Early morning July 6th
Had to get an early start before the wind and cloud blew in from the Thunder down Under......John. its here!
seeing was average, but a good bit of practice to get my processes better!
The 5" mod seems to be working well. Cant wait for some great seeing!
John, I thried to get the DS more even....then chucked the ds off to the side and shot the FD single. Im thinking Im selling the ds portion! Tired of messing about with it!
- sun_091909_g3_ap2249scc.jpg (66.37 KiB) Viewed 1537 times
- sun_091537_g3_ap1071sc.jpg (91.51 KiB) Viewed 1537 times
- sun_091411_g3_ap1196sc.jpg (64.74 KiB) Viewed 1537 times
- solardave
- Has thanked: 10 times
- Been thanked: 219 times
Re: Early morning July 6th
Nice images rob
tak 102fs solarmax40 ds es ed80 cornado 90mm filter bf10 bf 30 skynyx 2-2 mono camera lunt 2inch wl wedge lunt b1800 cak mod
- Been thanked: 8792 times
Wow! these are nice
What is wrong with the DS? I wouldn't be without one now.
Thank you Alexandra!
Im finding it nearly impossible to tune the front etalon without having huge issues with even brightness/on band.... With tilt tune fronts its almost impossible to keep the disk even.... Its driving me nuts!
That is one of those things ive just never been able to overcome!
Thanks buddy!
My 60 is pressure tuned like yours, but the front ds unit is tilt tuned. Thats the one that causes the uneven coverage! Damn thing sucks. Lol
- solarchat
- Site Admin
- Has thanked: 83 times
- Been thanked: 1317 times
you will never overcome the uneven illumination with a full disk image and tilt tuned etalon. Its the nature of the optics. This is also what gives the older Coronado's the unmatched 3D look when you use a big double stacked 90. The uneven illumination is aesthetically pleasing and our eyes can adjust each pixel to compensate.
Why not just image with the single pressure tuned etalon? You should be able to get most of the same details with some camera and PS skills. In fact, the prominences will be far easier to capture.
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Atlanta, GA USA
The FD above is just the pressure tuned 60 single. I found it does get nice detail with the dmk51 if its set correctly! Im just going to use my ds unit for visual use.
Or maybe....... A new mod unit is about to be pulled apart?
- Been thanked: 4904 times
Thanks you Eric!
Thanks John.
John in DS with a powermate, the results are great. It does a great job on active areas..... As far as mosaics. Its me john. I just learned how to black out prom shots!
Thanks John.
- Been thanked: 4340 times
Superb images Rob
Hi Rob
very fine results
very fine results
- solar
- Has thanked: 192 times
- Been thanked: 1245 times
Pretty nice results Rob.
Vixen 130ss SolarMax 90 BF30 EQ6 Pro, LX200 14, C8 CG5, Megrez80, Lunt 100 DS. EQ 8
ASI 120mm 290mm 432mm Lunt B1800 Cal-K + other stuff.
Skywatcher 150mm PST Mod2
- Has thanked: 20442 times
- Been thanked: 10248 times
Good shots there Rob!
