Quark calcium and Evostar 72mm
Has thanked: 9293 times
Been thanked: 6128 times
Post by ffellah »
Hello all: I am considering getting a Quark Calcium H, to be used with an Evostar 72mm. Does anyone have experience with that ? Daystar says it works with f/7 or higher: the Evostar 72mm is f/5.8. I was thinking of stopping it down to 50mm or so to achieve the correct focal length. Thoughts ? Would I get the full disk ? Any suggestions/experience with that filter would be appreciated... thank you.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: Quark calcium and Evostar 72mm
Post by EGRAY_OBSERVATORY »
Hi Franco, I can't vouch for a Calcium-H Quark, but of course much has been said about both Quark and CaH on SC and on the web.
But certainly to have a range of F-stoppers for whichever scope is useful, as today whilst starting imaging from the new mini-obsy, was using my set of such, showing some interesting results. They range from 10mm through to 70mm for the ED80T-CF.
I can say that with my Sodium Quark through the Orion 80ED and the SW ED80, that I couldn't get full disk captures with either ASI-178MM or ASI-120MC-S cameras. I've still got other cameras to trial, but one (Altair GPCAM) seems that Altair have ceased/taken-off the download program which I needed for the new pc. Obviously using one or more 0.5Focal-Reducers may correct to a small extent, but that's another task to try...
Best wishes
Been thanked: 10439 times
You will always get better results with calcium with lower f-ratios. With a camera with large enough chip, yes, you will get a full disk. With that scope I would be using at 40mm aperture.
Your big chipped PGR will give a FD all the way up to 1000mm focal length, have you any other fracs you could use?
Post by ffellah »
Thank you Mark and Terry. I can probably use it also with the Explore Scientific 6" refractor. Still considering the purchase, let’s see how things go.
ffellah wrote: Wed Nov 17, 2021 12:10 pm Thank you Mark and Terry. I can probably use it also with the Explore Scientific 6" refractor. Still considering the purchase, let’s see how things go.
I would probably use it with that scope stopped down to 50mm and the big chipped PGR, you will get a full disk at the 988mm focal length, and at f20 the filter will work with a lot more contrast than with the 72mm scope...
Post by ffellah »
Thank you for the guidance Mark
