Using different settings in Autostakkert 3
- Been thanked: 8905 times
I am probably saying something here that maybe all of you take for granted because I seem to be the only person struggling to stack images from larger apertures. It all started when I noticed that my eyes could see detail in the video but the stacked images never ever showed what my eye could see.
I have done two tests so far, I have yet to try on Halpha but I think I have other problems there as well.
First CaK with the C11 stopped to 9 and 3/4 inch to get rid of aberration. These were taken with the 2.5x Powermate but even with a flat you can see that processing in the middle is compromised. 6000 frames and 5% taken for stack
NR = Quality estimator - Noise Robust
Br = brightness setting in the AP (alignment point box)
As you can see in the CaK it is very important to use a high NR and I feel a brightness on the high side. This is very different to my standard of NR 4 and Br 35 I would use with the TEC.
However for white light NR7 is still the best but I thought the Br on the low side was maybe better? These are still horrible pictures and look nothing like granulation so please don't comment about that. WL full aperture Baader film 3x Barlow (Televue). 6000 frames and 5% stack
So I tried NR7 and Br10 on last years problem WL file and it was a reasonable improvement, so I feel I am slowly making progress.
But still no where near a single frame So the message here is your image is only as good as the stack, if the stack is rubbish then it doesn't matter what processing you do, it will still be rubbish. Experiment with the ASK3 settings.
My rule of thumb is that the stack should be a good representative of what your eye can see in the video or a single frame, it shouldn't be worse than the input. But maybe you all know this anyway and you will laugh at me, but I thought I would share.
- Has thanked: 38 times
- Been thanked: 185 times
Re: Using different settings in Autostakkert 3
Can’t comment on your CaK but for your WL image, have a look to see how many alignment points are used (assuming you don’t apply them manually) at the two different min bright settings. I can’t imagine it will be a very big difference between the two as it is not a particularly big brightness change.
Freddie
Ha: 152mm, Quark, ASI174m
WL: CPC9.25, ASI120m
- Has thanked: 9710 times
- Been thanked: 5769 times
Hi Alexandra,Montana wrote: ↑Tue Apr 28, 2020 5:36 pm I am probably saying something here that maybe all of you take for granted because I seem to be the only person struggling to stack images from larger apertures. It all started when I noticed that my eyes could see detail in the video but the stacked images never ever showed what my eye could see.
Interesting. Would you upload the videos somewhere ? I would like to try them in AviStack.
Or you can send them via wetransfer wich accepts up to 2GB free.
Thanks
- AJamesB
- Has thanked: 1154 times
- Been thanked: 630 times
My final stacks always look worse than my better/best individual frames, but after deconvolution/sharpening they then look better than the best frames. Could be another area to look at for improvement of final images.My rule of thumb is that the stack should be a good representative of what your eye can see in the video or a single frame
Only other thing I can think of is what Freddie mentioned, looking at the number and size of alignment/stacking points you use. If detail is good, I use small alignment points, and a lot of them, to try and isolate the good pockets of seeing. If too large they sometimes can get lost amongst the rest of the average seeing.
Would be fun to play with a video of the best 5-10% of the 6,000 frames to see what we can do with it.
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- Has thanked: 128 times
- Been thanked: 121 times
Are the two sunspot details images straight out of AS3? The first one looks like it has deconvolution artifacts more than stacking artifacts. The second one looks much better.
The brightness level should only affect the number of alignment points that are produced when you click Place AP grid. Try setting the number very low on a full disk image some time and watch what happens along the edge of the Sun when the AP grid is generated.
Just out of curiosity, About how many alignment points do you shoot for?
- Been thanked: 2725 times
Hello Alexandra,
It is difficult to comment on these since we would need to know what are the other settings of AS3 ?
- use of Local / Global ?
- use of double stack reference ?
- AP Size ?
The "min brigthness" adjustement is just to say to AS not to put any alignement point on places of the image where the intensity is lower that "min brightness". If set too high the darkest regions are not considered.So this might be an image of very dark images (like Ca K).
Have you checked whether you have alignment points all over the image ?
- AP Size ?
- Has thanked: 8544 times
- Been thanked: 8281 times
Hi Alexandra,
As Christian says, the brightness adjustment changes the threshold that defines where alignment points are placed. I adjust this (upwards) to avoid placing points in the blackness of space for FD images or prom shots. I've never adjusted the NR setting and just use the mid-range. Maybe I should take more notice of this.
This is a snapshot of my settings, rightly or wrongly.....
- Been thanked: 4423 times
Great review of the settings in the software...a nudge for me to look at mine !!!
- Has thanked: 20783 times
- Been thanked: 10467 times
Hi Alexandra,
So, my understanding of what the different settings do and how I use them based on what I do.
Improved tracking feature if de-selected means when the software is doing the stabilisation routine, does it using 2x2 binning, if it is selected then no binning used. Deselected has the advantage of speed being quicker, selected means it will take 4 times longer (remember an image is 2 dimensional). Deselected is better if the image is jumpy (scope shake) or the seeing poor, selected in this situation can take a verylong time, and sometimes won't work. I generally only use selected if I have got particularly good data, or, don't have time constraints for processing (which I often do!)
