ImPPG version 0.6.0
GreatAttractor
Has thanked: 115 times
Been thanked: 31 times
ImPPG version 0.6.0
Post by GreatAttractor » Mon Dec 23, 2019 9:52 pm
ImPPG version 0.6.0 is available at: https://github.com/GreatAttractor/imppg/releases
New features:
  • GPU (OpenGL) back end for much faster processing
Enhancements:
  • View scrolling by dragging with the right mouse button (previously: with the middle button)
  • Zooming in/out with the mouse wheel (previously: Ctrl + mouse wheel)
My software:
My images
Has thanked: 2132 times
Been thanked: 816 times
Re: ImPPG version 0.6.0
Post by marktownley » Mon Dec 23, 2019 10:04 pm
Fantastic! Thanks very much.
rsfoto
Has thanked: 1497 times
Been thanked: 1072 times
Post by rsfoto » Wed Dec 25, 2019 7:16 pm
As I am always interested in different software solutions in order to improve my images I downloaded ImPPG and atarted to test it today.
I opened one of my AVI files and got the message
which is of course the worst error I can get ? I acquire my AVI using lucam Recorder and use a Lumenera Infinity 2-2M camera.
Is there a way to solve this problem ?
Post by marktownley » Wed Dec 25, 2019 7:32 pm
ImPPG is for image files (jpegs, tiff etc), not movie (avi) files Rainer.
rsfoto
Post by rsfoto » Wed Dec 25, 2019 7:43 pm
Hi Mark,
Thanks :shock:
GreatAttractor
Post by GreatAttractor » Wed Dec 25, 2019 8:22 pm
Hi Rainer,
That's right, ImPPG is for post-processing of stacks. So you must stack your AVI first (e.g. in AutoStakkert), and then you can open the resulting TIFF in ImPPG. On the home page you'll find links to a few tutorials:
http://greatattractor.github.io/imppg/
My software:
My images
rsfoto
Post by rsfoto » Wed Dec 25, 2019 9:08 pm
Hi Rainer,
Thank You. Will play a bit inorder to see if it gives better images as I am getting now.
I process my AVI's in AviStack v2.0 including Wavelets and save them as TIF.
Thanks again ...
Post by marktownley » Wed Dec 25, 2019 9:22 pm
I'd miss out the wavelets and go straight to ImPPG for sharpening
GreatAttractor
Post by GreatAttractor » Wed Dec 25, 2019 10:22 pm
Indeed! It will work best with raw, unprocessed stacks.
Though one could do the primary sharpening elsewhere (e.g. wavelets in Registax) and then just touch up in ImPPG (probably with L-R disabled, just apply unsharp mask and modify the tone curve). In any case, whenever you can, use high bit-depth images as input (16 bits per channel or more).
My software:
My images
rsfoto
Post by rsfoto » Thu Dec 26, 2019 12:01 am
I will test with my TIF images with no wavelets.
