Right! My first ever solar animation. I finally got enough clear sky to test out my Lunt 50 mod. I'm using an Altair 102ED f/7 refractor, with an extra internal Baader 35nm filter. I also converted my blocking filter into a straight-through one.
The only mono cam I have, is a ZWO asi120. And it Newton rings like mad! So I made my own tilt adapter out of an extra nosepiece I had lying around. That took care of the worst rings
Seeing wasn't great, so I only got 25 minutes. My solar processing skills are also non-existent, so be gentle :p But I think I'm now hooked on this solar stuff!
102ED f/7, asi120, 2x barlow, SharpCap, flats
My first solar animation test
- Has thanked: 60 times
- Been thanked: 78 times
- Has thanked: 17859 times
- Been thanked: 17003 times
Re: My first solar animation test
I am a beginning imager as well. I haven't tried animations yet. It looks like you are off to a nice start by me.
- Has thanked: 9733 times
- Been thanked: 5777 times
Well done.
Well done.
- Been thanked: 4881 times
Thanks all!
Hmmm...I can clearly see NR in the vid in here, but not when I play it on my PC. Compression?
You don't want to know how much time I spent on that animation...DeepSolar64 wrote: ↑Fri Mar 19, 2021 3:31 pm I am a beginning imager as well. I haven't tried animations yet. It looks like you are off to a nice start by me.
Clear sunny skies!
Chris
Lunt LS50THa
Lunt "Luntair" Altair 102ED
Chris
Lunt LS50THa
I spend a lot of time editing too. I find it amazing on how fast some of the more experienced imagers do it. But I'll admit, I lack patience and can be a bit lazy. I want it done fast and with as less effort as possible and still get a good image.Gingerfish wrote: ↑Fri Mar 19, 2021 4:30 pm Thanks all!
I know the feeling. And like you, I'm a bit lazy. I just want it done
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
- Has thanked: 20828 times
- Been thanked: 10502 times
Excellent first result and nice shot of the setup too!
- Been thanked: 8907 times
Well done nothing will stop you now have you automated most of the processing? if you set Autoskakkert in batch mode to stack, walk away and have a cup of tea. Then in ImPPG, sharpen the first and save the settings, then set it going in batch mode to sharpen them all. Again you can walk away and have a cup of tea. Then, with all the sharpened images set ImPPG to align them all. Then run in GIMP or Photoshop to make your Gif. It shouldn't take more than an hour with lots of cups of tea
