Gales from the west becoming increasingly difficult in the dome as it turns to south.
Seeing improving as lunch arrives and cloud clears.
A flare has suddenly appeared to the north of disturbed area!
160mm D-ERF, iStar 150/10 H-a, Beloptik KG3 Baader 35nm H-a, PST mod with Maier ITF, ZWO ASI 174MM.
3k frames at 320fps in 9 seconds, 0.8ms, 800x600 and 640x480. SharpCap 3.2, iMPPG, PhotoFiltre7.
Flare has appeared on southern AR
- Rusted
- Has thanked: 8016 times
- Been thanked: 1938 times
- Has thanked: 17666 times
- Been thanked: 8787 times
Re: Flare has appeared on southern AR
Fantastic images Rusted, I looked this one up and it managed to splutter a A class flare at 11:50 UTC well caught though
https://www.swpc.noaa.gov/products/goes-x-ray-flux
- Rusted
Thanks Alexandra.
I'm quite pleased with progress with the new iStar f/10 H-a, OTA with full aperture D-ERF.
It's the only instrument on my big DIY GE mounting now. So it doesn't catch the wind like it did.
I was capturing images at five to ten minute intervals once the cloud finally cleared.
I capture, process and then post on my blog.
The time taken to process and post the final image dictates the capture intervals.
Only the last image before lunch showed the flare. Image capture times are all CET.
The flare capture is at 12:46 CET. The previous 12:35 CET shows no sign of a flare.
- salvo lauricella
- Has thanked: 56 times
- Been thanked: 75 times
Wonderful images!
Salvo Lauricella
https://www.salvolauricella.it/
- Rusted
How kind. Thank you Salvo!
I still have much to learn about processing.
- Rusted
At 15:03 [CET] the flare had folded itself into a tiny U-shape at its south eastern extremity.
The seeing has gone off over lunch.
- Has thanked: 20424 times
- Been thanked: 10243 times
Nice images Rusted!
