Another beautiful blue sky day and I managed a few minutes before work this morning (albeit working from home) to try out the 250mm RCT (just to please Valery). The seeing conditions were pretty good (not perfect) but much, much better than anything I'd seen over the past week, thanks to high pressure over the UK.
Here are a few random shots of the chromosphere taken with a 2.5x powermate and 1.5x Barlow. I took heed of Valerie's suggestions and captured around 5000 frames with my acA1920-155um camera running at 160 frames per second and stacked in my case about 50 frames (set AS!3 to stack 1%).
It's just a pity there are no active regions to focus on.
2.5x Powermate images:
20200416_rct_2.5x by Stuart Green, on Flickr
20200416_rct4_2.5x by Stuart Green, on Flickr
1.5x Barlow images
20200416_rct6_1.5x by Stuart Green, on Flickr
20200416_rct7_1.5x by Stuart Green, on Flickr
20200416_RCT_1.5x_Mono by Stuart Green, on Flickr
Thanks for looking.
Chromosphere images with 250mm RCT
- Has thanked: 8559 times
- Been thanked: 8297 times
- Has thanked: 20828 times
- Been thanked: 10501 times
Re: Chromosphere images with 250mm RCT
Good job Stu, the seeing was the best i've had all week too.
How do you think they compare to the results you get with the 150?
- JochenM
- Been thanked: 1619 times
Looks like the seeing was cooperating indeed.
Especially that first image looks great. Nicely done.
- pedro
- Has thanked: 14 times
- Been thanked: 6696 times
wonderful images Stu, not much going on though
Pedro Re'
- Has thanked: 9327 times
- Been thanked: 6163 times
Great job with the close-ups, Stu. I observed with the small scope and the large prom was gone.
Glad you enjoyed good seeing and had the opportunity to use the big scope successfully.
- Been thanked: 4981 times
Stu:
A very interesting HR session on a rather blank Sun, but the results are outstanding.
- Been thanked: 8907 times
Many thanks everyone. Much appreciated.
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Hi Stuart,
You must be very glad you took your 250mm RCT out. Stunning results! The first one shows the plasma best, especially wavy. Please Keep them coming.
What did you use as the second filter? Can you post a photo of the setup?
Best.
Alfred
Best.
Alfred
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
Great images as always , well done Stu.
Martin
Martin
