Full disk 01-02-2021
- Has thanked: 9807 times
- Been thanked: 5822 times
Feruary started well.
Lots of filaments in the Northern and Southern hemisphere and even a new spot visible in White Light at ~ +30° and ~+30° which possibly will be named ¿ AR 12801 ? as the position is new. Yesterday it was just a plague.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: Full disk 01-02-2021
I was hoping you would get that new spot Rainer, thanks.
Dan
South central Indiana
USA
USA
indeed Rainer the Sun-spot well shows in your captures, so well done as usual.
(was just about to post an SDO image of this).
- Has thanked: 17941 times
- Been thanked: 17090 times
Ha is overall quite calm and you got a spot in the NW. Thanks for the view Rainer. I have gotten clouded out again and it has turned off cold and windy. I yearn for your warmer climate where the palm tree sways....
- Has thanked: 20938 times
- Been thanked: 10586 times
Very nice indeed Rainer, that's a great northern polar crown you've captured there!
- Has thanked: 65 times
- Been thanked: 4453 times
Superb image Rainer...great details
- Has thanked: 8588 times
- Been thanked: 8324 times
Very nice FDs indeed, Rainer. It's always a pleasure to see your images.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely captures Rainer, thanks for sharing. Been cloudy since the 29th January here .
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Very good!
Marios S.Ioannou
Sketcher/Visual Observer
- Has thanked: 18090 times
- Been thanked: 8934 times
Well done Rainer I didn't quite see a spot there on my images but the plage was very bright.
Thank you very much for the SPoD
