It was getting late in the morning and the seeing conditions were deteriorating fast on an otherwise beautiful day.
Ha FD on the Lunt 60 with Coronado BF. This is a bit under sampled on the Basler acA1920-155um camera with a 1.5x Barlow. I usually use a 2.5x Powermate for a better match to the pixel size.
20210211_Ha_FD_Mono by Stuart Green, on Flickr
20210211_Ha_FD_Colour by Stuart Green, on Flickr
and I couldn't resist a quick image of the small active region in spite of the seeing. I didn't want to risk over sharpening in ImPPG, so the image is a little 'soft' as a result.
20210211_Ha_AR_Mono by Stuart Green, on Flickr
Thanks for looking.
Ha FD and a close view of the small active region
- Has thanked: 8415 times
- Been thanked: 8161 times
Re: Ha FD and a close view of the small active region
A cracking close-up Stu, showing fine detail of the disintegrating AR.
Shame the disks aren't busier today, but the nice-long filament is interesting.
Thanks vm
Thanks vm
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Looks like it could be almost, one filament below that AR, nice.
Dan
South central Indiana
USA
USA
- Been thanked: 16691 times
Very nice discs Stuart. I like the detail in the plage closeup. You did very well considering the seeing conditions!
- Been thanked: 4340 times
Nice work Stuart, you pulled out a lot of details in the images
- Has thanked: 20424 times
- Been thanked: 10243 times
They came out well Stu!
- Has thanked: 9144 times
- Been thanked: 6025 times
- Has thanked: 17667 times
- Been thanked: 8787 times
Nice work Stuart been lovely weather yesterday and today, I bet it won't be sunny tomorrow
