Solarmax 60 + BF 15mm
Charon_X
Post by Charon_X » Sun Aug 30, 2020 6:04 pm
I have the opportunity to buy Coronado Etalon 60mm + BF 15mm. Will such a set + refractor give the same image as a regular Solar Lunt / Coronado 60mm telescope? Or maybe we can somehow use a refractor with a larger diameter - maybe this etalon could be given somewhere at the beginning or in the middle of the tube + some ERF for the lens?
Has thanked: 15 times
Been thanked: 70 times
Re: Solarmax 60 + BF 15mm
Post by Merlin66 » Mon Aug 31, 2020 9:01 am
Charon,
I have used an original SM60 mounted on an ED80 successfully for many years.
IMHO opinion it works better than the current SM60II scope.
Highbury Mark
Has thanked: 56 times
Been thanked: 78 times
Post by Highbury Mark » Mon Aug 31, 2020 4:25 pm
It really depends on the quality of the etalon to know precisely how it’ll perform. But paired with a small refractor (there’s no gain using a large refractor as you have to attach the SM60 to the front of the telescope, so it will have a 60mm aperture whatever your choice of scope) it should give you nice views of prominences, and fainter views of surface detail like filaments and active regions. To bring out more surface detail you’d need to add another external ‘double stack’ filter, which would narrow the bandwidth and improve contrast.
TeleVue 85 + Solarscope SF70DS
Tak FC-100DC, Quark Chromosphere, Baader wedge
Zeiss binoviewer, Zeiss OPMI/TV plossl eyepieces
Has thanked: 1717 times
Been thanked: 1719 times
Post by DeepSolar64 » Wed Sep 02, 2020 4:41 am
I have a Coronado SolarMax II 60 doublestacked scope. Overall I am satisfied with it. It's does well visually on low power full disc views. It's performance drops as the magnification increases. I almost never top 50x with it and run usually between 16x and 33x. It does well there. I also have the BF15 blocking filter. So far it has done well and gave no issues.
Charon_X
Post by Charon_X » Wed Sep 02, 2020 6:36 pm
Thanks for the answers. The seller withdrew. I will be taking the new 50mm Lunt.
Post by DeepSolar64 » Wed Sep 02, 2020 6:53 pm
I don’t think you will lose with the Lunt LS50Tha. Good observing!
RKBerta
Been thanked: 2 times
Post by RKBerta » Thu Nov 05, 2020 2:28 am
Charon,
I have an original (around 25 years old) Coronado US made etalon used on 80mm three element Officina Stellare APO refractor with both BF15 and BF30. I also have a 4 year old Lunt 60mm Ha with pressure tuner and BF15. Both are close but I think I get a bit better contrast on surface detail with the external etalon with tilt tuner than the newer Lunt.
Post by DeepSolar64 » Thu Nov 05, 2020 5:40 am
I would love to have one of the US made pre-Meade Coronado etalons to see how they compare with those of Meade Coronado. Many seem to prefer the pre-Meade ones.
