The weather report for today was not totally correct. We were supposed to have a lovely sunny day for the most part, but by mid-morning yet again the clouds rolled in and then things got patchy throughout the rest of the day. Thankfully I managed to do what I needed to do before the opportunity was lost.
I've been thinking for a while about doing an animation of surface granulation and after a couple of failed attempts I had a plan to take a continuous sequence of 10s bursts, but for that I needed a clear sky without any fluffy clouds to spoil the flow. This morning was perfect for that. More on that later.
First up a hydrogen alpha full disk using my Lunt 60.
20200719_Ha_FD_Mono by Stuart Green, on Flickr
20200719_Ha_FD_Colour by Stuart Green, on Flickr
Then over to Ca II K and a few views of a little patch of plage in the south west.
20200719_CaK_2.5x_Mono by Stuart Green, on Flickr
20200719_CaK_2.5x_Colour by Stuart Green, on Flickr
20200719_CaK_5x_Mono by Stuart Green, on Flickr
20200719_CaK_5x_Colour by Stuart Green, on Flickr
Then on to 'white light' views (540nm continuum) with my Lacerta wedge. Full disk and some closer granulation shots with, finally, the animation.
20200719_WL_FD_Mono by Stuart Green, on Flickr
20200719_WL_FD_Colour by Stuart Green, on Flickr
20200719_WL_Granulation_2.5x_Mono by Stuart Green, on Flickr
20200719_WL_Granulation_2.5x_Colour by Stuart Green, on Flickr
20200719_WL_Granulation_Mono by Stuart Green, on Flickr
20200719_WL_Granulation_Colour by Stuart Green, on Flickr
The animation comprises 17 frames collected sequentially in 10s bursts, so just around 3 minutes in total, yet close inspection shows a significant amount of movement. Previously I had waited too long between frames so my attempts were always too 'jumpy'. This has better flow, capturing the rapid changes over the short imaging period quite well I think. Room for improvement, but my best so far.
Granulation_Animation by Stuart Green, on Flickr
Thanks for looking.
Sunny Sunday morning 19th July '20
- Has thanked: 8415 times
- Been thanked: 8161 times
- Has thanked: 9401 times
- Been thanked: 5564 times
Re: Sunny Sunday morning 19th July '20
Hi Stu,
Very good. Interesting animation in White Light.
- Been thanked: 4904 times
Stu:
Very clean and crisp shots, beautiful animation.
- Been thanked: 4340 times
These are excellent images Stu...a great catch while the conditions allowed
- Has thanked: 17667 times
- Been thanked: 8787 times
A cracking WL animation Stuart, crystal sharp just needs to be longer
Hi Stuart,
Excellent and crystal-clear images and animation of another day of a blank/very quiet disk - thanks vm.
Regards
Regards
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
All the images are superb Stu, however I particularly like the Lunt 60 as that is the same scope I have.
Dan
South central Indiana
USA
USA
- Rusted
- Has thanked: 8016 times
- Been thanked: 1938 times
Stuart,
A stunning set of images.
You really are an all rounder!
In all senses of the word.