Laplace I think you are going wrong here Alexandra in places. If look at the numbers says the following; 8 focuses on big features (resized data), 7 oversampled data, 6-4 normal range, 3 -2 focus on very small (high SNR data!). Lets think about what this is telling us:
8 would be the setting used if a files native frame size was (for example) 640x480 but the software resampled it, so it played back at 1280x960. This is the equivalent of if you looked a picture in photoshop at 200% zoom, the image is twice the size but only the same amount of detail is there so it looks blocky and lacking in resolution. I'm not aware of capture software that does this, so my advice avoid.
7Refers to oversampled data, this is when the pixel size of the camera is too small to ideally sample at the scale you are imaging at (Nyquist), so, for example if you were using an ZWO290M to image with a Quark. The camera is suited to imaging at f15 ideally, but with a Quark you are f30. Poor seeing also mimics the effect of oversampling - the blurring of data, so, looking at the WLs you post it makes perfect sense if you are pushing it with the seeing, and, in the WL you are imaging at f35 which is borderline oversampling. So, to me, makes perfect sense you are getting best results in WL at this value.
6-4 Normal range - Seeing is OK, not particularly oversampling or undersampling. For my CaK and Ha I normally use 4, as I make a point that pixel size is good for image scale (sampling - longer focal ratios = bigger pixel size, smaller focal ratios = smaller pixel size). If the seeing is bad I find for me '5' works better. I only ever use '6' on prom shots.
3-2 If when using AS3 I find I have some files that are particularly good data (rare!) I set laplace to 3 as it has a better SNR, generally this would only be in CaK as features have a higher constrast than the more subtle grades of Ha. Caveat!!! Setting too low and AS3 focuses on noise and will look at those transient pixels of noise and stack these resulting in noisier final images. 99% of the time I never use '3' and 100% of the time do not use '2' Someone using a IMX174 chip to do full disks (where the disk ends up being say 700-800 pixels mid frame) with a short focal length scope would do well to use lower (3-4) laplace values as the image is undersampled.
I always use 'local' rather than 'global'. I have read people get good results from global in really poor seeing, the software uses the frame as a whole, rather than alignment points to determine the reference frame.
Double stack reference I don't find any improvement in using it, it does however take longer to process a file, so again I avoid.
Auto size I always use checked.
Min Bright I always have set to zero now, faffed around with it in the past and found the only thing it does is reduce processing time as fewer APs are being placed (in the black sky for example). Sometimes, particulary with proms the sky background can have an uneven chess board gradient to it and if this the case and really want to get that image I may raise the value to reduce it.
AP size My general rule, the worse the seeing the higher the value. For my Ha and CaK full disks under normal conditions (laplace4) I use a AP size of 48 and 'multi scale', this gives me around 17000 alignement points. This is with the 9.1Mp Grasshopper, with the 2.3Mp (IMX174) Grasshopper which I use at F20-30 I use the same size. If the data is brilliant raw data I may go for 24 for the AP size, if the data is bad I raise the value beyond 48. All seeing dependent.
Looking at the pics you have put up I would go with a laplace of 7 for the whitelights, however looking at the CaK (I think!) you're miles off with a laplace of 2 - the data definitely isn't high SNR! - maybe a 5, possibly a 6, but it doesn't look good seeing to me. Poor seeing effectively has the effect of gaussian blur on the data we record, and this has the same effect as oversampling.
I would go as far as to build on your conclusion, the final image is only as good as the stack and the stack is only as good as the seeing. My take in this to everyone is don't go chasing ghosts in seeing. I often see great views on the monitor - but, this is rarely (in my conditions) the whole image just a part, and that is where the eye is drawn. My eye is always drawn to the bottle of 18 year old single malt on the shelf in the shop, but in reality i'm more likely to come out with the 12 or 15 year old...
Just my thoughts and ramblings!
Thanks everyone, I have never really understood all the points in ASK3 and wanted to investigate, so thank you Mark for a wonderful desciption of what everything means.
I have seen appalling videos on the web and then seen miraculous stacks they have produced from them (I've thought WOW mine are better than that!). I have found it unbelievable when I see lovely detail by eye in my videos compared to theirs and yet my stacks are rubbish. How do they do it?Particularly like in the above example of the sunspot, image one is a stack (with dust bunnies and all, yes sorry about that) and the second is a single frame from the video.
So, the take home message from you guys is - don't believe the videos on the web? you will never get a good stack unless the video is perfect?
So some points to answer:
It is impossible to upload and share a video, the sunspot is 9GB and the CaK or WL videos are 13GB, that would take me 12hrs to upload somewhere.
The change between brightness at 10 to br at 40 was about 5,800 alignment points to 6,100, so not much difference. I usually use AP size of 35.
