RAW stacked image in CaK with 280mm SCT
If any of you are interested in trying your processing skill.
This is a RAW stacked image in CaK taken May 31 2018 with my C11 equipped with ARIES 296mm DERF.
Filter - PST CaK #1 + original PST BF filter #2 + Edmund 10nm 393nm
Camera Basler 1920-155
800 frames stacked
Have fun.
800 frames stacked
Have fun.
- _SUN_080924_AS_f800_g4_ap3973 bw.png (3.99 MiB) Viewed 3377 times
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Re: RAW stacked image in CaK with 280mm SCT
Valery,
Thanks for posting raw image. I love processing other folks images trying to reproduce their results using my
usual methods.
In this case it was more interesting as I haven't processed any CaK images before. I had quite a lot of trouble deciding what was
noise and what was artefact from my heavy touch tools. So here is a first pass.
David
usual methods.
David
This is good palette for a Ca-II I at infrared 854,21nm !
Very nice first CaK processing, David!DJD wrote: ↑Sun Oct 21, 2018 6:44 am Valery,
usual methods.
David
Thanks Valery, I will have a go at this at home. Is this using a Saffix as well?
No SAFIX, Alexandra! With ARIES filter you will have such a sharpness from your 11" SCT. Just hunt for the seeing! SSM will greatly help in this.
BTW. Have you received the DERF yet?
BTW A year or so back such an offer of a RAW image for post processing will be quite demanding. But not now. Does the solar minimum is so damaging?
May be you, folks, need less boring image(s) for postprocessing?
Valery, yes the DERF is at the hubby's work in the safe (he told me today). When we get it home tonight it will be the big reveal
Would the Lunt CaK module work?
- Has thanked: 1188 times
- Been thanked: 1382 times
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Hi Valery.
Here's my version.
Peter
Workflow details:
ImagesPlusv5.5:
2.0X scale change.
Adaptive Lucy-Richardson deconvolution (200 iterations, 11x11 px)
Multi-resolution sharpening.
0.5X scale change.
Photoshop CS4:
HDR Efex Pro2: Tone mapping filter #5 - normal blend 60% opacity
HDR Efex Pro2: Tone mapping filter #4 - overlay blend 30% opacity
Curves adj (mild)
Smart sharp (1.5px 75%) - normal blend 40% opacity
Local Curves adj (mild ) in sunspots.
Curves adj (mild)
Despeckle - 50% opacity
Here's my version.
Peter
Workflow details:
ImagesPlusv5.5:
2.0X scale change.
0.5X scale change.
Photoshop CS4:
Curves adj (mild)
Curves adj (mild)
1. Nice to know that the DERF came intact to you! It got a good home! I hope that Stu will help you with the cell.
2. Yes, the Lunt CaK diagonal or straight will work just fine. Tell me what is the camera you plan to use with this
telescope. I need to know the pixel size.
This is my take #1
- _SUN_080924_AS_f800_g4_ap3973 bw proc.png (1.36 MiB) Viewed 3215 times
Hello Valery
I have a Grasshopper 3 GS3-U3-28S5M-C and a Lunt CaK diagonal, is there any hope?
PS Cracking image Valery!
- p_zetner
Love the deep contrast in your processing, Valery.
My attempt to come close is below.
Are you using some kind of line or edge enhancement filter?
Peter
Peter
No, I don't use such a software.
I would say that this camera is not fast enough for imaging with such a large aperture telescope.
In my opinion there are two cameras which can be used with good chances for a success.
ZWO ASI190MM and Basler 1920-155. They are fast enough.
I now extensively test these both cameras side by side. For CaK I prefer 290MM. For Ha I need more
tests to be done.
150fps or faster is our choice.
ASI290MM is much cheaper and should be the best choice.
- Has thanked: 20819 times
- Been thanked: 10489 times
Can you describe the processing you do Valery please?
All my efforts to formalize the work flow to a single stable sequence have failed. All depends of how good the initial recorded movie is, how noised it. All I can say is that I do use two instruments: Astra Image Pro 3.0 and Photoshop CS6. In AI I mostly use Maximum Entropy and LR deconvolutions. And a lot of intuitive steps - depends how the processing is going. Next season I will finally go with SSM - in hope to get better quality of recorded movies.
