Good day everyone...
I was not aware of the flare yesterday when I arrived home for lunch, and with a lot of cirrus cloud of variable density blowing through I only planned to grab a full disk set o of images. Once I looked at the sun through the LS80T solar scope I surprised to see a lot of flare activity around AR2887...I though the new AR on the eastern limb was to be the watch to watch for
I did capture the full disk images, which are posted below:
With 6 AR's and one flaring as well as a nice collection of proms and filaments, I decided to try these with the Orion 130ED modded double stack scope. The brightness varied considerably as he clouds drifted past, but I think most of the captures came out ok. I have to go through them all yet, and have only processed two of AR2887 taken with short and long exposures to show the activity. Both were taken at approximately 16:48UT:
I will post the balance of the images later today or on the weekend when I have some free time.
Oct 28th Flare Session - 1st Images
- Been thanked: 4419 times
- Rob63
- Has thanked: 599 times
Re: Oct 28th Flare Session - 1st Images
Fantastic captures, thanks for posting and looking forward to seeing more.
Rob.
Rob.
Quark Chromosphere, Lunt LS60MT DS, Lunt Ca-K B1200 module, Baader herschel wedge
Sky-Watcher ED120 & ED80, StellaLyra 8" CC
Sky-Watcher EQ6R-Pro, ZWO AM5
ZWO ASI120MM, ASI174MM, ASI290MM, ASI1600MM
- Has thanked: 2464 times
- Been thanked: 4880 times
- arnedanielsen
- Has thanked: 6276 times
- Been thanked: 7302 times
Good timing... beautiful images of the activity.
Arne
Arne
- Has thanked: 17970 times
- Been thanked: 8904 times
Wow!!! well done Brian, what timing I love the image with the lightning streak through it
Are these 15:48 or 16:48 UTC Brian? the X class was at 15:35 and yet these images look like they are the flare and not post flare an hour and a half later.
- Rusted
- Has thanked: 8127 times
- Been thanked: 1943 times
Well done Brian!
Some high quality images. With far more extensive flaring than my earlier capture.
The sun would have been gone here, for a couple of hours, judging by your timing.
My last capture was at 14.12 [UTC] With no visible flaring at that time.
12.50 [UTC] was the last sign of AR2887 obvious flaring amongst my captures.
Some minor flaring, well to the south, at 14.08 [UTC]
- Has thanked: 9710 times
- Been thanked: 5764 times
Hi Brian,
WOW, that spot is really crackling ...
Well done
Well done
Thanks to all for your comments and thanks...always very much appreciated
Alexandra, the time of capture was 12:48 EDT, which if I converted correctly would be +4hrs to UT/GMT or 16:48UT. Does that make sense?
Based on the SpaceWeather report the main flare occurred at 15:35 UT, so I am over an hour past that time....likely catching the end of it.
Well done Brian for the SPOD and well-deserved with the excellent FD and close-up's.
Thanks for sharing
Thanks for sharing
Thanks Terry
