Hello Everyone.
Here is a collection of spectroheliograms taken on June 12. There was a bit of a delay in posting because I'm still experimenting with processing techniques. I set the instrument up for full disk views. It had previously been configured for closeups (using a ~3x barlow on the Celestron 4" SCT) and I actually regret having made the change for this session because it would have been more interesting to view the AR and prominence at higher magnification. Chalk it up to rustiness after a long time since last using the SHG. I also replaced the previous 2400/mm grating with a 1800/mm grating. This sacrifices some spectral resolution for better transmission in the UV.
The first montage shows the solar disk imaged in the four Fraunhofer lines: CaII K, H beta, HeD3 and H alpha.
The second montage shows a series of images in H alpha. The SW limb prominence is evident in the upper frames which are composite images of prominence and disk. A blue wing image shows the expected similarity to H beta shown in the first montage. A dopplergram shows some evidence of complex plasma flow near the AR.
The third montage shows some images in the UV. These are composite images of prom and disk in the CaII K line. A blue wing CaII K line and an image taken in the CN bandhead (3883 angstroms) show strong similarity. The CN molecular band is interesting because magnetic bright points can be observed there (at high spatial resolution) with greater contrast than in the CH molecular G-band (~ 4300 angstroms). The required spatial resolution would be pretty challenging for a spectroheliograph.
The SW limb prominence exhibited some interesting spectral behaviour. If only I had opted for higher magnification! Here is an image taken with an effective spectral resolution of about 2 angstroms. A coronal loop is evident along with a higher lying wispy structure.
These features were captured by a number of observers on this forum:
Eric Roel viewtopic.php?f=4&t=28475
Phil (Astrophil) viewtopic.php?f=4&t=28464
John (highfnum) viewtopic.php?f=4&t=28474
James (DeepSolar64) viewtopic.php?f=4&t=28473.
The spectroheliograph revealed that the prominence consisted of structures that varied significantly with wavelength. In order to demonstrate this, I assembled the following animated spectral sequence of the prominence: a movie showing the shape of the prominence as the wavelength is tuned over a range of about 2.5 angstroms.
Each frame of the video represents a step of 0.058 angstroms, or, in terms of the recessional velocity corresponding to a 0.058 angstrom doppler shift, a velocity step of 2.56 km/s. The frames in the animation are labelled with the recessional velocity with respect to gas at rest on the disk surface. Negative velocities refer to approaching gas while positive numbers refer to receding gas. It looks as if the wispy prom component had a significant recessional velocity component. Was this gas in the process of being ejected?
Anyway, it's good to be making spectroheliograms again! Hope you enjoy.
Peter
12 June 2020 Spectroheliograms
- Has thanked: 8559 times
- Been thanked: 8290 times
Re: 12 June 2020 Spectroheliograms
Peter, these are exceptionally good spectroheliograms. The quality is amazing.
The prom animation is absolutely fascinating and it would also be interesting to see these images stacked in colour, 'blue to red' to show in one image the entire prom and its velocity field.
Excellent.
Excellent.
Absolutely wonderful Peter, a thoroughly enjoyable and informative post, the animation is incredible together with marvellous views of the sun. I do like the He D3 how it is completely inverted to Halpha or CaK view
- Been thanked: 10489 times
Fascinating post and excellent images Peter! Love it!
