Hello all: does it make any sense to "upgrade" from a 152 mm achromatic refractor to a 130mm triple APO refractor at approximately double the cost ? It would mean sacrificing 1" of aperture for a sharper image, I guess.
Interested in hearing your opinions...
Thank you,
Refractor question
- Has thanked: 9304 times
- Been thanked: 6140 times
- Has thanked: 20767 times
- Been thanked: 10453 times
Re: Refractor question
Hi Franco.
For solar, no, not at all. Quite the opposite.
If you are looking for decent night time yes the apo.
- Has thanked: 17829 times
- Been thanked: 16971 times
Franco,
I don't think it would be worth it unless you choose to use it for nighttime as well. The narrow band filters used in solar usually remove the chromatic aberration of an achromat. If the lens is of good quality I would not sacrifice the aperture of the larger achromat for the smaller APO unless you choose to use the scope on objects outside of the Sun.
I am weighing the Celestron C6-R achromat against the Astro-Tech AT130EDT triplet apo and have came to the same conclusions.
They make nice instruments, Franco. I have their little AT72EDII and it has practically no chromatic abberation. It's a doublet with a lanthanum element mated to an Ohara FPL53 element. Both ED glasses.
SharpStar would be another good option for an affordable ED/APO. They are really nice too.
But if it's just for solar a good achromat is more affordable.
Glad to help, Franco. Good luck with your choice.