Yes, stacks always look worse than the video until you sharpen it, but really the sharpened image should look just as good (not worse) than the best frames in the video. The first sunspot picture is a stack, the second is one single frame only. For this video it was better not to stack but work on one frame only.
I've only ever used local, results from global were always terrible so never used this.
never heard of the double stack ref before?
I wanted to try Avistack but I can't use it anymore as it says that I do not have a licence to use it.
Thanks for your help, I guess I need perfect videos which will never happen
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Hello Alexandra/Montana,
I have a similar problem with Autostakkert!3. It is usually really good. However, I still don't know how the frames are assessed in terms of quality, and which frames are good, and which frames are bad. I tried scrolling through the video file after Step 2: Analysis. The window says the frames are arranged in order of quality, but I don't know if it can do that so quickly, sorting in order over 1000 frames in a matter of seconds?
I came across one of GreatAttractor's other software which gives you more control - Stakistry. You can select the frames you want, and I suppose give you the option of just stacking those. It might take longer, but in the current lockdown, unless you are working long hours, there is time to try this out. I will try this out.
https://github.com/GreatAttractor/stackistry.
https://www.youtube.com/watch?v=_68kEYB ... L39z78zwdE
If you look at a video file, there is sometimes lots of movement from 1 frame to another, with a lot of blurring. It would be interesting to correlate the movement of the frame with respect to local or atmospheric conditions, including the jetstream. Measuring the movement in number of pixels could be possible.
Thanks for your helpful advice, Alexandra, I will post my Quark calibration files when I can manage to go through those videos !!
Magnus.
London
Magnus.
London
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
Frames are assessed for quality in terms of their overall contrast, the sharpest frames will have the highest contrast, a poorer frame has lower contrast as details are blurred due to the seeing.
- Radon86
Hi Mark,
Does Autostakkert!3 actually rearrange the frame order according to the quality graph in the centre of the main program window ? When you scroll frame by frame on the right window (the Image video), is the frame you see as you go from frame to the next frame, ranked in order ?
Thanks.
Magnus
Thanks.
Magnus
- banjo
- Has thanked: 2100 times
- Been thanked: 2877 times
Good morning all,
I may be off topic, translation problems.
I note that the quality value is not always optimum, if we scroll image by image we see that sometimes bad image is in the first positions.
Another factor to take with it is the number of images stacked in the end, I sometimes take only 20 to 100 images rather than percentages, you will also have to try that.
On my message today the photo "soleil-b-29avril20" is only the stacking of 33 images out of 1000.
sorry if my message is unrealistic, google translator is used.
Paul
Paul
Mark - Thanks so much for the very helpful AS info
Magnus - AS does rearrange the frames. In the example below, I have performed the analysis on a 1000 frame SER file. In the image frame on the right, note that I moved the Frames slider just a bit to the right and that the frame number window to the right of the slider says that it's positioned on the 21st frame. Since the analysis has finished, this is now the 21st best frame in the file. The blue arrow points to the frame information area, providing more details. The actual frame number (in the original file) was #676. It is now placed as number 21 out of 1000 frames.
One other important AS tip. Now and then AS will choose a frame as having high quality when it actually doesn't. A bird flying by can cause the problem for example. Basically, AS (and SharpCap too, but I don't know about FireCapture) treats the difference between darkest and lightest as the measure of contrast. One time I accidentally walked in front of the telescope and the frames were selected as being very high quality.
When it is necessary to remove a few frames, particularly random frames, from analysis, you can scroll through the frames using the Frames slider. Click in the slider area. You can then use your arrow keys to move through the file one frame at a time. If you know about where the problem is, go there using the thumb of the slider, then use the arrow keys to find the problem frame(s). To eliminate a single frame, press the space bar. The green area under the slider will turn red, indicating that the frame will be skipped. You might have to click on the slider again to keep scrolling through the file. Eliminate all problem frames _before_ doing the Analyze operation. Usually what happens though is that you realize that something has gone badly wrong only after seeing the stack, then you have to go back, find the problem frames, nuke them, and start with Analyze again.
Hi Alexandra,
You wrote
Here you can download the AviStack 2.0 version which is the one I use
http://www.avistack.de/download.html
You wrote
It is freeware and there is no license needed.I wanted to try Avistack but I can't use it anymore as it says that I do not have a licence to use it.
- Has thanked: 174 times
- Been thanked: 619 times
Another thought I have is that when long AVI’s are used, say 3000 frames the “best” 100 or 5% etc will be taken from the whole AVI - some may be at the beginning, some in the middle and some at the end. To me this could lead to surface, or prom movements being blurred due to movement in the detail during the AVI.
What if a series of shorter AVI’s were taken, the best from each then used to make up an image. We could then compare each image and look at the result of adding them together.
Make any sense?????
Make any sense?????
- Radon86
Just looking at Stakistry to isolate frames and have a more controlled way of assessing individual frames.Bruce G wrote: ↑Thu Apr 30, 2020 3:04 pm Mark - Thanks so much for the very helpful AS info
Thanks for this, I shall have to investigate AS!3 more.
Magnus
