/IR cut but a 120mm scope needs some better. A Baader blue filter is best as this passes the calcium wavelength. It is also dielectric so reflects energy. The Lunt needs nothing as its ERF is built into the front of it.
I have used a B1200 (this refers to the 12mm size of the block) with an 800mm scope. That was OK. The diagonal of your 173 is just over 13mm so you would get some vignetting. Just use ROI. Don't wast money on a B1800
Hi thanks, makes sense. The Quark Calcium sounds more fussy than the Quark Chromosphere!
Lunt sounds more simple. I don't mind a little vignetting. Thanks!
Hi to All,
It is nice to have such an extensive post on Ca K observation :-)
As I have been observing in Ca K since the last 17 years, and using a Taka TO150 for Ca K observations for more than 7years, I would like to put forward some information.
- The TOA 150 mm is of top optical quality at 396 nm. I have somewhere on my computer the spot diagrams calculated by Taka at 396 nm. There are simply perfect.
- The AR coating does absorb a significant amount of light. The total transmission (for the six air surfaces) at 396 nm is about 60-70% (I have the data on another computer). This is not a big deal.
- In real life, and this is all that matters, the TOA performs splendidly in Ca K.
Here are two examples of images taken at full aperture :
Please note the structure of the chromosphere "surface". What you see is the solar granulation which appears "inverted" (or in negative) compared to visible light. Please note the size of the solar cells. Some cells are darker than other. There is no noise on these images, only actual solar details.
As for the optical performance of Schmidt-Cassegrain. This optical design does suffer from spherochromatism which degrades optical performance in UV. Here are the Strelh ratio versus wavelength of various popular SC:
Remember that to be diffraction limited, an instrument should have a Strelh ratio greater than 0.8.
In other terms, a SC would need a chroma corrector to perform correctly in near UV light.
In a nutshell, all is a matter of pro and cons (and also cost ..).
Best regards
Best regards
A nice contribution there Christian. If you are able to post the data you have on your TOA150 from your other computers on here I would love to see it
- krakatoa1883
Quark-Ca is short, with its 2" nose it requires only 62 mm backfocus, most refractors will have no problem to accomodate it, mine goes to focus even with Quark inserted in a 1.25" diagonal.Astrograph wrote: ↑Mon Jun 19, 2017 2:18 pmThe problem is that inserting the Quark Calcium into the light path uses up what back focus you have. With some scopes you will not get focus. You don't need extensions, you need a scope whose focuser retracts further inwards.
The Quark-Ca has an advantage over the Lunt module: it can be used on reflectors, in fact a solar newtonian of medium or even large aperture would be a very powerful scope for imaging in Ca-H. Mine works wonderfully with Quark while I couldn't use it with a Lunt unit.
- Astrograph
You are fortunate that it focuses. It is not always the case.
Have you been using your Calcium Quark on a Newtonian with no ERF or are you talking about one with a mirror with no coating?
Lunt also offer a version of the CaK module as a diagonal. Obviously that only suits certain scopes too but reflectors must have ERF's (if they are normal) and Calcium ERF's are rare.
- krakatoa1883
It is a newtonian with the primary mirror uncoated (secondary is fully reflective), it still transmits enough light for Quark. The scope is a f/5 but I use a barlow lens that brings it to f/10.
Enough for imaging or for visual?krakatoa1883 wrote: ↑Wed Jun 28, 2017 6:08 pm It is a newtonian with the primary mirror uncoated (secondary is fully reflective), it still transmits enough light for Quark. The scope is a f/5 but I use a barlow lens that brings it to f/10.
If you mean for imaging what is the equivalent F/D at the camera chip? Remember, that for full resolution realization
one need to use for Ca an F/D 1,67x greater than diffraction resolution for H-a. I doubt that Quark Ca H transmits enough light for such a scale if to use it wih one uncoated mirror.
- krakatoa1883
No problem to image at 3760 mm that corresponds to about f/29 at the image plane (sampling for 393nm). And mine is a 130mm only, a larger newtonian can do even better, the problem is not light, is the seeing.
Wow, a lot about K-line. This wavelength really doesn't sell to many filters. Only the younger people can really see anything normally. I like K-line, in the days of film it worked fine. With the cameras today and processing you can make the image look like it was shot with a narrower filter.
1) refactors are not usually corrected for that wavelength. If it is an air spaced you can increase the spacing to correct for 393.4nm but you loose the longer wavelength. The old MgF2 AR is still the best low cost AR for a K-line scope. Most common AR today used TiO2 as the high index. TiO2 starts to absorbing at 400nm. It is usually not used for UV optics.
2) SCT's you have already seen from a earlier post that they are not designed for 393.4nm. Even in Celestron's notes,they say the scope is corrected to the green line.
3) Newtonian's, should do better. I would keep to a longer Focal ratios.
The main thing I would worry about is heat. You put a piece of blue glass in a F/8 beam and it will get so hot you can't touch it. Do the same with red and it's not a problem.
All that said, Valery is right about using a corrector. It can be made, but one size does not fit all. And you will need to worry about off axis coma showing up.
The different filters you have talked about. The Lunt's is a single cavity, probably with a low index spacer. So it broadens out fast depending on the focal ratio. I would keep it in the F/20-30 range for best contrast.
The Quark uses a 5 Ang HW two cavity filter. It should be used in the same focal ratio also. This HW should show some plage.
The 5Ang filters is soft coated ,so the wavelength will move red with the extra heat. If the 2.4Ang is soft coated then it will move off K-line even easier. So on hot days you may want to tilt the filter to better center the bandpass.
You really need to be close to 1Ang to get that good contrast your looking for in K-line.
This is my 2 cents
Mark W.
This is my 2 cents
Mark W.
One more cent,
With refactors, if you stop them down .This will help with correcting for K-line.
Even 50mm at a F/20 or so, does quite well with K-line. And with these HW's you can get away with using a barlow.
Mark W.
Mark W.
