My first Hα animation with D = 200 mm (and a flare)
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 753 times
On Sunday the seeing was finally good enough to utilize my RC8 + LS50THa + Aried tri-band ERF setup.
One of the best videos yielded this image of AR 2822 (check out this thread if you'd like to play with the raw stack):
I continued recording for some time, even though the seeing was variable and a high thin cloud was passing. I saw a few bright points appear, but had no way of knowing it would be a nice C4.0-class flare, until I put together an animation:
Beside the "igniting grass", note how there's a brightening in the billowing "smoke", right before a thin stream gets sucked back in to the smaller sunspot.
I'm really satisfied; even despite the so-so seeing this tiny thing looks very interesting. Can't wait for an M-class like the one I caught with 90 mm – it would fill the whole FOV with twisting and churning plasma!
I also recorded a CaK animation (Lunt CaK module, 90 mm refractor, PowerMate 2.5x), much better seeing than during the previous attempt, with consistently good resulting frames, but nothing happened there at all:
Mandatory full disc from Lunt 50:
and proms from the 90 mm mod:
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: My first Hα animation with D = 200 mm (and a flare)
Amazing, lovely animation of the flare. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
You captured some amazing dynamics from this activity region.
Beautiful to watch.
Peter
Beautiful to watch.
Peter
- minhlead
- Has thanked: 738 times
- Been thanked: 1104 times
Amazing!
Minh.
Loves from Viet Nam <3
My gear:
Scope: SkyRover (Kunming Optics) 152mm F/6 Doublets
Mount: JTW Tridents GTR
Camera:
PlayerOne Apollo M-Max
Quark Chromosphere Doublestacked with PST etalon
My gear:
Camera:
Absolutely Fabulous animation and well interesting too. Also the stills are really great.
Thanks for sharing
Thanks for sharing
- Has thanked: 17572 times
- Been thanked: 16692 times
I caught this flare visually Sunday using my SMII60. I did not get a view like this though. That's an awesome animation at a considerable magnification.
- Has thanked: 8415 times
- Been thanked: 8161 times
Superb animation. Amazing dynamics beautifully captured.
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Fantastic video, great luck.
Is this your new mod?
Ivan
Ivan
- Has thanked: 2412 times
- Been thanked: 4786 times
- GreatAttractor
Thanks, everyone. Too bad seeing was deteriorating and clouds started rolling in – NOAA says 50 minutes later there was another flare in this AR, also C-class, but over twice as powerful.
Yes, described here.
- Has thanked: 17667 times
- Been thanked: 8787 times
Oh my goodness!! this is simply stunning
What an animation
What an animation
- Been thanked: 2713 times
This is great !!
- Has thanked: 9144 times
- Been thanked: 6025 times
A fantastic set, great attractor. The animation is magnificent.
