Animation AR2577-74 ( Aug 13th ) Réfractor 230mm H-Alpha
jp-brahic
Post by jp-brahic » Thu Aug 18, 2016 5:09 pm
Hello
i presents you a small animation on the group AR2577-74 realized on August 13th with a turbulence more than averages, deteriorating as the sun rose in the sky
55 images of 15sec spaced out by 30 sec , Génika Astro 2.11
On the other hand big problem with my flats which did not really work , I do not understand why !!!!
Size(Format) reduces to 75 %
JP
TN 450mm F/D 4 Zerodur
Has thanked: 556 times
Been thanked: 309 times
Re: Animation AR2577-74 ( Aug 13th ) Réfractor 230mm H-Alpha
Post by ffellah » Thu Aug 18, 2016 5:35 pm
Still very impressive, given the conditions.....
Has thanked: 27 times
Been thanked: 106 times
Post by Valery » Thu Aug 18, 2016 5:56 pm
Very nice capture, JP!
Thanks for sharing.
Valery.
jp-brahic
Post by jp-brahic » Thu Aug 18, 2016 6:16 pm
Franco , Valery thank you for your clemency
JP
fjabet
Post by fjabet » Thu Aug 18, 2016 8:39 pm
Nice result given the conditions Jean Pierre !
Has thanked: 2049 times
Been thanked: 711 times
Post by Montana » Fri Aug 19, 2016 9:06 am
Tremendous amounts of detail in this, it had me mesmerized for ages :bow :bow :bow
It is wicked that animations really show up the flats that fail, they are quite unforgiving. I'm sure you will sort the problem and the next will be perfect :hamster:
jp-brahic
Post by jp-brahic » Fri Aug 19, 2016 4:46 pm
Fred, Alexandra thank you
Alexandra , i hope to do better next time with better Flats ;) and a better seeing!!! it's very difficult to obtain a good seeing for a long périod with this sampling
JP
Has thanked: 5 times
Been thanked: 261 times
Post by MapleRidge » Sat Aug 20, 2016 2:10 am
Hi JP...
A very nice animation despite the issues you encountered. When the seeing is better the details are superb :bow
C9.25 Edge/Daystar 250mm ERF/PST (Modded)
Lunt LS80PT/LS75FHa/B1200Ha
CR-150/DSII/B1800Ha (Modded)
Stellarvue 110, f7 or iStar 150mm, f8
Daystar Quantum 0.45A SE, Quark Combo Chomosphere, Lunt WL and CaK Wedges
MI250 Mount carrying C14
ASI 1600MM, ASI174MM, ASI290MM/ASI462MC, Canon 60D (Ha mod), SBIG STF8300/FW8
jp-brahic
Post by jp-brahic » Sat Aug 20, 2016 6:13 am
thank you Brian
JP
jp-brahic
Post by jp-brahic » Mon Aug 22, 2016 6:29 am
thank you Pedro
JP
yltansg
Has thanked: 638 times
Been thanked: 278 times
Post by yltansg » Mon Aug 22, 2016 7:50 am
Hi JP,
The details are fantastic!! Congrats. A pity the flats failed. Any clue?
Alfred
jp-brahic
Post by jp-brahic » Tue Aug 23, 2016 5:48 am
thank you Alfred
for the bad Flat , yes i have an idea , I shall test a new method the next time
JP
Has thanked: 800 times
Been thanked: 702 times
Post by Carbon60 » Tue Aug 23, 2016 5:58 am
Beautiful levels of detail with lots of subtle movement, JP.
Good luck with the improvements.
