My first solar animation test
Gingerfish
Has thanked: 60 times
Been thanked: 78 times
Post by Gingerfish »
Right! My first ever solar animation. I finally got enough clear sky to test out my Lunt 50 mod. I'm using an Altair 102ED f/7 refractor, with an extra internal Baader 35nm filter. I also converted my blocking filter into a straight-through one.
The only mono cam I have, is a ZWO asi120. And it Newton rings like mad! So I made my own tilt adapter out of an extra nosepiece I had lying around. That took care of the worst rings :D
Seeing wasn't great, so I only got 25 minutes. My solar processing skills are also non-existent, so be gentle :p But I think I'm now hooked on this solar stuff! :beanie:
102ED f/7, asi120, 2x barlow, SharpCap, flats
Clear sunny skies!
Chris
Lunt LS50THa
Lunt "Luntair" Altair 102ED
Has thanked: 17807 times
Been thanked: 16943 times
Re: My first solar animation test
Post by DeepSolar64 »
I am a beginning imager as well. I haven't tried animations yet. It looks like you are off to a nice start by me.
rsfoto
Has thanked: 9677 times
Been thanked: 5756 times
Post by rsfoto »
Well done.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Nice to see, well done.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Gingerfish
Thanks all!
Hmmm...I can clearly see NR in the vid in here, but not when I play it on my PC. Compression?
DeepSolar64 wrote: Fri Mar 19, 2021 3:31 pm I am a beginning imager as well. I haven't tried animations yet. It looks like you are off to a nice start by me.
You don't want to know how much time I spent on that animation... :mrgreen:
Clear sunny skies!
Chris
Lunt LS50THa
Gingerfish wrote: Fri Mar 19, 2021 4:30 pm Thanks all!
I spend a lot of time editing too. I find it amazing on how fast some of the more experienced imagers do it. But I'll admit, I lack patience and can be a bit lazy. I want it done fast and with as less effort as possible and still get a good image.
Gingerfish
I know the feeling. And like you, I'm a bit lazy. I just want it done :P
Clear sunny skies!
Chris
Lunt LS50THa
Has thanked: 20738 times
Been thanked: 10432 times
Excellent first result and nice shot of the setup too!
Has thanked: 17901 times
Been thanked: 8888 times
Well done :bow :hamster: nothing will stop you now :hamster: have you automated most of the processing? if you set Autoskakkert in batch mode to stack, walk away and have a cup of tea. Then in ImPPG, sharpen the first and save the settings, then set it going in batch mode to sharpen them all. Again you can walk away and have a cup of tea. Then, with all the sharpened images set ImPPG to align them all. Then run in GIMP or Photoshop to make your Gif. It shouldn't take more than an hour :) with lots of cups of tea :)
