AR2767 in High Res II | HA, CaK, Gband Trifecta | July 27th 2020
- Has thanked: 1192 times
- Been thanked: 1386 times
I had a small window this morning (0800am Eastern Time) here in Florida before clouds & rain rolled in. It's now thunder storming of course. But in that brief period I had a chance to get some decent data on AR2767. The spot has evolved a bit and the plage has decayed to something smaller with less major filaments coming from the area. Being close to the center of the face of the disc in its transit, some features are more obvious now (like cells, and the structures in the penumbra and sometimes the inner structure of the umbra itself). The plage is less dramatic and mottling less dramatic straight on compared to at an angle where more contrast is on the spicules. But straight on like this, the convection cells and k-grains are a bit more obvious with better contrast I think compared to at an angle. I noticed the beginnings of what might be a light bridge were different in the various wavelengths, in HA it appeared to have a nearly complete light bridge in two sections of the umbra, but I didn't see that same structure in Gband, but the structure's root to the umbra was visible, however in CaK it was a little less visible. Kind off as I have not noticed that before (with a completed light bridge I typically note it in all wavelengths). So perhaps it was not a light bridge. I'm not sure, so I'm interested in everyone's thoughts on this phenomena!
B&W:
Colored:
Seeing Conditions (not great, but supported the image scales of 0.2" to 0.4" per pixel with sub-arc-second-seeing):
Equipment:
150mm F8 Refractor
+ 2" Baader Red CCD-IR Block Filter (Sub-aperture internal D-ERF) + Baader GPC 1.25x (F10) + PST 1A HA Etalon + 10mm BF + ASI290MM
+ 2" Baader Blue CCD-IR Block Filter (Sub-aperture internal D-ERF) + 2.5x Telenegative Amplifier (F20) + EdmundOptics 430nm Filter + Baader 3.0 ND + ASI290MM
+ (aperture masked to 120mm F10) + 2" Baader Blue CCD-IR Block Filter (Sub-aperture internal D-ERF) + 2.5x Telenegative Amplifier (F25) + Lunt CaK B1200 + ASI290MM
B&W:
Colored:
Equipment:
150mm F8 Refractor
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: AR2767 in High Res II | HA, CaK, Gband Trifecta | July 27th 2020
Awesome images Marty. I leave comments on the light bridge to the more knowledgeable.
Dan
South central Indiana
USA
USA
- Has thanked: 9733 times
- Been thanked: 5777 times
Hi Marty,
Very good and here it is raining due to " Hanna "
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Excellent images, Marty.
Awesome H-alpha and the WL and CaK shots are very crisp and detailed.
Peter
Peter
- Has thanked: 17862 times
- Been thanked: 17006 times
WoW Marty! The Ha ones are good but the Gband and CaK ones are absolutely stunning. Incredible job my friend!
- Been thanked: 4981 times
Marty, agree with James, the G band and the CaK are super.
- Has thanked: 20828 times
- Been thanked: 10502 times
A very good set of images Marty, glad you got something before the weather came in.
Hi Marty, excellent images - thanks vm
Thanks all,
Here's an animation (forgive me its a little large, 3.5MB, may take a minute to load) of the three wavelengths aligned to see how the structures change through the layers of the chromosphere and photosphere.
(If anyone knows a way to make these files more efficient for gif animation, that would be a great help, I can't seem to ever get them to be 500kb or anything like that, always several MB despite the files being only a few Kb each)
- Been thanked: 2725 times
Hi Marty,
The 3-band animation is very interesting !
- arnedanielsen
- Has thanked: 6305 times
- Been thanked: 7327 times
Excellent collection of images in different wavelengths and the animation is just super cool!
Arne
Arne
- Been thanked: 8907 times
Fabulous images Marty and that animation just tops it off
Thanks all,
Looks like something truly energetic is coming around the bend as of right now, it has a leading pore but the main spot is still masked behind the limb. It's magnetic region is significantly larger than AR2767's so this could potentially be a "great spot." Hope so! If it's truly "great" it may last the 10~12 day transit and make a 2nd appearance like the last great spot did? Would be nice!
- Has thanked: 9327 times
- Been thanked: 6163 times
