18 Nov 2020 AR2783 and prominence
Fabio_Imm
Has thanked: 214 times
Been thanked: 146 times
Post by Fabio_Imm »
After ten days of rain, finally a sunny day!
Seeing was mediocre, with the usual whitish haziness.
SS60 Quark etalon on an 80ED scope
Basler acA1920-155um
Image2020-11-18_T1 by Fabio Immovilli, su Flickr
Also captured my first prominence :hamster: , found it an the northern limb, just opposite to AR2783
Image2020-11-18_P2crop by Fabio Immovilli, su Flickr
Concerning proms, which is the best approach to picture them: long exposures with low gain or max gain with short exposure?
Cheers
Fabio
Been thanked: 4957 times
Re: 18 Nov 2020 AR2783 and prominence
Post by eroel »
Fabio:
You got the Sun in spite of bad seeing, so the session was a success.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Thanks Fabio.
I tried to capture the spot in WL with Baadar film, without success due to thin-clouds
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
Not bad at all considering the conditions, Fabio.
Regarding your question; I always try to keep the gain low (and of course that means slightly higher exposure times). More gain = more noise, which I find always shows in prominences.
Jochen Maes
Belgium
https://www.jochenmaes.com
Fabio_Imm
Post by Fabio_Imm »
Hi Jochen,
Thank you for the info.
I asked, because in today's imaging session I tried two different settings resulting in similar histogram:
a) 150 ms exposure, low gain
b) 50 ms exposure, max gain
After stacking and post processing I found no difference between a) and b) in terms of noise (maybe it got averaged out by the stacking?)
but b) was noticeably more crisp in details.
Anyway, this was just a single quick test, I'll investigate further under better seeing conditions.
Cheers
Fabio
rsfoto
Has thanked: 9677 times
Been thanked: 5757 times
Post by rsfoto »
Very good.
yltansg
Has thanked: 1455 times
Been thanked: 1444 times
Post by yltansg »
Hi Fabio,
You should also try different gamma setting.
Alfred
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Nice images of the AR and prom Fabio...well done !!!
Has thanked: 17925 times
Been thanked: 8891 times
Wonderful images :bow :hamster: the prom is fabulous :hamster:
I would answer the same as all the above. It is a question of testing in your system, you want as low gain as you can get away with and as quick an exposure as you can get away with. You have to balance the two out. Every prominence is different so difficult to always use the same method each time. For each prom I usually image a range of gain vs exp and see which comes out best. Also, like Alfred said, play with the gamma too. Increasing the gamma can also make it easier to see the prom and lower the exposure, but be cautious! the more gamma you add the more white haze you get and the more stacking artefacts you get. I only change this marginally as I have learned the hard way :)
