FD 03-30
FD 03-30
A quick recoding from this morning before the clouds, there was a lot of hase in the air ...
Asi 120MM-S
Lunt DS 60/35
I believe there is something wrong, I have all horizontale small lines in both images, not to see in the AVI recording.
Asi 120MM-S
Lunt DS 60/35
- Been thanked: 10489 times
Re: FD 03-30
Nice sun, looks like fixed pattern noise to me.
- salvo lauricella
- Has thanked: 56 times
- Been thanked: 75 times
Re: FD 03-30
Nice shots! Even for me it is fixed patter noise.
Salvo Lauricella
https://www.salvolauricella.it/
Re: FD 03-30
The problem is fixed,
It was in AutoStakkert 3, the "frame procentage to stack" was not oke, I had places in the four columns each 10%.
Now I only placed in the first colon 10% and the result is free of horizontal lines.
- JochenM
- Been thanked: 1619 times
Re: FD 03-30
I don't understand why there are four "frame procentage to stack" in AS3.
- JochenM
Re: FD 03-30
They represent 25% sections of the video. If you look at the graph in the middle of the screen, it'll give you an overview of the quality of each section. The idea is that you pick the section with the best quality and use frames (however many you see fit) from that section by entering a number in the appropriate input box.
Re: FD 03-30
Jochen, what do you think is the best of the four coloms?JochenM wrote: ↑Mon Mar 30, 2020 1:07 pmThey represent 25% sections of the video. If you look at the graph in the middle of the screen, it'll give you an overview of the quality of each section. The idea is that you pick the section with the best quality and use frames (however many you see fit) from that section by entering a number in the appropriate input box.
- JochenM
Re: FD 03-30
Personally, I'd use the second. The overall quality of frames looks highest there.
I think you can safely use a higher percentage as well. You have a total of 1008 frames, so 252 per section to play with.
Re: FD 03-30
This image is again WITHOUT a flat processed.
There are no visible traces of horizontal lines.
When I don't use a flat calibration in Sharpcap 3.2 Pro than I have not the horizontal lines.
Re: FD 03-30
Thanks Jochen, but what is the function of the green curve from upper left to botom right??
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Re: FD 03-30
The green line represents the sorted to quality.
Jochen are you sure about the "sections". Doesn't AS stack accourding the the sorted quality? (Thats the only way thats make sense)
Paul
Paul
- JochenM
Re: FD 03-30
Hi Paul
You're making me doubt now
The way I always understood it (maybe I'm completely wrong, anyone feel free to correct me) is that the "sections" are basically representations of 25% of the total frames by sorted quality (left to right).
- PDB
Re: FD 03-30
My understanding was the 4 stack options were to generate 4 stacks "at the same time" from the same set (left to right on the graph)
The diagram is normally shaded, which is the sorted option. You can change that by pressing the frames button on the image window, then you scroll not by quality, but by time. (But don't know if that influences stacking)
Not much documentation around for AS!3. Maybe whe should as Emiel
Paul
Paul
Re: FD 03-30
Yup, that's what it does.
- JochenM
Re: FD 03-30
After we know, is the second part now the best of the four parts in the above diagram, and why, because most lines are above the blue horizontal 50% line?
Re: FD 03-30
AS3 sorts the best frames to stack automatically.
- Has thanked: 9723 times
- Been thanked: 5773 times
Re: FD 03-30
Nice disks
Rainer
Nice disks
Rainer
Re: FD 03-30
I'm glad you got this sorted, the full discs are beautiful
I always thought the 4 sections were a time saving device, you align the once, then can stack the best 1%, 2%, 5%, 10% etc or whatever you fancy and see which is the best.
Re: FD 03-30
That's exactly what it is.
