Hello ,
the sky is not very usable with these trails that never end, I tried again without the Pst stallion but with the Bf 5mm in front of the camera and the erf in front of the lens.
for the prom it works well, for the surface obviously it is not selective enough.
the Bf coronado must be a few Ä (if Christian Villadrich passes by there he will inform us, I believe 6Ä) wide enough for a coronograph.
in the animation without febry-parot we see shiny dots at the bottom, are they Ellerman's bombs ????
the 2 animations take a long time to load
my sky to start
the assembly of the Bf5
the comparative result unfortunately not at the same time so not necessarily significant raw images out of AS3! with the same number of AP
animation on the surface, no filament but interesting in the spot - long to load
finally comparison of the surface with the Pst standard - very long to load
some images in Ha with the Mod PST
Ha without Fabry – Pérot for the prom
- banjo
- Has thanked: 2100 times
- Been thanked: 2878 times
sorry for my English translators google
- Has thanked: 9313 times
- Been thanked: 6151 times
- Has thanked: 17848 times
- Been thanked: 16985 times
Re: Ha without Fabry – Pérot for the prom
Awesome work Paul
They flicker so they probable are EBs.
- Been thanked: 4976 times
- Has thanked: 3317 times
- Been thanked: 1907 times
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4880 times
- Been thanked: 8906 times
Absolutely amazing Paul I didn't realise you could do that! They are most probably Ellerman bombs as these are seen in the wings of H-alpha and they also come and go in the timelapse. However, they are also in a similar position to the 'Bright ring' as found in CaK too, very interesting indeed!
