Page 1 of 1
ImPPG version 0.6.3
Posted: Thu Apr 15, 2021 7:21 pm
by GreatAttractor
Download from:
https://github.com/GreatAttractor/imppg ... tag/v0.6.3
Enhancements:
- Opening an image file by dragging and dropping onto the ImPPG window
Bug fixes:
- Crash when batch processing in CPU mode with deringing enabled
Re: ImPPG version 0.6.3
Posted: Fri Apr 16, 2021 5:16 am
by Carbon60
Many thanks for all your great work developing this software.
It really is very much appreciated.
Posted: Mon Apr 19, 2021 2:46 pm
by EGRAY_OBSERVATORY
Also thanks from me for your efforts in developing this version.
I hope to start using it soon.
Best Wishes
Posted: Sun Apr 25, 2021 6:55 am
by christian viladrich
A big thanks for this very nice software !
Christian
Posted: Sun Apr 25, 2021 11:28 am
by Montana
Posted: Sun Apr 25, 2021 1:22 pm
by MalVeauX
Huge thanks for keeping this going, great software, the GPU optimization was such a huge leap!
Posted: Mon Apr 26, 2021 3:51 pm
by Rusted
A huge thank you from me as well.
ImPPG is the only software which will save the day in poor seeing conditions.
Today was a perfect example: Same image: Before and after ImPPG:
- Capture 2021-04-26T16_06_07_l3_ap4680.jpg (24.3 KiB) Viewed 3282 times
- 26042021 16.06 no gpc.jpg (55.62 KiB) Viewed 3282 times
Posted: Mon Apr 26, 2021 7:48 pm
Thank you Chris and I will now try my latest of the same regions as yours, to see what it does for me..
Cheers
Posted: Mon Apr 26, 2021 8:14 pm
Ok a few minutes later than my previous here - with a basic-start to a posted-image since redone with imppg and for a start is a welcome improvement.
Will do more trials with any different settings available in imppg.
Thanks for the reminder Chris and of course Filip/GreatAttractor - Thanks Very Much.
Posted: Tue Apr 27, 2021 11:41 am
by Rusted
Your ImPPG version is over-sharpened. Leading to uniform and unnatural artefacts.
ImPPG should ideally be used just after your stacking software.
Posted: Tue Apr 27, 2021 3:44 pm
Thank you Chris and yes this was done in a hurry and is still in the leaning and experimental stage of use.
Last night was a very-busy time for me with lots to do's...
Cheers
Posted: Tue May 04, 2021 2:50 pm
by Radon86
Hi Filip,
Thanks for the great work on this software.
I just wonder about the following things.
1) Can you specify LRD separately from unsharp masking ? I mean I would like to do one with out necessarily doing the other.
2) Can you include a histogram display feature ? I think having a histogram would be advantageous. I hope you can do this for the next update !!
Thank you.
Magnus
Posted: Tue May 04, 2021 3:36 pm
by GreatAttractor
Boso36 wrote: ↑Tue May 04, 2021 2:50 pm
Done and done
1) Both can be disabled independently. To disable L-R deconvolution, set the number of iterations to 0 (or just click the "disable" button). To disable unsharp masking, set the "amount" to 1.0 (values > 1.0 sharpen, values < 1.0 blur), or just click "reset".
2) Histogram (of the current selection) is displayed in the background of the tone curve window. It applies to the image after all processing steps BEFORE the tone curve application.
Posted: Tue May 04, 2021 4:35 pm
by Radon86
GreatAttractor wrote: ↑Tue May 04, 2021 3:36 pm
Done and done
Thank you Filip,
I shall have to read the manual again for ImPPG.
On another note, the Tone Curve editor seems to have disappeared. How do you get it back ? It happened before a long time ago now.
Many thanks.
Magnus
Posted: Tue May 04, 2021 4:44 pm
by Radon86
Hi Filip,
I found the Tone Editor reset window position command.
I will have to learn ImPPG again now !!
Magnus
