Page 1 of 1
Omni xlt 120mm and quark
Posted: Sun Jun 16, 2019 12:34 pm
by BertUK
Just testing the water to see if anyone has any advice on using the omni xlt 120 refractor with a quark.
What can i expect to see with the views,do i need an external erf.
Am i better off buying a dedicated solarscope.
Thanks in advance
Mick
Re: Omni xlt 120mm and quark
Posted: Sun Jun 16, 2019 3:52 pm
by marktownley
At f8.3 I would think it would work very well. By far the weakest link will be the stock focuser.
Posted: Sun Jun 16, 2019 4:37 pm
by PDB
Yep, that stock focuser is a nightmare. The scope is very much ok in H-Alfa.
I have the Skywatcher version and replaced the focuser with a Baader Diamond Steeltrack.
This scope has a very short tube. With the very long stock focuser and a 2" diagonal it will be ok. Wit focuser replacement you will need extension tubes.
I used (before my Quarl died) with the Baader focuser, 2 80 mm extensions to come to focus without diagonal. (Only 1 needed with the 2" diagonal)
Posted: Sun Jun 16, 2019 5:24 pm
by BertUK
Thanks for the replies but my questions still arent answered,what views will i get,full disc partial??
Do i need an external erf?
Would i be better off with a dedicated solar scope?.
Posted: Sun Jun 16, 2019 6:11 pm
by PDB
Impossible to get full disc with that scope and standard Quark. The blocking filter only allows full disc view with scopes with fl ~400mm. (I have a 80mm f/6 -> 480mm FL, does not give me full disc either, FL just a tad to long)
An UV/IR (best a 2") in front of the Quark will do. Better a Baader 35nm H-Alfa filter. Blocks more and is cooler that the UV/IR.
My setup was: 2" UV/IR (later replaced with the 35nm H-Alfa); 2w 80mm extension tubes, quark, camera.
For visual: 2" UV/IR (later replaced with the 35nm H-Alfa); 2" diagonal, Quark.
Hope this helps
Posted: Sun Jun 16, 2019 7:09 pm
by marktownley
Exactly what Paul says. Who knows if you will be better buying a dedicated solar scope - what do you want / expect?
Posted: Mon Jun 17, 2019 1:35 pm
by BertUK
Ok thanks for the help,how would the quark perform with a 10" schmidt at 2500mm and a mak 180 at 2700mm,would i need erf,s with these also?
Posted: Mon Jun 17, 2019 2:54 pm
by PDB
For Maks & SCT's you will need a cool front ERF. (Baader, Aries ...) Without it, too much heat will build up in the tube and reflected from primary to secondary mirror. You risc melting (if plastic parts) or secondary coming of (if glued) You can't work with an UV/IT in front of the mirror.
Of course you can use the off-axis erf with a combo quark, but what is the point of turning a big scope into something like a 50 or 60mm scope?
Quality: you will need good seeing, but there are always good moments. Others with the big systems (Valery, Mark, Franco ...) can probably advise on that.
Posted: Mon Jun 17, 2019 8:41 pm
by marktownley
With a big scope like your Mak or SCT unless you live somewhere in the UK with spectacular daytime seeing you won't be getting much use. I'd go with the 120 in the first instance.
Posted: Thu Feb 20, 2020 8:48 am
by daslolo
PDB wrote: ↑Sun Jun 16, 2019 6:11 pm
Does 2" eyepieces help bring details? The quark being 1.25...
PDB wrote: ↑Sun Jun 16, 2019 4:37 pm
What happened to your quark? Daystar fixed it?
These quarks seem fragile...
Posted: Thu Feb 20, 2020 9:06 am
by PDB
The first one: my dealer sent it back to Daystar and they sent me something bach after a few months. (Replaced or new, can't say since they have no serial number. Too costly just to put a serial on it? My dealer took all the cost of sending it back and forth (warranty)
Second one looked ok with good contrast but later started to show strange spots (as if some internal "oil" spil. Probably could get another one, but sending it back to the US and pay import tax again and probably get another lemon. No thanks! Is a nice paper-weight now.
You get what you pay for .... Wel ask Rainer (rsfoto) about his daystar adventure.
