AR12297 Through a Pollution Sunset 17th March
- Has thanked: 20948 times
- Been thanked: 10588 times
The weather for me lately has been awful - just persistent grey skies, day after day, soooo frustrating. Anyhow, the forecast for yesterday afternoon was for it to go sunny somewhere between 4-5pm, so after a busy day at work I decided to just get home and hope for the best. Well the skies did clear, but it was hazy, very hazy, infact the sky just had a yellow tinge to it, that just kept getting yellower the closer the sun got to the horizon. This is a 'pollution sunset' - Haze can form from a variety of sources, commonly industrial pollutants, desert dust or sea salt. The result of these small particles in the air gives a murky blue-grey appearance to the environment. On this occasion, the recent south-easterly flow which has affected the UK has brought air across the country from the industrial heartland of Europe. This has mixed with our own local urban pollutants, and with wind speeds very light under an area of high pressure, has added to the dull visual conditions.
To put it in perspective, my usual exposure settings with the quark on the ED80 are 1/30s and minimum gain (260 on a PC and IC Capture), but yesterday the histogram was telling me there was a lot of light missing, and to get to my usual levels I had to have to gain up at 900 (out of 1024 I think), the live view looked like there was 'snow' all over the image, or as is the 'dissolve filter' in photoshop was in operation. Somewhat disheartened by this I recorded away, as was setup and well, some sun is better than no sun!
Enter the magic of stacking software. Normally I record 300 frames and stack 50, today decided to record 1000 and stack 250 to try and average away the noise. I knew the results were never going to be perfect, but they surprised me in the sense were better than I thought they were going to be:
ar12297-departing-bw by Mark Townley, on Flickr
ar12297-departing-invert-colour by Mark Townley, on Flickr
Woke this morning to freezing fog (and more grey skies!), with that forecast set to stay with us again possibly for another week, apart from maybe, just maybe, a few breaks on friday morning, let's see!
- Been thanked: 171 times
Re: AR12297 Through a Pollution Sunset 17th March
Mate you need to move.A good result despite the conditions
- Has thanked: 2 times
- Been thanked: 101 times
Nice detail there Mark. I agree with Derek, you need to shift to a warmer climate - maybe to Aussie?
George
George
DS External SM90 Etalons, Single External SM40 Etalon, BF30, WO FLT98 f/6.3, Tak FS-102 f/8, Tak FS-60C f/5.9, DMK51, DMK21
- michael.h.f.wilkinson
Very nice detail. Great filaprom. I must say the conditions here also make me want to move to the Provence or so once I retire (years away still, but a man may dream)
Solar kit: GP-C8 with Thousand Oaks Solar filter, APM 80mm F/6, Lunt Herschel Wedge, Solar Spectrum 0.3Å H-alpha filter, Beloptic Tri-Band ERF (80mm free aperture), Thousand Oaks 90mm ERF, Coronado SolarMax II 60mm with Double Stack Unit. Lunt straight B1800 Ca-K module.
- mattwastell
- Been thanked: 72 times
These came out very well - I hope you get a shot as the AR rounds the limb & flares for a loop prom......well we can hope!
- solardave
- Has thanked: 10 times
- Been thanked: 219 times
nice images mark good job
tak 102fs solarmax40 ds es ed80 cornado 90mm filter bf10 bf 30 skynyx 2-2 mono camera lunt 2inch wl wedge lunt b1800 cak mod
- grimble_cornet
- Been thanked: 47 times
Amazing results considering the conditions Mark
I was out on my drive at the same time testing out the new TS 'cheapo' x0.5 2" reducer on the Quark and had exactly the same problems with thick haze
I only had about 5 minutes between the sun coming out and it dipping below the house opposite so just grabbed a few shots with the Lunt60 plus Quark.
Good news is that the 'Chinese ring puzzle' seems to work giving a much more evenly illuminated fov than I get when using a normal nose-piece on the camera - direct coupling is clearly the way forward.
Difficult to judge the reduction factor but I suspect it was about x0.7 so need to play with the reducer-sensor distance when the sun is available
Mike Garbett
Mike Garbett
Hi Mark
what a thuesday story. I can feel with you. About 50% of our pics have snow in it too
we (Orphelia, Barbara and my selfe) suggest you move to the Kanton Tessin
- Has thanked: 8588 times
- Been thanked: 8324 times
Lovely images, Mark, despite the conditions.
Good luck for Friday morning......fingers crossed!!
- Has thanked: 18105 times
- Been thanked: 8941 times
These are absolutely fantastic considering the conditions, you work miracles
Thanks everyone! Direct coupling is most definitely the way forward with the Quark, I shall be doing a write up on it probably over the easter break when I have a bit of time.
- Has thanked: 65 times
- Been thanked: 4459 times
A great capture of AR2297...despite the conditions, you pulled it off.
- solar
- Has thanked: 246 times
- Been thanked: 1426 times
That's how it goes some times Mark. I think it is a top result.
I tend to get bogged down with what worked instead of trying different things. I am changing my ways.
Good luck with the Solar Ecp's tomorrow.
Vixen 130ss SolarMax 90 BF30 EQ6 Pro, LX200 14, C8 CG5, Megrez80, Lunt 100 DS. EQ 8
ASI 120mm 290mm 432mm Lunt B1800 Cal-K + other stuff.
Skywatcher 150mm PST Mod2
Thanks all, a couple more that 'kinda' worked...
ar12303-Ha-bw by Mark Townley, on Flickr
ar12303-Ha-colour-invert by Mark Townley, on Flickr
Mark!
Mark!
