Filament Jump
ischua
Filament Jump
Post by ischua »
Did anyone catch the filament jump off the sun today at about 2:30 eastern US time. It only lasted a few minutes and was gone. Here's a shot with my neximage solar system imager its not on par with what you can do but I'm learning.
I used a recontacted Coronado SM 60 single stacked in Ha no photoshop
Mike
Has thanked: 64 times
Been thanked: 4407 times
Re: Filament Jump
Post by MapleRidge »
Good catch...I think I shut down about a half hour before that time.
Been thanked: 1 time
Re: Filament Jump
Post by swisswalter »
Hi Mike
a great shot from that short event
oreoluna
Has thanked: 1 time
Been thanked: 661 times
Re: Filament Jump
Post by oreoluna »
Good catch
GUS
Has thanked: 102 times
Been thanked: 213 times
Re: Filament Jump
Post by GUS »
Great capture, what happened to the etalon.
Derek Klepp
Been thanked: 171 times
Re: Filament Jump
Post by Derek Klepp »
Good catch Mike
edobosz
Re: Filament Jump
Post by edobosz »
Good catch, that is quite a blast off.
Ted
michael.h.f.wilkinson
Re: Filament Jump
Post by michael.h.f.wilkinson »
Very good catch. Just clouds here so thank you for sharing.
ischua
Re: Filament Jump
Post by ischua »
GUS wrote:Great capture, what happened to the etalon.
The scope was given to me. It sat in a shed for a few years after the tripod fell over with it. The etalon had been taken apart and everything was very dirty.With some help from DaveG I was able to recontact it. From what I hear I got lucky.
The views are wonderful with it but I need a better imager 640x480 will never give me the captures you guys get.
Mike
jetstream
Re: Filament Jump
Post by jetstream »
I watched the event starting as a triangular solid lump on the sun, to the jump and disappearance. The view through my Quark 90mm SV APO was photographic like- very high detail and sharp as a razor. The SW120ED upped the view again. Great catch ishua! I hope some others caught it too.
Gerry
SW 120ED Pro,90mm Stellarvue
Baader Cool wedge, Quark Chrom
Has thanked: 20738 times
Been thanked: 10433 times
Re: Filament Jump
good snap!
ischua
Re: Filament Jump
Post by ischua »
Thanks much for the kind words.
Mike
