1h Animation of many solar activities, 17 June 2021
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Hi all,
Today the seeing was acceptable (average SSM 1.6-1.7", with minima @ about 1"), so my plan was to make a "very" long H-alpha animation where the sunspot, surface activity, dancing proms and filaments and if possible even the sun's rotation would be all visible. I masked the Lunt130MT @102 mm and there we go!
My 1T hard disk (some 800G free) became full with 130 frames taken during exactly 1hour, plus 5 captures for photos. The resulting Animated GIF, although heavily cropped, was still some 125MBs. I thought it was really worthy to upload it, but should find a way to make it a smaller file. It took me 3 hours... :-( I converted the GIF to m4V and became 6.3MB!!! Wow I said! But then how to make it continuously looping? Impossible! I had to reconvert it to GIF (30MBs), but the quality was dropping significantly. At the end I found out that QuickTime is supposed to export it to looping .mov. It does loop on my desktop and it is just 6.4MBs!!!
I hope it loops when uploaded here as well...
Many active solar features! The proms are dancing (other slowly, other rapidly), the central filament is "smoking", the surface is boiling, and if you focus at the bottom right corner you will observe the rotation of the sun!!! It could be a much more active day (hope such days are ahead of us), but I am already very happy I have it "all in one"! :-) :-) :-)
I just realized .mov appears here as a link and does not play automatically... :-(. If you click on the link below and chose to open it with the Windows Media Player (hopefully other media players too), it will play immediately and will be looping only if in you turn your player's option to loop. :-( Or just click on "Play again", as long as you want to watch it again.
The original in full resolution and no compression is much better but still hope you like it.
Best wishes,
Alexandros
Best wishes,
Alexandros
Alexandros
Greece
Greece
- viewer
- Has thanked: 233 times
- Been thanked: 23 times
Re: 1h Animation of many solar activities, 17 June 2021
Very nice! Especially the filament lifting off is amazing.
Eq-2 mount on the balcony, pst, mak with baader filter, zoom, camera asi290mm
Sketches and images: https://www.cloudynights.com/gallery/me ... 07-viewer/
- Has thanked: 17449 times
- Been thanked: 16548 times
Alexandros,
This is both well done and beautiful! Nothing shows the Sun like a good animation and yours is excellent!
Despite the hazy patch in the objective lens the Lunt 130MT seems to work well.
- Has thanked: 1262 times
- Been thanked: 1057 times
Amazing movie, Alexandros!
Big work well done, very clear view. Could you describe in brief, how did you make batch processing?
thanks for sharing
Leo
thanks for sharing
Leo
- banjo
- Has thanked: 2070 times
- Been thanked: 2833 times
sorry for my English translators google
- stef41
- Has thanked: 120 times
- Been thanked: 1476 times
magnificent animation of a great fluidity!
bravo!
Sincerely,
stéphane
bravo!
Sincerely,
stéphane
- Has thanked: 9074 times
- Been thanked: 5976 times
Excellent work Alexandros. Love the animation.
- Has thanked: 17521 times
- Been thanked: 8761 times
This is your best ever!! I really enjoyed it, so much going on and it loops great
- H-Alpha
Thank you all so much Viewer, James, Leo, Paul, Stephane, Franco, Alexandra, for your nice words and encouraging comments!
1) First I stack them all directly in Autostakkert!3 (all at once in a batch process that takes a lot of time, but do not need me to be there :-) )
2) Then I take one stacked image (usually the first) and try to find the best settings in ImPPG to improve it in the best way I can.
3) When happy with the result I save the ImPPG settings
4) Then I improve all the stacked images (batch processing...) in ImPPG. To do this, I have to load the ImPPG settings previously saved and indicate the folder with my stacked images, plus the output folder.
5) Then once more in ImPPG, I align all the improved (stacked) images and save them in a different folder.
6) Next comes Photoshop where I further improve them and add colour. I do this automatically in batch process. I have previously created an Action in Photoshop that does all (Hi-Pass, Levels, sharpenning, shadows, Colour etc. are used following Marty's tutorial in Youtube) at once. This is my standard improvement and not repeat it with each separate animation. I always use the same. To make the Batch process in Photoshop there is a a menu under File/Scripts/Image processor, where I indicate my Actions, folders with the files and output format (I use jpg, quality 12).
I will try to find the way to perform this step 6) in GIMP instead of Photoshop, but did not have the time yet.
7) now I finally have all my coloured final frames and open them as Layers in GIMP. Here I only make a final crop if needed and then create the animated GIF. In Filters-->Animation a have a preview and then in Export As I create the Animated GIF, et Voila! :-)
I hope it helps. It took me a while to find all these paths and little 'secrets', but I am so fascinated with what we can all do with our solar scope and see the sun alive, that could not stop until I find the way. Of course, I have been helped a lot by questions like yours that I made here to people of our wonderful solarchat community, who are always very willing to help and share!
Best wishes,
Alexandros
Dear Leo, thanks for your interest. I try in brief ;-) below and if you need further details please do not hesitate to come back.
Best wishes,
Alexandros
Alexandros
Greece
Greece
- Ivan
- Has thanked: 3461 times
- Been thanked: 2250 times
Hello Alexandros
It's just amazing to watch this sozheo endlessly, wow. Congratulations, you have a masterpiece.
