June 25th Session
Has thanked: 64 times
Been thanked: 4406 times
June 25th Session
Post by MapleRidge »
Hi everyone...
Well, it took a week but I managed to sneak a few hours in to process the video clips taken last Sunday and get them posted.
This session continued the display of the large filaprom that was visible the previous day, but it had become more regular prominence in the 24hrs that elapsed from the previous session. Still, it was a great prom to view and image and AR 2264 was still a great target.
The first images are full disk and limb composites taken with the LS80T/DSII/B1200Ha solar scope and PGR camera (ICX674 chip):
The final FD image had the gamma boosted to pull in the proms without the disk/limb stack:
The seeing continued to be poor, so I stuck to imaging with the LS80T scope, but added the 2.5x barlow to get a higher resolution image of the filament/prom activity on the western limb:
Before finishing up before lunch I shot a few images through the Meade 25cm ACF/Daystar full aperture ERF/AiryLab 2.7x telecentric and the ZWO174MM camera in binned mode to try the AR and proms with the Daystar Quantum 0.45A filter. Results were far from ideal...seeing on the SSM was running in the 3-4 range, occasionally dropping below 2. I've posted them to show what the day produced...probably the seeing had the most effect, though I have had little time to experiment on refined stacking and processing for these images:
Comments, thoughts, and suggestions are more than welcome ;)
That's all form the last session. I'm hoping for some clear skies over our long holiday weekend, and more rain has work on hold for a few days too...maybe a chance to play in the sun again :P
gabrieli
Been thanked: 1735 times
Re: June 25th Session
Post by gabrieli »
Hi Brian
Good to see you posting again. I'm having the same issues as you with my large ERfs, finding seeing good enough to support a large aperture.
Your hi res prom looks like it has some good detail in it but I'm guessing a high gain value had to be used.The LS80 images are, as usual, great quality.
I want to use about 4600mm on my c9.25 as a base but with a Quark or PST in SS mode, the proms are very faint and all images I've posted so far don't exceed what I've produced with my 152 Lunt. I guess a few people have lucked out finding good Quarks or PST for their large scopes. Your hi res prom looks like it has some good detail in it but I'm guessing a high gain value had to be used. Stacking a Quark on a PST does give more contrast, but the view is very dim and tuning on the PST is very coarse. I'm expecting my SSM on Tuesday next and I hope that helps in lessening the frustration.
Lou
Hi Lou...
Hope you are getting some sun this long weekend...hints of it here but not looking good at the moment.
Seeing is the biggest challenge, and the slow, cold spring has not provided any ground cover on the neighboring fields so my local seeing is worse than usual.
The prom and AR in live view certainly looked better than what was processed...probably a multitude of issues between seeing, soft focus, and stack/processing that needs refinement with this long focal length setup.
Good luck with your system!!!
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
Great stuff , Brian !!
Thanks Franco!!!
yltansg
Has thanked: 1455 times
Been thanked: 1444 times
Post by yltansg »
Splendid set, Brian!!
Alfred
Has thanked: 8523 times
Been thanked: 8252 times
Post by Carbon60 »
Some wonderful images here, Brian, particularly the close up views on the Lunt 80 of that large hedgerow prom.
Large ERF scopes really do require excellent seeing.
Derek Klepp
Been thanked: 171 times
Post by Derek Klepp »
Good set Brian
DJD
Has thanked: 42 times
Been thanked: 133 times
Post by DJD »
Lovely set Brian. That prom certainly was a great target.
David
Has thanked: 17894 times
Been thanked: 8887 times
I really enjoyed these Brian, I love the full disc and the close up prominence has wonderful fine detail, quite superb. I hope you have had a sunny holiday weekend :bow :hamster:
Been thanked: 4957 times
Post by eroel »
Brian:
A very good session after all.
Alfred, Stu, Derek.David, Alexandra, and Eric...
Thanks to each of you for your comments and support...always appreciated :bow
Been thanked: 10431 times
Nice results Brian! The seeing is so important at these large apertures. I don't bother with the HaT unless it is registering as 2 and below.
cshahar
Post by cshahar »
Lovely shots Brian. I am glad you are getting some imagining done. The weather has been horrendous from my site, a couple of hundred miles to your north.
-Charles
