The east is clearly under haze up to the center of Mars. Some beautiful cloud baths can also be seen in the north.
C11, TV 2x Powermate, GKC ADC, ASI290mc + UV / IR cut filter. Lum: ASI290mm + IR Pass 685nm
CS, Jozef
Mars 30.10.2020
Moderator: Montana
- Has thanked: 57 times
- Been thanked: 1189 times
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
- Has thanked: 17667 times
- Been thanked: 8789 times
- Been thanked: 4900 times
Re: Mars 30.10.2020
As you say Jozef, the coloured version does seem better, so very well done and thanks vm for sharing
Regards
Regards
- Been thanked: 4340 times
Re: Mars 30.10.2020
Excellent images Jozef
- Has thanked: 8418 times
- Been thanked: 8161 times
Re: Mars 30.10.2020
I’m always impressed by your images, Jozef. Having tried imaging Mars myself (and failing to achieve anything remotely acceptable) I can appreciate the skill here.
