Ha without Fabry – Pérot for the prom
An archive of all the best images Solar Chat has to offer!
banjo
Has thanked: 609 times
Been thanked: 810 times
Post by banjo »
Hello ,
the sky is not very usable with these trails that never end, I tried again without the Pst stallion but with the Bf 5mm in front of the camera and the erf in front of the lens.
for the prom it works well, for the surface obviously it is not selective enough.
the Bf coronado must be a few Ä (if Christian Villadrich passes by there he will inform us, I believe 6Ä) wide enough for a coronograph.
in the animation without febry-parot we see shiny dots at the bottom, are they Ellerman's bombs ????
Paul
the 2 animations take a long time to load
my sky to start
the assembly of the Bf5
the comparative result unfortunately not at the same time so not necessarily significant raw images out of AS3! with the same number of AP
animation on the surface, no filament but interesting in the spot - long to load
finally comparison of the surface with the Pst standard - very long to load
some images in Ha with the Mod PST
Has thanked: 2344 times
Been thanked: 1465 times
Re: Ha without Fabry – Pérot for the prom
Post by ffellah »
Amazing work, Paul ! Everything looks great.
Franco :bow :bow
Has thanked: 5760 times
Been thanked: 4554 times
Post by DeepSolar64 »
Awesome work Paul :bow
They flicker so they probable are EBs.
eroel
Been thanked: 2163 times
Post by eroel »
Paul:
Super images and animations.
Thanks.
AndiesHandyHandies
Has thanked: 1325 times
Been thanked: 378 times
Post by AndiesHandyHandies »
Interesting.
Thanks. Andrew.
MAURITS
Has thanked: 491 times
Been thanked: 1206 times
Post by MAURITS »
Amazing setup and results Paul.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 6610 times
Been thanked: 3069 times
Absolutely amazing Paul :bow :bow :bow I didn't realise you could do that! They are most probably Ellerman bombs as these are seen in the wings of H-alpha and they also come and go in the timelapse. However, they are also in a similar position to the 'Bright ring' as found in CaK too, very interesting indeed!
