FD and proms in HA and Baader Ca-K 29th January
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Hi all, not entirely satisfied with yesterday's results, illumination not quite right. There was high altitude haze but not sure if that's why. Usually I can get good overall illumination. Anyway these are taken with my Lunt 60mm DS and 80ed both with the Zwo ASI 178mm camera.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Has thanked: 17813 times
Been thanked: 16953 times
Re: FD and proms in HA and Baader Ca-K 29th January
Post by DeepSolar64 »
You got much better results than I got yesterday!
Stardust5858
DeepSolar64 wrote: Sat Jan 30, 2021 8:21 pm You got much better results than I got yesterday!
Awwwww, thanks, it's really challenging this time of year with the low altitude of the sun and weather isn't it.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Hi Nigella, I wish that I could get such exquisite and fabulous images as you do - regardless of the weather.
Your coloured version of the "Two Trees & Hedgerow" prom and the undefined one in close-up are may favs...
Thanks vm for sharing
Stardust5858
EGRAY_OBSERVATORY wrote: Sat Jan 30, 2021 10:28 pm Hi Nigella, I wish that I could get such exquisite and fabulous images as you do - regardless of the weather.
Awwwww, thanks Terry, very much appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
rsfoto
Has thanked: 9694 times
Been thanked: 5761 times
Post by rsfoto »
Well done.
Stardust5858
rsfoto wrote: Sun Jan 31, 2021 1:01 am Hi,
Well done.
Thanks Rainer, it's appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Has thanked: 20757 times
Been thanked: 10444 times
Nice shots Nigella! Try sharpening the caK and proms at a smaller radius, you will get more detail out. Stopping down the ED80 to 60mm will tease out more detail too as spherical aberration is reduced, it will also be a lot more friendly to your seeing.
Has thanked: 17925 times
Been thanked: 8894 times
:hamster: WOW!! look at that solar disc :hamster:
Fabulous proms and CaK :bow :hamster:
PS Just wondering, all your images are time stamped with a 30th January mark, are they from the 29th or 30th Jan? However, somehow I can't see you imaging at 19:35. If you could correct that you would find it useful in the future, when flares occur or something special it is good to refer to the time stamp as you will never remember unless you write the time down somewhere else.
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Great series of images Nigella...well done :bow
Stardust5858
MapleRidge wrote: Sun Jan 31, 2021 10:33 pm Great series of images Nigella...well done :bow
Thanks Brian, appreciate the comment.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
