Eyepiece, and focuser for camera
willisobservatory
Been thanked: 5 times
Post by willisobservatory »
I have Lunt 152. What is best eyepiece for this scope?
I have Basler acA1920-155um Ace - IMX174, 1/1.2", C-Mount, 1920x1200, 155fps, Mono. Is there a focuser you would recommend for this camera?
Newbie here, and I so appreciate all your help.
I have the entire Ethos Tele Vue line. I talked with Tele Vue rep and he said Pan Optic 41 would work well with Lunt and my Astro-Physics 175 at night.
He also mentioned Tele Vue Plossal just for solar observing.
Has thanked: 20757 times
Been thanked: 10444 times
Re: Eyepiece, and focuser for camera
Hiya.
Regards eyepeices, i've always found the plossls work best, indeed I use Televue, my favourite is the 15mm. I'm assuming you have the Bf3400 blocking filter? A 41mm panoptic is only going to give just over 20x magnification with the Lunt152, and is going to give a very small disk relative to the fov. Also remember that the 152 is designed for high power viewing rather than full disk, so, if you are using it for full disks you will be getting sub optimal performance.
Regards the focuser, just use the stock, it will be fine. Of course a Feathertouch is the premium choice.
pedro
Has thanked: 14 times
Been thanked: 6686 times
Post by pedro »
I use a Pentax Zoom eyepiece with my LUNT152. It works fine