Why did you aperture up to 100mm?
Ivan
Ivan
- Been thanked: 4877 times
Alexandros:
Superb animation.
Thanks for the info on how to make an animation.
Never have made one.
Superb animation.
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 753 times
Excellent animation.
It seems that penumbral waves are visible around the sunspot (similarly to here).
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Great animation, you have done an excellent work. I follow the same steps for my own animations but I use GIMP instead of PS for generating the gif.
- H-Alpha
Thanks a lot Ivan, Eric Filip, Raf, Peter for your kind words!
I am glad you liked the animation and observed so many things.
@Ivan: My scope is 130mm and I mask it at 102 mm quite often, because the seeing is not so good, or it is not good lomg enough for a long animation...
@Eric: You are very welcome! You have to try. It's a lot of fun. Great expectation and curiosity until you the final result... ;-) And then the sun becomes alive!
@Filip: Thanks so much. I wasn't aware of the penumbral waves! And now see there's a lot of scientific work on them. In your animation they are fantastic! In mine they are just visible. i will try to run it faster to see if they are easier to see. ;-)
@Raf: Independent paths of parallel evolution! ;-) :-) :-) Actually I also generate the gifs in GIMP. I only put some filters and colour in PS before GIMP.
Best wishes,
Alexandros
Best wishes,
Alexandros
Alexandros
Greece
Greece
- minhlead
- Has thanked: 734 times
- Been thanked: 1097 times
Great work, Alex.
How come your raw video so big? I see that you are using a 290MM which have relatively low res. How many frame you are capturing each shot?
Minh.
Loves from Viet Nam <3
My gear:
Scope: SkyRover (Kunming Optics) 152mm F/6 Doublets
Mount: JTW Tridents GTR
Camera:
PlayerOne Apollo M-Max
Quark Chromosphere Doublestacked with PST etalon
My gear:
Camera:
- cmas
- Has thanked: 294 times
- Been thanked: 248 times
I'm gonna say it in a short way: WOW!
H-alpha: Baader D-ERF, Sharpstar 61 EDPH II, Altair Astro 102 f/7, Quark, reducer and ASI174mm.
White light: Baader ASSF 115, Sony SEL 200600G, Sony SEL20TC, Sony A7iii.
Images in AstroBin
Images in Flickr
Images in AstroBin
Images in Flickr
Thanks a lot, Alexandros, for detailed explanation!
Next time I´ll try ImPPG instead of AstraImage and compare the result. As to me, for animation usually I take 200 frames from 1000 every 30 sec, sure if seeing is stabile.
regards
Leo
regards
Leo
- H-Alpha
Thanks a lot for your kind words Minh, Tommi, Leo,
All the best,
Alexandros
Thanks Minh. The ASI290MM gives 1936x1096 videos. Is this what you had in mind? I capture 3000 frames per shot and this creates files of 6.2 Giga when the frame rate (depending on the exposure) is about 170 fps. What does not seem right for you?
All the best,
Alexandros
Alexandros
Greece
Greece
- minhlead
The file is too big. Are you capturing in 16 bits? If so lower the bitdetph to 8. You can recover some bitdepth by stacking.H-Alpha wrote: ↑Sat Jun 19, 2021 7:10 pm Thanks a lot for your kind words Minh, Tommi, Leo,
All the best,
Alexandros
Also 3000 frames seems excessive for animation. I think 1000 will do just fine. Just my 2 cents
Minh.
My gear:
Camera:
My gear:
Camera:
- AJamesB
- Has thanked: 1150 times
- Been thanked: 630 times
Excellent animation, love it!
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- H-Alpha
Thanks a lot Minh and James!
[/quote]
[/quote]
Minh, your input is always very welcome. It was you that inspired me to try long animations. ;-)
Today I tried 2 hours and you will see the post/results. I just realized what you said the other day! and I also took my lesson...
Regarding file size..., I capture in 8 bits. Cannot go further down :-( The seeing would not allow to drop to 1000 captures most of the days; if not some frames would not be clear at all! :-(
Best wishes,
Alexandros
[/quote]
[/quote]
Best wishes,
Alexandros
Alexandros
Greece
Greece
Alexandros,H-Alpha wrote: ↑Fri Jun 18, 2021 1:48 am Hi all,
1h, 130 frames, Animation Cropped, 2021-6-17.mov
Best wishes,
Alexandros
Looking at this animation, I can say with a confidence that your problems with a good quality of High Res images with C8 are definitely not the only seeing as the reason. You need a full size DERF, perfect collimation and focusing, good Ha etalon, SSM and then hunting for best seeing in hours when a good seeing moments are most frequent (early morning before 9:30 and 1-2 hours before sunset).
- Has thanked: 1640 times
- Been thanked: 878 times
Very nice animation. There is a lot of activity.
- H-Alpha
Thanks a lot Valery and Alan!
@Valery: Capturing early in the morning is not an option from my balcony. :-( No sun view in those hours... The Hi-Res and a DERF for C8 is of course in my list, but I should first be certain that I will be able to get clear images with it, when all other factors will be under control. Once I will have acceptable WL with C8, I will make the DERF step.
Best wishes,
Alexandros
Best wishes,
Alexandros
Alexandros
Greece
Greece
