ImPPG performs Lucy-Richardson deconvolution, unsharp masking, brightness normalization and tone curve adjustment. It can also apply previously specified processing settings to multiple images. This time everything is wrapped in a full-fledged GUI, whose operation should be familiar to most amateur astrophotographers.
Some of the interface features:
- freely adjustable processing area (selection) within the image
- non-blocking operation; if you change the selection, previously started processing (if any) aborts and begins for the new selection
- for moderately small selections the application of Lucy-Richardson deconvolution is almost instanteneous, which allows for convenient fine-tuning of the "Sigma" parameter
- tone curve editor with helper functions (invert points horizontally to create a negative; stretch the curve to cover the histogram only)
Screnshots:
The "Prevent ringing" function is highly experimental and may not help in all cases. It aims to reduce ringing around overexposed areas (e.g. a solar disc in a prominence image); it does work quite well in the case I devised it for:
no deringing:
deringing enabled:
but your mileage may vary.
For now only BMP and uncompressed TIFFs (8- and 16-bit) are supported, but I'll add support for more formats (including FITS) soon. The program can be built on any platform which has a C++ compiler supporting Boost and wxWidgets libraries, including Linux (which I use on my laptop) and OS X. As usual, additional details can be found in the README file.
ImPPG is free & open-source, licensed under GNU GPL v3 (or later). Source code and Windows version (32- and 64-bit) can be downloaded from:
http://stargazerslounge.com/blog/1400/e ... processor/
All the material shown in http://solarchat.natca.net/viewtopic.php?f=4&t=14937 has been processed by ImPPG.
ImPPG - Image Post-Processor
- GreatAttractor
- Has thanked: 748 times
- Been thanked: 757 times
- grimble_cornet
- Been thanked: 47 times
Re: ImPPG - Image Post-Processor
Looks like a great front-end to what was already a very impressive bit of software
Mike Garbett
Mike Garbett
Hi Filip
thank you so much. I'll have a go with it for sure
- Has thanked: 20828 times
- Been thanked: 10502 times
an excellent resource, i shall have to give it a try!
Hi Filip
it works (tested it on a SAFIX test shot from friday) , but I do not understand it yet
- GreatAttractor
Walter, all there's really to do is play with the sliders
Of course, if anything is unclear, please post your questions here.
- robert
- Has thanked: 4 times
- Been thanked: 1275 times
Thanks! I have downloaded it and will have a try
Robert
Robert
- michael.h.f.wilkinson
I have been a great fan of ImPP for my mosaics, so I will give this further development a try as soon as I can.
Solar kit: GP-C8 with Thousand Oaks Solar filter, APM 80mm F/6, Lunt Herschel Wedge, Solar Spectrum 0.3Å H-alpha filter, Beloptic Tri-Band ERF (80mm free aperture), Thousand Oaks 90mm ERF, Coronado SolarMax II 60mm with Double Stack Unit. Lunt straight B1800 Ca-K module.
- GreatAttractor
New version: 0.1.1
Bug fixes:
– Blank output files after batch processing when L-R iterations count is 0
Download from: http://stargazerslounge.com/blog/1400/e ... processor/
Bug fixes:
Thank you Filip
