Yesterday's Imaging Session 26th April
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi all, finally got around to process and post the imaging session from yesterday using the Lunt 60mm DS and 100mm AR stopped down to 60mm. Zwo Asi 178mm camera for all images. False colour added in PS CS2.
- 20210426-112807UTellabryant-haPROMS-FD.jpg (620.89 KiB) Viewed 385 times
- 20210426-112807UTellabryant-haPROMS-FD-col.jpg (1020.12 KiB) Viewed 385 times
- 20210426-112210UTellabryant-Fil-ARs.jpg (1.09 MiB) Viewed 385 times
- 20210426-112210UTellabryant-Fil-ARs-col.jpg (1.12 MiB) Viewed 385 times
- 20210426-112115UTellabryant-HAARs.jpg (853.24 KiB) Viewed 385 times
- 20210426-112115UTellabryant-HAARs-col.jpg (953.51 KiB) Viewed 385 times
- 20210426-113351UTellabryant-FD-col.jpg (1.02 MiB) Viewed 385 times
- 20210426-123651UTellabryant-CaK-AR.jpg (465.3 KiB) Viewed 385 times
- 20210426-123651UTellabryant-CaK-AR-col.jpg (752.93 KiB) Viewed 385 times
- 20210426-103137UTellabryant-CaK-FD.jpg (839.35 KiB) Viewed 385 times
- 20210426-103137UTellabryant-CaK-FD-col.jpg (838.64 KiB) Viewed 385 times
- 20210426-110242UTellabryant-WLARs.jpg (631.25 KiB) Viewed 385 times
- 20210426-110242UTellabryant-WLARs-col.jpg (493.61 KiB) Viewed 385 times
- 20210426-102549UTellabryant-WLFD.jpg (872.62 KiB) Viewed 385 times
- 20210426-102549UTellabryant-WLFD-col.jpg (954.46 KiB) Viewed 385 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4787 times
- Stardust5858
Re: Yesterday's Imaging Session 26th April
Thanks Maurits, appreciate your comment. Managed some CaK and WL this morning too. Rain forecast for several days ahead now. Weather was good while it lasted even if the seeing wasn't the best.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 8791 times
- Stardust5858
Thanks Alexandra, appreciate the comment.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
