Hello,
in view of satellite images and Météoblue , I installed the equipment and all day it is not discovered
but I didn't really believe it, I run the acquisitions automatically and the result is more than remarkable given the conditions,
the Ha would be the secret boot (well with the 150mm at the 60 it was pretty bad)?
to give an idea of the transparency, for the surface usually gain = 50 speed 4.5 / 6.5ms, on these sockets gain = 99 speed 10ms
Paul
haze and fog long live the Ha !!! March 4+NEW color
- banjo
- Has thanked: 2100 times
- Been thanked: 2878 times
- Has thanked: 20813 times
- Been thanked: 10487 times
Re: haze and fog long live the Ha !!! March 4
Really nice captures Paul, thanks for sharing!
- Has thanked: 975 times
- Been thanked: 344 times
Great proms!
Call me Geoff.
- Has thanked: 17853 times
- Been thanked: 16992 times
WoW, how did you manage to get that kind of detail through so much mirk?! That's amazing!!
Very nice work Paul!!!
- JochenM
- Been thanked: 1619 times
That's quite some impressive shots for those kinds of conditions, Paul.
- banjo
I have the impression that the mist has stabilized the temperature and calmed the turbulence.DeepSolar64 wrote: ↑Fri Mar 05, 2021 5:44 pm WoW, how did you manage to get that kind of detail through so much mirk?! That's amazing!!
to give an idea, usually for the protus I am at 180 in gain and 10ms, there it is 303 and 10ms, the advantage is that the haze calms the turbulence instead of stacking 50i by .Ser I was able to take 400 in 16bits for #2 prom's, suddenly the dynamic goes up and for processing I only took the .tiff sharpened 50% of AS! And made tone / light dark and an emphasis on the softer and auto contrast on the harder.
The wind was gusting around 25 / 30kmh on my hill and I was in the shelter on the eq8 it helps a bit when it is oriented well, but it is a disaster when it is full sun.
a brute exit from AS! for this one retained only 111 images on stacking
sharpened 50% out of AS!
- Has thanked: 9319 times
- Been thanked: 6157 times
Nice additions Paul!
Re: haze and fog long live the Ha !!! March 4+NEW color
Well done Paul, absolutely exquisite prominence imaging
You get far better results on a bad day than I do on a good one
- Been thanked: 4427 times
Hi Paul...
These are excellent images...well done
Congrats on the prom image being selected as the SPoD too!!!
