Sundays Sodium Sun - 3rd June
- Has thanked: 20435 times
- Been thanked: 10245 times
Back from a week away on the boat, and Sunday dawned with clearish skies, bit of haze contributing to variable transparency. I got out the HaT to try with the Na Quark, but the seeing was not up to it so backed off to the 100mm Tal refractor. Initial impressions are it is like slightly more contrasty white light, but (at this scale) less of an emphasis on granule boundaries. It's interesting to see what this Q is capable of. Camera used throughout was the PGR Chameleon 3.
Bit of plage that has recently rotated into view...
ex-ar-na-bw by Mark Townley, on Flickr
ex-ar-na-col by Mark Townley, on Flickr
Then AR12712...
ar12712-na-bw by Mark Townley, on Flickr
ar12712-na-col by Mark Townley, on Flickr
Seeing was rapidly falling away so I dropped down to the 60mm f6 scope to do a full disk mosaic. I'm quite surprised at the detail I get from this small scope, especially when the image is viewed full size.
na-fd-bw by Mark Townley, on Flickr
na-fd-col by Mark Townley, on Flickr
I've been trying the flat field function in firecapture too, which, as long as transparency (and exposure) remain the same is quite effective. Not sure if anyone else is using this?
Then AR12712...
- Has thanked: 9411 times
- Been thanked: 5571 times
Re: Sundays Sodium Sun - 3rd June
Very interesting that Sodium filter.
- Has thanked: 1171 times
- Been thanked: 1360 times
- Been thanked: 4904 times
Thanks guys!
- Been thanked: 8789 times
A nice collection Mark, I really like the full disc at full size, very nice indeed how about taking the HaT on the boat? then you could use it on those early morning sun days and it would be over water (perfect observatory).
- Has thanked: 9144 times
- Been thanked: 6025 times
Those Sodium images seem very promising, Mark: how would you configure the HaT for use with the Quark Sodium ?
Thanks everyone. It's easy to use on the HaT - just plug it in the back like you would a regular eyepiece / diagonal and use away.
Yup. that's right Franco. I find I get better results with my Ha Quark using the native 4.3x telecentric than the HaT 2.7x.
So, just remove the Airylab 2.7X telecentric and insert the Sodium Quark with the 4x Barlow built-in, right ?
Thanks Val!
A shot of the mid disk from yesterday with the Na Quark and 100mm Tal.
granulation-bw by Mark Townley, on Flickr
granulation-colour by Mark Townley, on Flickr
What are the small dark arches? There is an obvious one top right, one less so to top left?
- Has thanked: 8418 times
- Been thanked: 8162 times
Good images, there, Mark. The sodium Quark looks like a nice addition to the family.
I've no idea what the arches are. You'll have to see if they show up in future images using the same setup to check if they are some sort of artefact, although looking closely there appears to be lots of similar arches and 'curls' in other parts of the image.
Hi Mark: when you user the HaT with the Quark, I assume you use a focal reducer. I do not believe you use it at F/43 (F/10 x 4.3x built in Barlow). If that is the case, what reducer do you use and at what position you place the reducer ?
Thank you,
Thank you,
- banjo
- Has thanked: 2090 times
- Been thanked: 2859 times
really amazing these photos in sodium, bravo !!!!!
- THEO BAKALEXIS
- The Sun?
Very closed granulation Mark.
Great work but i `ll want to see compare with white light to understand.
At the first i see faculae with very low power but i want to see the same area in white light to see the difference
Great work to images.
For me you are one of the best observators here.
Yup, I use it at f43 Franco.
I managed to get some comparison shots on Sunday morning, the transparency was poor, but I could see the sun through the haze. First off using the 100mm scope Lunt wedge and 7nm Ha filter:
gran-white-light by Mark Townley, on Flickr
Then, same scope and the Sodium Quark:
granulation-Na-100mm by Mark Townley, on Flickr
The views are subtly different. Then, what things were looking through the Na Quark and the HaT - seeing not playing!
granulation-HaT by Mark Townley, on Flickr
Mark, Did you capture another sodium bridge??
It's so difficult to distinguish if these are real features, or a trick of the eye. It's interesting to note, though, that this feature does appear to connect between two pores.
Yes, indeed it's difficult to say what that are, I may have to crack out my 5" scope and see how this works in Na. Certainly would be good skyburner if are capturing these features. Where did you get the diagram from? would be interested in more info about them...
No sun, no time. Hopefully soon!
- Has thanked: 17572 times
- Been thanked: 16694 times
Yep. What are those arches? Are they genuine, artifacts or a trick of the eye? This needs more study.
- steveward53
- Has thanked: 1225 times
- Been thanked: 1492 times
I have to say , the more I look at that last image the more potential "features" or "artifacts" I can see , the human eye/mind combination has an amazing knack for this , I could circle dozens on that image alone ...
Steve.
Day by day Solar album ... http://www.astrobin.com/users/steveward53/
Tal 100RS , ED80Pro , Mak180Pro.
HEQ5Pro , EQ3/2 , 14' pier.
Canon 1000D , SPC900NC Mono.
Scopium wedge - Baader ND3.8.
- Been thanked: 2713 times
The eye/brain combination is very good at finding structure. There are even psychological tests where pseudo random feature are presented to the subject in a way to probe the mind of the subject ;-)
Just for the record, in the book "Planetary Astronomy", we have a whole chapter dedicated on visual observation with a description of a number of optical illusion (contrast, size, inversion of color, etc.).
This being said, the question is whether these structures are seen at the same time with different telescopes and observers. Solar satellite images are probably one of the best tools to test this. I don't remember what is the fastest acquisition rate available on MDI/SOHO or Hinode (or others). Having a look at these could be a good step forward.
In any case, there is a huge lot of images available everywhere for people wishing to investigate this subject with a proper methodology.
BTW, the main mode of photopheric oscillation is the 5-min. There are measured as velocity oscilations and irradiance oscillations (see Foukal or other sources). Is it possible to have an optical counterpart for it ? I've never seen a mention of it in a professional paper.
Still ... large size planetary nebulae are currently discovered by amateurs using very small size telescope, and working in relation with professionals ;-)
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
- SteveZ
- Has thanked: 149 times
- Been thanked: 143 times
Great shots Mark. I can not wait to see more from the Na Quark.
Steve
Lunt LS80MT Single Stack
B1800 Blocking Filter
Lunt Herschel Wedge
Mallicam DS16M
AVX Mount
Steve
Lunt Herschel Wedge
Mallicam DS16M
AVX Mount
Thanks folks for all the comments, alas I no longer have the Na Quark, I sold it.
To Terry, I think. I haven’t seen him on here in awhile. I hope he’s hanging in there.marktownley wrote: ↑Wed Jun 07, 2023 5:43 amThanks folks for all the comments, alas I no longer have the Na Quark, I sold it.
- Has thanked: 2412 times
- Been thanked: 4786 times
