Partial and full disc views from the 26th
An archive of all the best images Solar Chat has to offer!
AJamesB
Has thanked: 1154 times
Been thanked: 630 times
Post by AJamesB »
The (very long and drawn out) relocation is finally winding down, and I was able to get the solar scope out in the backyard again after about 3 months of not being able to do any imaging at all. Felt good to be out again and almost done with the move!
Images captured at about sea level on a singestack lunt 100, with meteoblue saying I had about 2 arcseconds of seeing. Both images were single captures, then using masked stretch with a range selection to stretch the filaments into view. Full disc is also single image using the 0.5x reducer (cheap one, edges are a bit soft vs the center) on the 178mm. Partial disc is pure 178mm. Processing is a bit rusty as I forgot some of my workflow and coloring settings, but good to be out none the less.
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Re: Partial and full disc views from the 26th
Post by Stardust5858 »
Lovely captures, it must feel great to get back to your solar imaging. I get withdrawals if I don't see the sun. Here in the UK I can go weeks, especially in the winter months. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
krakatoa1883
Has thanked: 153 times
Been thanked: 496 times
Post by krakatoa1883 »
Wow, great spectacular captures!
Raf
rsfoto
Has thanked: 9677 times
Been thanked: 5756 times
Post by rsfoto »
WOW, those two proms from a few days ago went into a huge one ...
Has thanked: 20738 times
Been thanked: 10432 times
They came out well, glad you're able to get the scope out again properly!
Has thanked: 17901 times
Been thanked: 8888 times
Wow!! these are incredible, what a sight!! :bow :hamster:
